Tire Pressure increases 5 lbs in one ride
Quoted: 2333 Post(s)
Liked 2,097 Times
Oh geez's. Just when I'm thinking I might venture into tubeless tire realm you give me another reason not too.
So do you stop every other switch back on the way down to check the rim temps? I admire your dedication to being safe! Though actually I hope it is just in the interest of gathering data to help with the dogma.
Quoted: 6199 Post(s)
Liked 4,816 Times
No. I bought new tubeless rims with claims and some tests showing that they are better and safer than others. I checked the claims. Why? I had a double blowout thru debris on the road in September breaking 10 bones in the ensuing crash, so, a blowout isn't necessarily a benign event. I normally sit up and let the air cool me down as part of my braking strategy, so, I have never had a problem overheating carbon rims but I wanted to see for myself.
Quoted: 3352 Post(s)
Liked 1,056 Times
This is why some cyclist that run extreme air pressure have tires fail. They start with extreme pressure, and then hot road ways take the pressure way up.
On a car they say for every 10 degrees increase you get another one pound of pressure.
Liked 2,097 Times
Really Old Senior Member
For all of you taking air pressure measurements-
What's the temperature error of the gauge itself?
A bladder type gauge is likely to show higher pressure the warmer the gauge is.
Take a gauge that sits in the glove box of your car. Do you expect the same accuracy in sub freezing temps to 120+ that a car interior can reach?
How many spirits can dance on the head of a pin after lunch vs before?
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Sampling error(s) aside, slight overpressure on hookless rims can be disastrous because the safety margin is much, much lower than crochet rims. I did a mini gage r/r, the error is never upwards. 1-2 psi is lost when measuring. 5 psi difference is well within capability.
I am not sure why you consider a 2% per 10F increase unlikely. It is common form the differential from inside to outside temp to exceed 20F and the temps on the pavement are much higher still.
Stuart Black
Stuart Black
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 566 Times
Inherent error of the measuring device plus the increase in tire air temp from usage/roadway, I would think 5-7psi or more is to be expected, depending. (Say, inflating and measuring at 70deg, but riding in 85-90deg on a roadway that's ~125deg or more.)
IIRC, for example, the Meiser Accu-Gage line is rated at +/- 3% accuracy, for the gauge itself.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Might want to talk with the NFL and Tom Brady. Actually, the person you should talk with with is Jacques Charles, but he has been dead for a couple hundred years.
Check your car tire pressure after driving it.
Quoted: 1613 Post(s)
Liked 2,596 Times
I consider 5 psi to be extremely slight. You also have to consider that the pressure fluctuates with impact and/or just pedaling. The impact decrease the volume of the tire which increase the pressure in the tire. If your tire is so sensitive to a 5 psi fluctuation, you probably shouldn’t be riding it anywhere but an extremely smooth surface.
It’s not the size of the temperature increase but the impact. A 2% increase is tiny. If you heat a tire from 32°F to 112°F, the total pressure increase is 20 psi. To get a 5 psi increase in pressure, you need to heat the tire 25°F. That’s a lot of heat for a very small pressure change.
Liked 2,097 Times
It’s not the size of the temperature increase but the impact. A 2% increase is tiny. If you heat a tire froms 32°F to 112°F, the total pressure increase is 20 psi. To get a 5 psi increase in pressure, you need to heat the tire 25°F. That’s a lot of heat for a very small pressure change.
Likes For GhostRider62:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Quoted: 4806 Post(s)
Liked 3,933 Times
If the OP inflated the tires indoors at 70F and it was sunny (late May in North Carolina if I read his location correctly) the pavement could easily be 10 degrees warmer than the thermometer reads. Now, the OP did not say what his starting pressure was so I am going to presume 80 psi for this calculation. So that's 25 degrees hotter. (25+70+491)/(70+491) X (80+14.7) - 14.7 = 1.045 X 94.7 - 14.7 = 98.9-14.7 = 84.2F or an increase of 4.2psi. (5F with the gauge? 0.8F margin of error? Do we ever see better in this world of bicycles? Oh, my guess of a starting pressure affects the pressure change. A higher starting point would raise the gain. In fact, starting at 100 psi yields 5.1 PSI gain. I could do this backwards and tell you your starting pressure if you promise me that 5 psi gain is good to two decimal places. But, my school days are long past and a better grade gets me nothing so I'll pass.)
For the Perfect Gas Law to work, everything must be absolute; ie measured from zero. The added 491 takes Fahrenheit to zero. The added 14.7psi takes the pressure to zero. It must then be subtracted out of the end result so we see the relative pressure we are used to.
And that 10 degree temperature difference due to the sun on the pavement? Well I just rode 30 miles on my rain bike through two light showers. SUn after both. And both times I got to ride through a low, warm cloud of damp air evaporating off the pavement. While I rode with arm warmers, leg wamers and several tees under my spring/fall jersey.
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
I’ve not previously taken tire pressure after a ride. But I just put new Perrelli P-Zeros 700x28. Since it was the first ride I measured tire pressure and found they had both increased 5 LBS.
That is a surprisingly high increase.
how common is that?
zipp 303 wheels
new perrelli p zeros running tubeless
170 lbs rider
85degree air temp
70 mile ride @ 19 mph.
how common is that?
zipp 303 wheels
170 lbs rider
85degree air temp
Liked 4,222 Times
Nope. Not Jacques Charles. That gas law relates temperature to volume with a constant pressure. Joseph Louis Gay-Lussac is the one who related pressure and temperature. He also co-discovered boron, discovered that water is made of 2 parts hydrogen and 1 part oxygen, and recognized iodine as an element, among other discoveries.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,222 Times
Go listen to Josh's podcast after re-reading what I wrote. You have a very annoying habit of twisting **** around. I was specifically talking about the risk of over-inflating hookless rims , the much smaller safety margin of such a setup AND lastly. I do not have hookless rims.
For rbrides, he is finish temperature was 83°. Did he fill the tires at 53°F? I would still suspect some kind of measurement error over a pressure increase due to temperature change.
But your cautions are a bit of a red herring. rbrides isn’t using a hookless system.
Stuart Black
Stuart Black
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 926 Times
I suppose that depends on what a person is thinking. I do know that 40 psi in your car tires at 70 degrees F will mean flat tires at minus 50 degrees. That's more effect than some people would think, I'm pretty sure.
Likes For rbrides:
Curmudgeon
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I have not read all the replies, so this may already be mentioned, but when doing gas law calculations, keep in mind that what pressure gauges read (and what actually matters) is NOT the pressure inside the tire, but rather the DIFFERENCE between the pressure inside the tire and outside the tire.
Likes For Kapusta:
Quoted: 5224 Post(s)
Liked 3,585 Times
are you also measuring the tire width w/ a caliper before & after?
regardless, that sounds like an impressive ride! how much water did you use?
Liked 4,222 Times
I’ve done demonstrations with balloons in liquid nitrogen where I can show liquid air (and zero pressure in the balloon). It’s very cool to watch the balloon collapse and a pool of liquid form in the bottom. It’s also very cool to watch the balloon expand as the liquid air boils off.
Stuart Black
Stuart Black
Liked 4,222 Times
Stuart Black
Stuart Black
Advanced Slacker
Liked 2,537 Times
Not really. There are many different designs for pressure gauges but all of them are sealed systems that measure the pressure in the tire directly. They don’t compare the pressure inside to the pressure outside. Gauges can be calibrated in absolute pressure (i.e. atmospheric pressure included) and “gauge” pressure (i.e. just the pressure in the vessel) which matters for some measurements but for determining the change in pressure with temperature, either would work. Most every bicycle gauge is going to be measure in psig (psi gauge).
This is why the pressure you read for a tire will increase when you go higher in altitude.
Liked 4,222 Times
From the standpoint of the Ideal Gas Law, the absolute pressure is important because that law contains a variable for the amount of gas present. But the Ideal Gas Law is the wrong law to use for determining changes in pressure due to temperature. The Ideal Gas Law is derived from Charles Law (V/T=k), Boyles Law (PV=k), Guy-Lussac’s Law (P/T=k) and Avogadro’s Law (V/n=k), where n is the number of particles of gas). Since the volume and the amount of gas is constant, all that is needed is the relationship between pressure and temperature.
You can get to Guy-Lussac’s Law from the Ideal Gas Law but it’s the long way around.
Stuart Black
Stuart Black
