Clunker 100 Challenge COVID 2.0 edition #7
#426
Bikes: 4 Raleigh's (1 International, 3 Super Course), 2 Miyata (610, Alumicross), one each Bianchi Eros, Fuji Cross Pro, Lotus Excelle, Paramount Series 7 Carbon,Specialized Sirrus Comp, Trek something mountain bike, Univega Super Strada, Wheeler Tremosinep
Quoted: 19 Post(s)
Liked 45 Times
In the last couple of years I’ve had two 531-tubed Raleighs that came to me with seat lugs crimped in from too-small seat posts and corrosion. I would suggest running a brake cylinder hone on an electric drill in the seat tube to clean the corrosion out. Take the bottom bracket out first! Once that’s done try a 27.2 post with lots of grease - you might be home free then.
In lieu of a brake hone, I fashioned a long metal rod as an extension for a drill and a wire brush.
turned out pretty clean.
I had to pull the bottom bracket for this job, so I went ahead and installed the cartridge bb that I got when I bought the $5 box of parts. I already charged the bike $5 for a bb, based on the cost of the bb in the box, so I think it's okay to install the bb I actually paid for, without charging myself another $5.
With bb change, chain rubbed the outside of the front derailler, had to adjust slightly.
I will be riding to breakfast later, I hope the seat stays in place now.
#427
Quoted: 823 Post(s)
Liked 1,395 Times
Drive side as received
Harry is withholding approval
Harry says he thinks this bike is a dog that rolled in something that smells bad.
Then I wheeled it into the shop and started spraying Liquid Wrench onto the pedal threads, crank bolts, seatpost and stem. Hopefully it will sufficiently penetrate the threads and free them!
At this time the brakes are inoperable, probably a combination of cables corroded into housings and gunk built up in all pivot points. The chain currently carries an incredible amount of dirt, dried grease, hair and who knows what else, while the bottom bracket feels very sluggish and dry, like the original grease has collected dirt and rust and has solidified. The rear tire appears to be useable, but the jury is out on the front one - the inner tube holds air, but that skinny 23 mm Continental Sport acts like it doesn't want to stay seated correctly when I start to inflate it. I'll examine that more closely. There is a LOT of rust on the frame under the dirt, including a sizable part of the underside of the top tube - I'll try to remember to photograph it.
My current plan is to disassemble and thoroughly clean everything that is here and try to re-use as much of the bike's current fittings as I can. I suspect I'll have to replace the brake cables and housings, and perhaps the tires. The pedals and rear rim, if not rear wheel, appear to be replacements, but everything else appears to be stock. I'm going to do my best to clean and re-use that fabulous bar tape.
Perhaps some other time I can run a bike in full filth mode, but not this time - hazetguy will likely retain his lead in that category - but (1) I would like to continue living, and (2) out of respect for what has the potential to be a cool old bike, I will do my usual full teardown and rebuild regimen.
#428
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
Just kidding
rustystrings61 I would never run that bike as is...you are wise to clean up the scene of the grime. Bumblebeena was in much more decent condition but in my mind I wanted to spruce and safety her up...
besides, it will be enjoyable watching that thing blossom...
Harry looks like a fun cat...
#429
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I took the Takara out for a shake down ride this morning along a favorite "playing hookey from working at home" route, over to the Fanno Creek Trail and back. I was pleasantly surprised all around. The brakes were my biggest concern -- I'm still using the gray pads it had when I got it (just sanded down to get a softer surface) and I though someone here had a less than glowing report on them -- but after nervously creeping down the steep hill I live on, I found that they were actually pretty decent. The shifting was great. The handling gave me no reason to complain. The drivetrain was wonderfully quiet. Even the cheap 27" tires didn't feel too stiff. Don't get me wrong, this is not in the same class as my keeper bikes, but if this was the only bike I had, I would be happy to ride it. I'd even say I have two or three other bikes in my garage right now that aren't this nice.
The bike is so clean it glows. Or maybe I need to clean the lens on my camera phone.
Here's another pic of it on one of several bridges crossing Fanno Creek.
Today's distance: 23.6 kilometers
My Bikes
My Bikes
#430
Quoted: 1143 Post(s)
Liked 1,748 Times
@Mr. 66 "So riding high on French enthusiasm"
I have also experienced this effect while working on my French bikes. Could it be the side effect of a good CABERNET? Don
#431
Quoted: 823 Post(s)
Liked 1,395 Times
I've had those Dia-Compe G and 500 brakes on several bikes now, and they're much better than their reputation - then again, I weigh between 160 and 170, depending on the season and my saddle time ...
#432
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
#433
Bikes: Yes
Liked 3,868 Times
Well, I'm pushing 240 at the moment and don't have great grip strength, but I was able to get satisfactory braking from the hoods (which I can almost never say with single pivots) and great power from the drops.
My Bikes
My Bikes
#434
Bikes: Yes
Liked 3,868 Times
One other thing I meant to note from my ride today is that I had never noticed before that the reflectors on quill pedals without cages actually serve a practical purpose. I'm skeptical as to how visible the reflector is when I've got a shoe on the pedal, but what I noticed today is that the weight of the reflector causes the pedal to rotate into a position that makes it significantly more likely that I'll get my foot on the flat side of the pedal on the first try.
I don't know if this was an intended result, but it makes a big difference for me using these pedals without toe clips (which I despise). I installed SunTour quill pedals without a reflector on another bike earlier this year, and I was constantly frustrated with finding my foot on the side of the pedal where it's supported by the spindle and not the pedal frame.
My Bikes
My Bikes
#435
Quoted: 823 Post(s)
Liked 1,395 Times
Found that as I discovered that the pedals came off with no drama and both the stem and seat post move freely when properly loosened. So far so good!
#436
Edumacator
Liked 3,130 Times
Ha-haa I knew I couldn’t be the only one...except I got a gift from a few...
#437
Edumacator
Liked 3,130 Times
One of the sucky things about living in the Charleston area is that there are no country roads in certain parts of the area, and very few bike friendly roads either...some of the prettiest roads are death traps to ride. In order to get to decent and safely navigated roads, sometimes (especially from Goose Creek) I have to throw the bike on the car rack and drive out a ways.
#438
Quoted: 823 Post(s)
Liked 1,395 Times
The drive side crank came off, too, but it involved using a rubber mallet on the Park crank tool to start it to turning 'round. All went well, though, and I moved on to the left crank. Sorry b*$+@*& sheered the crank extractor threads right outa the crank. That crank is sho 'nuff seriously welded to the spindle. I thought about it overnight. This morning I pulled the rest of the parts off the bike while I let assorted chemicals do their thing. The brakes and derailleurs and shifters were easy enough, but what surprised me was how the rear brake cable housing had bonded to the top tube tunnels. In the end I wound up soaking the tunnels in Liquid Wrench while I did my morning ride (cut short by the rain), then used Vise Grips to grab the housing, cable and all and pull firmly. The last piece uncoiled the housing and THEN it finally popped free.
Once everything else was off, I studied the crank again. I tried threading in the 23 mm side of the Park tool, but no go. So I sighed and hauled out the ol' hacksaw and went to work. I made good headway, but I've about reached the point where I'll need to use a Dremel and a cutoff wheel to make the rest of the cuts, I think. Here is where we are now -
At least everything else (except the headset and BB!) came off without too much of an epic struggle. I have a Miche 170 left crank that I think will work for this, once I get everything cleaned and ready to reassemble.
It's okay, it's still fun.
#439
Edumacator
Liked 3,130 Times
you already went onto the hacksaw method, but I actually was able to free a crank from spindle by removing the cups...no small feat but with the drive side off was easier, then taking crank and spindle and soaking in evaporust, of all things, then slathering in WD 40...but I still hAd extractor threads...
I spoke too soon. The Centurion isn't coming along without a fight, after all. I foolishly didn't slather the crank/crank spindle interfaces with appropriate stuff, or maybe that wouldn't have mattered anyway. The crank fixing bolts both required use of the 3-foot length of pipe that in past Challenges has been used to support cranks and BBs while using a big honking' hammer to smack out cotters, and most memorably to straighten the head tube on an old Mercier. It worked beautifully for both crank bolts, and I should just turn to it FIRST.
#440
Quoted: 823 Post(s)
Liked 1,395 Times
#441
Liked 1,748 Times
No progress fo me on the Simplex front derailleur, I ran out to the local tractor and farm supply outlets to see if I could find a chain breaker bigger than bicycle's. I was crap out of luck, Simplex beats me again. Regreased and waiting for another round.
I do have a backup Suntou Vx that I could pop on the Peugeot, but I would feel dirty putting Japan on 72' France.
There was one method that I forgot to post. The Simplex shifters and the Deldrin winged nuts those were rusted and frozen. On the front lever I was able to pinch the plastic at the base with my finger and twist for removal, breaking the corrosion of the screw threads. On the other side it was not as simple, here I racked the grey cells of memory. I had the solution from 1982, the last time I tried the method. I grabbed my small crescent wrench, wrapped the walls with tape and then closed finger tight on the Deldrin and gave it a twist that did not stress the wings and and presto!
So I did not go for a ride on the Peugeot, but I did go out on a thirty mile ride on a non challenger World bike instead when I went out shopping for the tools.
#442
Edumacator
Liked 3,130 Times
#443
Liked 1,748 Times
A little polish and some pantograph detail.
The pedals and clips got some treatment of foil and rubbing compound. They came out good, they already rolled some from international service, the guts came apart looking like all was polished just dry.
A polish and panto for the rest. The details
And the money shot.
And the money shot.
Likes For Mr. 66:
#444
Quoted: 823 Post(s)
Liked 1,395 Times
Progress
Yesterday morning I remembered to charge the battery for the portable Dremel tool. Last night I spent a few minutes working with a skinny cutting bit to get closer in to the spindle. I then broke out a large cold chisel and a 2 lb hammer, took a deep breath, whacked - and the crank arm popped right off. Yay!
It takes a village (idiot) ....
After that I spent a few minutes cleaning the worst of the grime off the frameset with strip of an old sheet and Meguiar's cutting polish. There is a lot more rust than I initially thought, but I think all will be okay.
This morning I found I couldn't get the headset locknut to budge, so I liberally soaked it with Liquid Wrench - we'll see what that does for us. Then I attacked the BB. The cups are in good shape, the bearings acceptable, and the spindle will do for now, but there are some pits. I remind myself that this is the Clunker Challenge, and perhaps afterwards I'll pop in another spindle, or perhaps even a whole cartridge unit. It all went back together smoothly with fresh grease.
Finally, I remembered to take a photo for the great serial number collection -
1987 for the 1988 model year?
My side challenge - can I get this bike assembled and shaken down in time to take it with me on the family beach vacation next Saturday?
#445
Edumacator
Liked 3,130 Times
I vote that I have confidence it will be nice and crustily-ready for the beach trip! Which beach?
#446
Edumacator
Liked 3,130 Times
Do you paint pantos, then scrape the excess, or do the toothpick method?
And the money shot.
And the money shot.
#447
Liked 1,748 Times
#448
Liked 1,748 Times
Yesterday's ride 42 miles plus a 4 mile gravel hike
Bledsoe Vinyard
The northern most of the Blue Mountains
Saddle Mountain, I'll be hiking at the left side of photo riding up Cottonwood dr.
This was only about fifteen minutes after the shots with all the ☁️
Bledsoe Vinyard
Likes For Mr. 66:
#449
Liked 1,748 Times
About a mile in on the hike
Same spot as above, and a lot more uphill to go
And up more
More again, this is a private road to the peak. This is the first time I've seen the gate open. I did not proceed.
Pike's Peak rd. Going down
At the bottom
From the bottom of Pike's Peak rd
And the refueling spot
Likes For Mr. 66:
#450
Liked 1,748 Times
I dab the paint, then wipe immediately. If it dries I'll put a few drops of solvent on a cloth and wipe gingerly as to not dig into the engraved area. If it's been dry a couple of day I'll use 0000 steel wool to clean up.
