Gifted Raleigh Gran Sport: odd components?
#76
Quoted: 7352 Post(s)
Liked 2,479 Times
I had a Gran Sport. I now have a Super Course. They both had LONG reach brakes. Getting longer reach brakes for 650b may not be feasible. I replaced my Super Course’s wheels with 700c and 37mm tires. Goal achieved. It rides very softly. Now I’m not happy with the brakes so I plan to replace them with dual-pivots which require less hand pressure.
#77
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 642 Times
OK, back to "odd components" for a moment. Lifted from “are you looking for?” topic: "Raleigh Grand Sports and Schwinn Premis, 2 for the money at 350 bucks in Raleigh, NC"
https://www.facebook.com/marketplace...39968249615443
I see Campy shifters and RD, the cranks don’t really look Stronglight-ish to me. A Doppelgänger? Maybe adding Campy to a Grand Sport was once “a thing”? That one does not seem to have Campy pedals however, and I cannot see the hubs or seat post.
Sounds like it was just as well I got talked into after 27's on the wheels I have. Pretty sure there are Weinmann center pull calipers longer than these 610's, but...
Thank you -- but I wonder how much of that is the poor photography?
...and I got the follow up e-mail -- and almost cancelled! 1400 yen for tape, 4,000 yen for shipping, so over $43 for two rolls of tape. But I went ahead. I hope the color does look that good in person!
tiger1964- The follow on email is a normal part of the international ordering process. You should hear from Grand Bois shortly confirming the order. Typically, you also receive one of their catalogues shipped with the order and it's worth buying something just for that alone.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
#78
Quoted: 987 Post(s)
Liked 642 Times
MORE PHOTOS COMING SOON
"Odd components" gets a bit odder -- but not the ones I found on the bike.
After two other topics I added to or started, ROADLINK and AXLE, I have been able to finally get the 13T/32T IRD freewheel on, and the NR derailleur with the Roadlink and the long Soma cage installed. New cabling (blue!) from Velo Orange out for delivery today, and I'll see if (a) it shifts at all, and (b) whether it works better with or without the Roadlink. in-process photos on the RD installion in the other topic.
OK, the Sand Canyon tires, tubes and rim strips arrived, and now on. Due to the rim type meaning the heads of the spoke nipples are NOT recessed, I decided to use rubber rim strips and not Kapton tape... this time. I think that made tire installation a little tougher. Now, reading that 27x1-3/8" is 35mm wide, I measured the bike with wheels on while awaiting tires. YIKES! At the chain stay, not all that much over 35mm! Well, I decided to mount them and see. Uh, could not get the wheel in without deflating the tire. Once in, looked like pretty good space in the back and huge amounts in front. Then I started measuring, inexplicably despite the same tires on identical rims, the front tire was 31mm wide and the rear 29mm. Getting ready to contact Swift about this, then it occurred to me; per above, little air in the rear tire. Pumped up, both are now about 31.1mm and it's s wee bit tight but OK at the chain stay, I better not break a spoke on a trail ride.
Little things like assembling seat and post to the bike should be easy, as it's the ones earlier on the bike -- but the post did not want to go in the seat tube. So I buffed down the post with a fine (white) Scotch-Brite, and then took a auto brake cylinder hone to the seat tube (inverting the bike as the BB is freshly rebuilt). Then I made a coat hanger into a copy of the rod they use for cleaning gun barrels, only bigger -- and ran paper towels up and down until one came out clan. Post went right in, then.
Still to go: install pedals (someone had a deal on M540 SPD pedals) brake levers and handlebar tape, clean the factory lube off the chain and hot-wax it, locate and install a water bottle cage and perhaps a pump (it came with a Brev. Camp. umbrella), fine tuning.
By way of bathroom scale, 24.1LB with a few parts still to add. The tires and the gigantic freewheel are not helping!
Many have sung praises of these. $36 each. Take two of these and call us in the morning.
#79
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Good job on the seat post, that's pretty much what I would have done.
#80
Quoted: 987 Post(s)
Liked 642 Times
JUST ONE PHOTO BELOW FOR NOW.
I do have a question for you, based on that photo of yours, and anyone else with an originalish Gran Sport -- I just received a replacement set of brake levers, to replace the bent ones, from forum member 67carlton and not only in great shape they came with the white Carlton hoods (I had already bought a set of gum Cane Creek hoods). So, I soaked the levers in hot water to soften the hoods and they came off intact . There was a lot of black reside inside (aluminum oxide abraded off the lever bases?) and I was cleaning them up, and now I have black residue embedded on the outside of the hoods! I've tried several cleaners with little luck (see photo). Does anyone have a nice idea how to get them back to gleaming white? Bleach? EDIT: amazingly a quick Google search had results on exactly this (except maybe the aluminum oxide part), so I watched a couple of videos and am heading to the auto parts store for a bottle of Bleche-White, a product that had been around just about forever. Results will be posted. But if you know anything better...
I just wrapped mine, and like the results (see photo). Your experience may be different than mine as my original bars have been replaced with SR Sakae World Randonneur bars, but the plugs are simply too small and to amount of tightening will keep them from falling out. I even tried using a small strip of the handlebar tape as a shim -- no success.
By the way, this is my first cloth tape in quite some time and, for gravel use, not having cushioning had me concerned. I was thinking of wrapping the bars with cushion-y tape first, then the Grand Bois; but I found this stuff on Amazon: FIZIK GEL PADS . Those made the installation a little more challenging, but not insurmountable, so now I have grippy cloth tape AND cushioning. You might be able to see in the photo that the bars look a little bit chubby.
The derailleurs/levers/cables are in place and working fine, using the RoadLink and Soma cage plates on the Nuovo Record (there's another topic on that), and I am having issues with getting the perfect housing ferrules for the braze-ons for both shift and brake cables (there's another topic on that too). The Velo Orange cable housing in blue is a very pretty color and I like it -- but it's noticeably darker/brighter than Lagoon blue or the Grand Bois tape. So, I see on-line this stuff sold by the foot, would this look better? HOUSING And, if I decide the Brooks Pro is just a bit much for gravel trails, I see the same place has a matching Saddle: LIGHT BLUE SADDLE. Anyway, swapping in housing at a later date is not likely to be a major problem.
Getting closer. Once I get the hoods looking nice I need to hook up the brakes, and I need to do a final adjustment on the headset, screw in the SPD pedals (there's a topic recently on pedal washers so I bought a pack, first time I've used them), re-dish the wheel due to a small axle spacing change (and there's a another topic on that as well), and perhaps look into accessories like a water bottle cage.
If you are looking for cloth bar tape that is lagoon blueish, try the Viva brand tape from Gran Bois in Japan. Ordering and shipping is easy and fast and the tape comes with white bar plugs in the package. https://cyclesgrandbois.com/SHOP/BT_viva.html That is the tape I used on my Carlton resto last year as you can see in the photo below.
Likes For tiger1964:
#81
Liked 5,803 Times
#82
I think I've "cleaned" them with a light wipe of Acetone. I put "cleaned" in quotes since with Acetone you may just be removing the top layer. Try it in an inconspicuous place first. The Carlton hoods are AMAZING in their durability compared to gum hoods.
#83
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
tiger1964-
The tape looks good and seems an excellent match against the head tube paint. The gel pads give the bars a nicely chunky look without the poor results often seen with gel tapes. The white plugs are small in diameter. It took two wraps of tape on each plug to bulk the plugs up to where they would stay in the ends of my Cinelli Giro d'Italia bars on the Carlton.
#84
Quoted: 987 Post(s)
Liked 642 Times
Now I have to make a decision. The included "fat" ferrules are plastic, I have encountered them before a long time ago. But elsewhere on the forum I read "do not use plastic ferrules", do they fail in service? While looking for ferrules, I saw Velo Orange had Dia-COmpe metal adjusters, that's neat, and I got a set. But that means opening up the top hole in the hoods with a Dremel with the risk that goes along with it.
tiger1964- The tape looks good and seems an excellent match against the head tube paint. The gel pads give the bars a nicely chunky look without the poor results often seen with gel tapes. The white plugs are small in diameter. It took two wraps of tape on each plug to bulk the plugs up to where they would stay in the ends of my Cinelli Giro d'Italia bars on the Carlton.
Good to know; well, all gum hoods everywhere seem to "perish" eventually. But they do not seem as "squishy" as gum hoods. Perhaps this is not critical.
#85
Quoted: 1830 Post(s)
Liked 3,382 Times
background info: I bought the International in 2000, and it had only recently emerged from the basement of the bike shop where it had been hibernating for decades. This shot was from 2005.
The hoods are indeed fairly hard. They are an improvement over a bare aluminum lever, or one with a wrap of bar tape on it, but are in no way as nice as a gum hood.
Everyone knows that gum hoods are the first step on that slippery slope to a decadent lifestyle.
Steve in Peoria (enjoying a bit of decadence every now and then)
#86
Quoted: 987 Post(s)
Liked 642 Times
Not 100% certain my hoods are as white as steelbikeguy's, it might just be the photography - but then again perhaps not. I'm actually considering white gloves for this bike, not to stain the tape and hoods.
On the ferrules-versus-adjsters conundrum, I got lucky. I had forgotten another project that I had tried conversing to upright bars and that failed, but the bars still in storage had Dia-Compe levers. And they still had the ferrules, and they are metal and fit the Weinmann drop levers. I'll save the adjusters for some other bike where hacking up hoods would not be so risky. You'll see no cables trimmed; in another topic I was fretting about not having the right size ferrules -- and forum member oneclick has made up custom ones and when they arrive, I'll finalize everything. The darker blue housing is growing on me, maybe I won't pull it all back off for the light blue available from porkchopbmx.
The "punch list" is now short, the bike should be ready for a test ride soon. I might order replacement Reynolds decals, the more I look at what's there, the more they detract from the bike.
#88
The hoods came out pretty well, though I admit I've never heard of Bleche-White, and the bike is looking really nice altogether. I do have to say the dark blue cable housing isn't working for me, too many shades of blue between the paint, the bar tape and the housing. Personally, I don't find cable housing to be an attractive highlight on any bike so I favor black or white to help it "disappear" into the background.
This is a terrible time to ask, you having just taped the bars and all, but do you want a longer GB stem? Seeing how high the saddle is made me realize you are a little tall for this frame size and the cockpit may feel a bit "crowded". I have one I can send you.
#89
Quoted: 987 Post(s)
Liked 642 Times
If you ever had wide whitewalls on your 1948 Ford coupe, you'd have heard of it. That said this is the first time I've purchased/used it. Cannot remember the original manufacturer's name, apparently they got bought out.
Thanks! I still have to figure out accessories like pump & water bottle, hope to have a test ride in a few days -- to see what works loose.
Understood -- I am borderline on it myself. I might order the light blue housing later. I'm different, I like the contrasting housing on my bikes -- 6 of my 7 bikes are red and I accessorize via handlebar tape, housing, pumps, etc.
Actually it's a good fit! I think. Most of my height is in my legs, with short torso and arms. The frame is actually a good inch short in the ST, thus the amount of post showing. By the old rule of putting one's elbow against the nose of the saddle and seeing if your fingertips reach the stem/bar intersection, I could actually ride a one inch shorter stem. Eh, most of my bikes fail that test, however; let's see how comfortable it is once on the road. But thanks for asking!
#90
Liked 2,479 Times
My 1975 Gran Sport had a 750 caliper on the rear. I switched to tubular tires so I had to drop the brake pads. That left a mediocre caliper working even a bit worse. Switching to modern dual pivot (side pull) calipers will be an improvement.
#91
Quoted: 1952 Post(s)
Liked 2,013 Times
Nice One. One of my favorite paint schemes and if I wasn’t always downsizing, I would like to have kept my ‘73.
I’m a little late with advice on spraying paint into a cup but next time, put a straw over the nozzle and you can drizzle the paint into a small cup. I use little measuring cups as used to mix epoxy for finishing thread wraps on fishing rods.
#92
Quoted: 987 Post(s)
Liked 642 Times
(PHOTO BELOW)
Interestingly, the rear caliper needed a little grinding despite this being the wheels and brakes on the bike already.
I'll try to remember that. For now, I am keeping the leftover spray paint -- once I find a correct-sized pump, with a little masking I can make the pump white with the blue bands aligned with those on the seat tube.
Well, the bike is "done" except a serious shakedown and then retighten everything, and locate a pump and water bottle (actually on the way from Belgium) and mount a cage. Once the ferrules Oneclick made went in place the brake and shifting cable are "playing nice", you can see them in the photo. As someone talked me into a roll of housing liner on a different project, I decided to cut a length to go between the fixed stops on the top tube where the rear brake cable is bare -- I figure it might help prevent the cable from scratching the paint and you almost cannot tell it is there. Even riding it a couple of blocks to and from our 1896 schoolhouse, I could tell a few things, mostly about the cockpit. The bars feel a little narrower than I am used to, and the front-to-back length feels shorter, but I think the latter is simply because most bikes tall enough for me are a bit long. A "real" ride will tell more. It feels very smooth, I presume due to the fat tires and I am unused to only 80PSI; the gel pads under the handlebar tape might contribute. Way too early to tell but the Brooks Pro seems fine; i may need to raise it a bit.
I want to thank all the contributors to this thread for their input!
Nice One. One of my favorite paint schemes and if I wasn’t always downsizing, I would like to have kept my ‘73. I’m a little late with advice on spraying paint into a cup but next time, put a straw over the nozzle and you can drizzle the paint into a small cup. I use little measuring cups as used to mix epoxy for finishing thread wraps on fishing rods.
#93
Quoted: 987 Post(s)
Liked 642 Times
I was thinking this thread was "over", but...
Yesterday was the shakedown, 15 miles, it did well. By the end the horrific shrieking from the brakes had died down, I presume that was the first few stops on brand new pads but I do not recall experiencing that with Kool-Stops before. Everything else on the bike fine. Got it home and on the stand, gave all the bolts a check -- a few did need an additional 1/4-turn or so.
Today, 25 miles, riding with the "original" owner's son; we even got a short video of him in a parking lot on his father's bike. Easy ride, few hills, slow pace; I kept looking for a place to try out that 32T rear cog but never encountered one. The bike felt comfortable to ride except...
...OK, maybe we should talk. I was constantly shoving myself back on the seat, and my arms ached a bit despite the gel pads, I am putting too much weight on the arms. Pretty sure I need more length. So, two choices, move the bars forward or the seat back. For the former, yes, swapping a stem is not hard but, but, but... the tape! Has anyone ever successfully unwrapped, and then re-wrapped, cloth tape w/adhesive? I just don't feel like paying almost 4 times the tape's cost in postage again. For the latter, I was looking online and saw extra-setback seat posts from Nitto and IRD, both pricey. That would put more weight not he back half of the bike, I must think that over. And I've read of something I've never done for any bike, a "string test" to help determine fore-aft placement. I really should do that.
#94
You are still welcome to the long GB stem but since I am traveling for a month it will be early April before I can ship it.
There is a shade of Newbaums bar tape that is very close to Lagoon Blue that you can probably get without paying those usurous shipping charges from Japan.
#95
Quoted: 1858 Post(s)
Liked 664 Times
I'm going to guess 1973, based on the serial # and '73 - later "Raleigh" graphics. I've seen Gran Sports with either Stronglight 93 or Nervar Star cranksets but not with a Campy crankset as factory issue. Original hubs would have been Normandy with 27 11/4 alloy rims. Rear derailleur looks like a Campagnolo but it is at a wonky angle, as though someone may have mounted it to the hanger for the Gran Sport's original Simplex. Seatpost and front derailleur also upgraded to Campy. Certainly nothing to complain about here component-wise. Being as the original handlebar tape has been replaced, and the replacement tape is pretty beat up, I'd guess the bike did do some mileage before the owner's mishap.
Being as the bike came with 1 1/4 (32mm) wide tires and the frame can probably accept 27 x 1 3/8 without clearance problems, converting to 650B may not be worth the expense involved. If the geometry of this Gran Sport is similar to mine, it will make an excellent "all-surface" bike.
#96
Liked 664 Times
#97
Quoted: 987 Post(s)
Liked 642 Times
I think that rear derailleur needs a few more chain links to straighten out. Or, it could be that the dropout has the rotator stop for a Huret rear mech, and the Campy rear mech needs the stop in a different place. Ebay around for a decent Huret rear derailleur, if that's what it needs.
Thanks. I'm more used to Mafacs, so neither squealing nor toeing-in scare me. If the problem does not go away 100%... I know what to do.
#98
Quoted: 5888 Post(s)
Liked 3,472 Times
I've just started on my Raleigh Gran Sport project. That's impressive that you cleaned stuff at that level of detail. I take my bikes down to the studs when rebuilding them but I don't usually go as far as you do. Great job.
#99
Quoted: 987 Post(s)
Liked 642 Times
Thanks. Based on a recent BF C&V topic, I have bought a small ultrasonic cleaner and hopefully cleaning same parts might take less time & effort on future projects
