Pletscher Rear Rack Question
Pletscher customer service is on-point. Kudos to them for sending me these measurements on their adapter. Posting here in case anyone else has this question in the future.
blahblahblah chrome moly
Quoted: 1198 Post(s)
Liked 2,627 Times
I notice they don't give you what is arguably the only measurement we need, the inside width, which should match up with the outside width of the braze-ons on the frame.
We can infer it from the measurements they do give though, looks to be 58.5 mm. Is that anywhere near the BO width on your frame?
The BO width can be narrower if you don't mind a stack of washers to make up the difference. But beyond just a few washers, that's ugly and structurally inefficient. The frame can't be wider than 58.5 mm though, not without unbending and re-bending the adapter.
Probably easier to just make one, out of suitable steel, just two bends and 4 holes. Stainless is harder to work with, but has the advantage of not rusting, so that's probably what I would make it out of. I'm happy to provide more tips like where to buy stainless, how to drill it etc, ask if interested.
Likes For bulgie:
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 166 Post(s)
Liked 102 Times
+1 to getting a Blackburn. I had a Pletscher on my first 10-speed, a Schwinn Continental. It attached via the infamous sandwich clamp, and swayed in the breeze with any sort of load. That's a good bike/rack match, as neither are very good but both are classics from the same era.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 942 Times
I know the rack is likely older than the bike, but the Pletscher is soooo cool looking with its polished aluminum (and very functional with the spring hinges to hold stuff down).
If I ever get a 70's bike I might swap it over but right now all my "vintage" frames are mid 1980's Italian "racing" geometry bikes with a 90's mountain bike sprinkled in. And this '87 Raleigh that might or might not come apart on the first bump.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Likes For 1989Pre:
Since it bugs me to no end to search for threads like this and the OP doesn't post an update or wrap-up, I'll make this a two-part ending since I'm waiting 24 hours for the paint to harden on my adapter.
What I started with...a piece of bar stock mild carbon steel that's (somewhat) easily bendable. Available at any hardware store for around $5.
After measuring, bending, drilling, filing and painting, here's what I came up with:
Will post a final pic on the bike after the paint has properly cured. This piece is pretty strong too...I'll certainly worry more about the Technium imploding than I will the rack coming loose.
Likes For tkm:
Thanks, good to have.
I deferred 58.5mm inside width myself and unfortunately the OE adapter was too narrow for the Raleigh. So, it set me to work on making my own since there was no clear OE solution to be had.
Final prototype. For this bike it just may well be good enough. I was planning to make one out of SS, but I painted this one up and clear coated it and it turned out very decent. It's certainly strong and the rack isn't going anywhere. It is the least "hardware store" I could come up with, even though it's 100% hardware store. The allen head 'water cage' bolts do help it look more like an OEM piece, I suppose.
Likes For tkm:
Liked 2,627 Times
Kudos, I love it. The weight weenie in me might have shortened the extension forward of the bolts into the braze-ons, and rounded the ends, would be several milligrams lighter
I hear ya. I was going to chop the extra length off and grind them after I had the rack alignment down (and drilled accordingly) but I really wanted to just be done...especially if this frameset implodes after the first ride. Figured if I make another set out of stainless I will adjust the length accordingly.
I don't mind the little extra overlap aesthetically as it hides the rack bosses. I stopped caring about weight several years ago as I've passed over or sold off "heavy" parts that I'd now love to have back.
Likes For tkm:
