Cadence when climbing
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
This is one of the climbs I regularly do when coming back from work:
After this climb, I have to keep mostly climbing for 12 more km with a lower grade (not more than 10%), except fort a really short section (maybe 150m) that peaks at 18%. After that it's all downhill until home.
I would get so strong if this was near me. We have nothing like this.
Super jealous. You must be strong!
Car dependency is a tax.
It's a total fitness disaster in fact hahaha
Recently I've managed to get some time and I want to duplicate my mileage... And when there's more sunlight available I hope to be able to ride some mountain bike too...
Bikes: Giant TCR Advanced Pro 0 Disc
Quoted: 105 Post(s)
Liked 69 Times
Yeah, your cadence is not bad at all. The quick answer is high. Higher the better. IMO cadence also changes with fitness. I can climb at higher (than normal) cadence with higher wattage on long climbs when I'm fit. My fitness drops so does my cadence. 30+ in the back helps. A good cardiovascular system immensely helps. I have been working on my cadence past few years. It's not easy to be quite honest. Going from 90 to 92 rpm is not easy. Gains have been very gradual. It seems like there's an optimum cadence that suits your fitness, body composition, gradient etc. All bets are off when the gradient goes around/over mid-teen percentages. 60-65 sounds about right. I have a buddy who lived in Barcelona for a while and he was talking about these climbs the other day. I was like wow you are serious this is awesome. Also was watching 2009 TdF stage 6 where the stage ended in Barcelona a week ago on the trainer. Pretty bad David Millar couldn't make it into the finish line but was super fun to watch the peloton rolling thru the wide streets of the city.
Quoted: 8287 Post(s)
Liked 9,064 Times
Why? since I've had a child 3 years ago I'm not really fit. Mainly commute twice a week to work (60/70km round trip depending on the route chosen) because I don't have much free time.After this climb, I have to keep mostly climbing for 12 more km with a lower grade (not more than 10%), except fort a really short section (maybe 150m) that peaks at 18%. After that it's all downhill until home.
You're obviously quite strong/fit if you do those climbs. My point was if you are doing those climbs you already know that when you're on an 18% grade cadence is out the window and it's just a grind it out situation. If you have knee problems then gearing is critical but there isn't much spinning going on at 18%.
Likes For big john:
Ever hear the expression "sandbagger"?
Trust me, I'm out of shape currently. I was fit when I was able to ride 120km with 3000m climb in a mountain bike in 7.30h and feel well at the end. That was in 2014. I don't think I'd even be able to finish that in any amount of time today...
I have a very low HR, and at that time I had a resting HR of 38bpm. Currently I can't get under 45. While riding I also noticed a higher HR, like 10bpm, and my max bpm is still the same, around 180. I'm way slower than I was. I suppose that my low HR helps when doing such climbs in comparison to people with more normal bpm.
Liked 9,064 Times
If you watch pro racers on a climb you will see different cadences at the same speed. We always say "spin to win" and recommend high cadence but the reality is many of us find our own cadence and it's not always 90 rpm or higher.
Liked 9,064 Times
I'm not a native English and never heard what a sandbagger is, had to look it up. Always nice to learn something
just another gosling
Quoted: 3891 Post(s)
Liked 1,940 Times
It's quite simple. One simply experiments to see at what cadence one climbs faster at a particular heart rate, or breathing rate if lacking a heart rate monitor. That cadence will probably be different on climbs of different lengths, as it takes some time for one's body to load up. The best cadence is different for everyone and can only be determined by this experiment. When one runs our of gears because the climb is steep, of course one just does whatever one can.
Having a power meter and going by that isn't helpful for determining the best cadence because one will always climb at the same speed at the same power, no matter the cadence.
One's best climbing cadence may change over time with fitness.
Results matter
Results matter
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
The heart rate is a valid indicator.. the trick is coming up with methodology to do this though. Doing the same climb on different days could yield different HR results even using the same cadence. Doing repeats of the same climb on the same day obviously could yield diffferences as one tires. Maybe doing 4-6 repeats, changing cadence every other run and then averaging results?
BTW, I also noticed that temperature affects performance quite a bit. At 5°C I'm noticiably slower than at 15.
Bikes: Felt ZR3, Specialized Sectur
Quoted: 100 Post(s)
Liked 52 Times
I have started to use a cadence sensor. I read that an ideal reference cadence is around 90rpm. I've been looking at my cadence and found that I can easily ride at 90rpm (and higher) when descending with little effort. On the flats, at normal speeds, I seem to pedal more around 80rpm, only reaching 90rpm when I want to push myself and go faster than usual.
However, when climbing any meaningful slope (10%, for example) I found I'm totally unable to pedal at 90rpm. I feel really uncomfortable at that cadence, and end doing most of the climbs between 70 and 80, and, sometimes, even falling down to 65rpm if it's a really steep slope (16 - 18%).
What is a usual cadence for such climbs?
The 90 cadence thing for climbing was not invented by Lance, but he sure popularized it. He would 'spin' up those huge climbs at 90rpm plus. Ulrich, his main competitor at the time was more of a grinder and would tend to grind it out as we would say. In today's pro peleton, Froome is the main spinner. He too spins up these climbs at 90rpm plus. Kind of weird seeing him spin like crazy up these climbs while others around him seem to be pedaling a more normal cadence but it has worked well for him.
What I have been told is that you really have to work on this and that it does not come naturally. You have to teach yourself to do this because your natural inclination is slow your cadence down while climbing. Just goes to figure that the slower you are going, the slower your cadence is. Spinning up climbs does though put less pressure on the knees but again, you have to train yourself to do this since it is not a natural pedal stroke.
Like others have said, experiment around and see what works best. I'm more a grinder, but that works for me. I'm not racing or anything so I tend to do what feels best.
john
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Bikes: bikes
Liked 1,429 Times
Figuring out the cadence at which you can sustain the highest power is pretty helpful. That's a lot more important than hr which is going to be different depending on a dozen different things.
Quoted: 1067 Post(s)
Liked 259 Times
Power is the best measurement to see what cadence works for you.
Another more basic way is to do some climbing with riders that are faster than you.
Play around with gears/cadence and see what seems to work best for keeping up with the others.
Liked 1,940 Times
And yes, those physiological symptoms are going to vary, depending a few things, mostly hydration, feeding, and training status. For those same reasons, max sustainable power will also vary according to those markers. And of course max sustainable power will also vary with the length of the effort. There's not one number. Interestingly, on my big event this past summer, I sustained a higher power on my last climb of 2500' than I did on earlier climbs and at a slightly lower average cadence. Probably I was simply giving it up. It was 20° hotter, too. I was going by breathing and holding power steady. Yes, steady power, but what steady power?
My cadence was 75-79 on the big climbs, just like it's been for the past 20 years. Lower gears now of course.
Results matter
Results matter
Liked 1,940 Times
The main thing is length of climb. On short climbs, I'm much faster at 95-100 cadence because power = force * cadence (more or less). I'd blow up if I kept that up. On long climbs, I'm much faster at 78. Higher cadence slows me down. But I'm an average guy. Talented people will climb at higher cadences. That's one of the ways you know you're talented.
Results matter
Results matter
Liked 1,940 Times
I think you have this backwards.
Whether one realizes it or not, one does an FTP test not by power, but by physiology. An FTP number is the result, not the input. If one isn't doing it that way, one is either dogging it or one blows up.
Sure you go into the test at what you think your FTP is and that's a nice feature. But after than, you're winging it. Same thing with cadence.
Results matter
Results matter
Likes For Carbonfiberboy:
Quoted: 741 Post(s)
Liked 412 Times
It seems like heavier riders tend to climb at lower rpms. I have always wondered if that is because the need to produce much more wattage to ride at the same speed as riders who are much lighter.
Bikes: bikes
Liked 1,429 Times
The rest of your paragraph is fairly nonsensical. The notion that you can just look at speed is a bit bizarre. I've never done a climb that I can simply look at speed to determine whether or not I'm maxing it out.
To compare speed to power is just wrong.
Bikes: bikes
Liked 1,429 Times
Where are you coming up with this notion that you can't maintain a given power output with different cadences? I do it on every single climb I want to do it on. Doesn't matter if it's 5% or 15%, 1 minute or 30 minutes. It's precisely how I do workouts. I think most anyone else that routinely rides with power can as well.
Likes For rubiksoval:
Liked 1,940 Times
When I can't hold higher power.
Results matter
Results matter
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
I'm 74 and 230 pounds. My power has declined almost 25 percent the past four years due to aging and neurological condition in my calves. My maximum HR is 165-168. Here's my cadence personally tailored to my combo of HR, power, and power to weight ratio these days.
A five-mile Cat 3 climb at best effort for time: Avg HR 150 with a max of 165-168 and the average cadence is 82. I switch from the 50 crank to the 34 after about the first mile. The hill starts out gradually and generally slowly gets steeper from start to finish. It goes from 2 percent to start to 12 percent at the very end. During the past 4 years, I've lost at least 65 watts of sustainable power or FTP. I am now on average 6-7 minutes slower up the hill.
On the flats, an endurance rate or pace is 95 cadence and HR is 115. If I am pushing hard for three or four miles my HR is 145 and cadence is usually about 105 average.
Going for a maximum effort of three-quarter of a mile on the flats my cadence remains at 105 but at the lowest gear, I can maintain for that distance at full power. HR runs steadily at between 150-156.
With the loss of power and low power to weight ratio I have as of about 18 months ago gone from and 11 speed 11-32 to an 11-40. The steepest I can climb for about one mile is at a near steady 14-15 percent and average cadence is 54. On a cat 3 or cat 2 climb, the steepest portion I climb is 18-19 percent and it takes a 100 percent max power effort for me to do that.
The above demonstrates that my cadence remains the same over four years despite the 25 percent loss in power. All that has changed is what gear I use for a particular grade at any particular spot on a one to 10-mile climb. The bottom line is for climbs cat 3 and 2 the optimal cadence for me has stayed the same on most at about 86 average. That 86 with the right gear beats for me as an individual a 90 or low 90 in an easier gear as far overall best time of a good climb like those I've described.
Likes For BengalCat:
Quoted: 73 Post(s)
Liked 41 Times
It would seem that by the time heart rate ramps up, it would be difficult to know if caused by cadence. or simply going to hard
Always a lag with heart rate, and a significant amount of variance due to many factors
Liked 1,940 Times
Or perhaps you simply left the word "maximum", or better, the phrase "maximum power output for the length of the climb" out of your first sentence? Yes, it's true, I can maintain zone 1 power for a long time at almost any cadence. Well, not any. 10 is too slow and 120 is too fast. For most folks, that 10-120 range gets smaller and smaller as the power goes up. But not for you! Does anyone here train in erg mode?
More to the point, are you saying that the OP's question is nonsensical? I thought that "best cadence to produce maximum power output for the length of the climb" would be a good way to put it. And IIRC it was you who pointed me to the article about the fellow training to win the Mt. Washington climb and how he found a 95 cadence worked best for him. That was very informative.
Results matter
Results matter
