Rene Herse catalogues collection with Daniel Rebour drawings scanned
Wonderful to have these! I downloaded a few of the interesting full bike prints from the catalog and am having them printed on matte photo paper (5X8 inches did the trick) so I can frame and hang them in my house.
I nowhere mentioned that the files where uploaded for private use only. I thought that went without saying.
Herse's name appears much more frequently if you omit "Rene" and only search for "Herse" in L'Auto. It's actually quite interesting to see how frequently Herse is mentioned by other companies. Sometimes you can find things like mentions of Rene Andre riding for Herse before he set up his own shop, or mentions of Herse himself when he rode for Narcisse.
Many (most, all?) articles on subjects like technical trials or Poly de Chanteloup where written by Claude Tillet, the founder of "Le Cycle" in Sept. 1945. And Herse had an excellent reputation as a bicycle component maker already in 1939. When I remember it correctly, Tillet wrote in 1939 about Herse as the best of his profession.
Quoted: 1088 Post(s)
Liked 1,205 Times
These are amazing. Thank you for this hard work! Obviously a labor of love.
Quoted: 3464 Post(s)
Liked 2,831 Times
Invaluable. This type of information should be preserved for the coming generations. Thank you.
I've noticed this misconception as well. Although some constructeurs used the 650B wheel size on bikes designed to be fast randonneuses, there seemed to be a preference for 700C for any type of "fast" bike through the decades, even during the "Golden Age". The demi-balloon 650B tire was mostly utilized on city bikes, utility bikes, and camping bikes when it came to production bicycles.
regarding 3/10 tubing- I have tested one with and it was more flexible but not crazy, yes when riding up the club ride “wall” it was drive train noise inducing. My normal ride at the time was 7/10 tubing. The weight saving was noticeable post ride.
I would think that Herse would select what tubing would be considered best based on the client’s weight, riding style, etc.
In the 70’s 650b tire size was really scarce and limited in the USA , Michelin could be imported, there was one that was reasonably lightweight, only allowing a tire driven dynamo with a rubber cap. Today, there are more choices at least to the general consumer.
Quoted: 964 Post(s)
Liked 1,451 Times
The downtubes we got from Reynolds were 30 mm and double-butted. It was my understanding at the time that the Taylors also used that DT, though I don't remember if I measured the DT on a Taylor -- anyone here know? I thought I heard that Singer, Herse et al. used 30 mm DTs also, but I don't remember where I heard that, so don't believe it unless we get corroboration.
Mark B in Seattle
Mark B in Seattle
Right then, here are some measurements.
Downtube:
Herse: 30mm
Taylor: 32mm or 1.25"
Seat tube:
Herse: 28.0mm
Taylor: 28.6mm
Boom tube:
Herse: 50mm x 25mm
Taylor: 50.8 (2") x 22.8 (this dimension was hard to measure with all the cables and chains in the way and didn't want to scratch what remains of the paint.)
For what that's worth. Sorry it took me so long to get this. I do wonder if Herse put Vitus stickers on even if the tandem was a mix of tubings - although this bike was made very shortly after the war so it might not be a particularly representative example.
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
Both have 28 mm steerers I presume? Stronglight headsets, or mystery unbranded headsets?
Thanks for the measurements, very interesting.
Mark B
Quoted: 964 Post(s)
Liked 1,451 Times
I do worry for the bikes occasionally, but I refuse to put my dreams of constructeur bikes on hold until "someday" when I have a better place.
Mark B
Mark B
The Herse has the tapered steerer. It tapers from 28mm down to either 25.0 or 25.4 (forgot to measure until I was back upstairs writing this post) thread. It's got a section of tube brazed in there, which appears to be 22.2, but is out of round so hard to tell. The stem clamps onto this tube.
The Taylor takes a standard 22.2mm stem quill, but I've never had its headset apart to see what's going on inside. The bottom cup of the Taylor headset and the bottom cup of the Herse headset appear identical or nearly so, in dimensions and appearance. The top cup of the Taylor headset is larger than the top cup of the Herse headset, so possibly the steerer is the same diameter throughout.
Liked 2,576 Times
Both headsets have some Stronglight branded parts top and bottom, but not every component says Stronglight, although they do work together so they probably are all Stronglight.
I know you (@scarlson) know this, but for anyone else with a Stronglight 28 mm tandem headset -- take care of it! They're very hard to find, and much higher quality than the Bardon that folks were forced to use after the Stronglight supply dried up. Even if your Stronglight develops divots from wear, don't throw it out, get it re-ground. I have heard they are through-hardened, though I don't have any reference for that, might be internet lore. But I expect even a reground Stronglight is better than a Bardon. I've heard Mel Pinto Imports still has 28 mm headsets, but I don't know what brand. Maybe they're high-quality and all my worrying is for nothing...
Mark B
Quoted: 237 Post(s)
Liked 83 Times
I may be the only one who can corroborate and compare in the comfort of my own apartment! I finally got a chance to measure the downtubes (and some other tubes, just for curiosity's sake!) of my '59 Taylor and my '46 Herse tandems. It is worth noting that the Herse came with Vitus decals on the forkblades and seat tubes, while the Taylor had remnants of Reynolds decals, particularly on the boom tube.
Downtube:
Herse: 30mm
Seat tube:
Herse: 28.0mm
Taylor: 28.6mm
Boom tube:
Herse: 50mm x 25mm
Downtube:
Herse: 30mm
Seat tube:
Herse: 28.0mm
Taylor: 28.6mm
Boom tube:
Herse: 50mm x 25mm
The Taylor dimensions match up with the 40's Reynolds tandem tubing, with the boom being an ovalized 1 1/2" tube.
In reference to oversize tandem tubes on single bikes, it's interesting to note that a "single oversize" French tube at 30mm is equivalent to an imperial "half oversize" 1 3/16 tube. An Imperial "single oversize" tube at 1 1/4 is closer to a French "double oversize" tube at 32mm.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Thank you for making these available, @HeikoS69! They were preserved and scanned perfectly.
Likes For bear_a_bug:
