Why have a triple?
pan y agua
Quoted: 1461 Post(s)
Liked 737 Times
then get an 11. 50x11 is a higher gear than 53x12. yours is an argument for an 11 tooth cog, not against a compact.
You could get lost and die.
You could hit a tree and die.
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
I ride a Touring triple (26 - 36 - 48 tooth chainrings) with a 12 - 27 tooth 9 speed road cassette. It covers from 26 to 108 gear inches. There are 17 or 18 distinct gear combinations I can use, and they are relatively closely spaced.
The middle chainring is pretty good for most flat or flattish rides. Unless I am with a group that is really hammering along, I seldom need to use the big chainring unless I am going downhill. As for uphills, the smallest combination I have using the middle chainring is 36 gear inches, which is fine for most, though not all hills. I don't often use the small chainring, but I much appreciate it when I need it.
One other time I use all three chainrings is on rides with rolling hills, which, isn't one of my regular rides but something I do every now and again with a club. So I will need the small chainring on the uphill and as I crest the hill, will shift all the way up to the big ring to gain as much speed on the downhill to get some momentum on the next uphill. (helps me keep up with the faster club riders)
I could probably get close the same range with a compact double but switching now would be costly so I am keeping my triple for the forseeable future.
wears long socks
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
A double is a trade off. Not a huge one, but a trade off nonetheless.
wears long socks
Quoted: 5892 Post(s)
Liked 3,479 Times
Quoted: 9 Post(s)
I tow a trailer with my Synapse (compact double). And also tow with my MTB (triple).
While my MTB has a 3x7: I spend almost all of my time on the large ring. The only scenario that I can think of that forced me to drop down was taking the trailer offroad and going up a few rather steep hills. But gearing is completely different.
My Synapse (2x10): I like the double and riding solo I have no reason to want anything else but, every so often, I wish I could drop down "just one more gear" when towing the trailer up a steep hill. And there've been a few times that I wish I had "just one more gear" up to get a little more speed but I think some of that is my own pedalling speed not being there yet. I don't regret not getting the triple.
pan y agua
Liked 737 Times
Point taken. However, at those speeds you want really close gears, so I'd most likely have to remove one of the middle gears that I spend much more time in. Or I could probably remove the biggest cog, I'm rarely in that... even on big hills. Meh.
Take Corrado's example. With a compact setup, you'd run a 50/34, and an 11-30
To get the same low end gear with a typical triple of 52/39/30, you'd have to run an 11-28 to get the same low gear.
So the spacing is:
Triple: 11,12,13,14,15,17,19, 21, 23, 25, 28.
Compact: 11,12,13,14,15,17,19,21,24 27,30.
The spacing 11-21 is exactly the same. Above 21 you move 3 teeth on the largest 3 cogs, instead of two. And typically when you get down to the lowest gears the relief of a large jump can be welcome.
Liked 208 Times
wears long socks
Quoted: 138 Post(s)
Liked 16 Times
Because I use the middle ring most of the time. Big ring for downhill and the rare extended level road. Small ring for steeper ~7-12% uphill grades, even just half a mile.
Bikes: mid 1980s De Rosa SL, 1985 Tommasini Super Prestige all Campy SR, 1992 Paramount PDG Series 7, 1997 Lemond Zurich, 1998 Trek Y-foil, 2006 Schwinn Super Sport GS, 2006 Specialized Hardrock Sport
Quoted: 59 Post(s)
Ok, I'll bite.
Triples have traditionally been the best answer to cover a wide gear range, with close spacing in the steps between gears.
When bikes had 6 speed cassettes, a triple was a great answer to cover a wide range.
With the advent of more and more cogs on the back, compact cranksets with smaller rings, and 11 tooth rear cogs, the case for triples is becoming much more questionable.
With 6 cogs, and the smallest one being a 14, you just can't cover a range of say 122 gear inches to 32 gear inches, with a double crank, without huge gaps.
With 11 cogs, and a compact crank, no problem.
And BTW, 9 speed chains last noticeably longer than 11 speed chains, and the 9-speed drivetrain components are noticeably cheaper.
Bikes: Berthoud Randoneusse, Curt Goodrich steel road, Zanconato Minimax road, Jeff Lyon steel all road,
Quoted: 15 Post(s)
I almost dropped into my triple on a 10% climb after almost 40 miles today. I didn't quite have to, but it was close. I was fighting a pretty good head wind before the hill, so I just didn't quite have it all to climb. But i was still fighting the clock, so i wanted to keep my time up. That triple almost saved me from some pain, as it has saved me in the past.
I still want a "race" bike with a campy compact double 10 or 11 speed, but since i'm riding on older steel, and sometimes carrying a load, a triple 7speed or triple 9speed are nice to have for now.
Quoted: 18485 Post(s)
Liked 15,779 Times
Also relevant are grades. You can have a long day with a lot of total climbing miles but with relatively easy grades. That's a lot different than tackling steep grades. I was recently touring in South Dakota. One day I left my gear in camp and rode to Keystone. From there I made the two or so mile climb up to Mount Rushmore. Even with only a small stuff sack with rain gear bungeed to the rear rack I was struggling at times in my granny gear of 26x34. Why? Because there were stretches of double digit grades. While my touring bike with racks is a good deal heavier than my road bike, I think part of that climb would have been a struggle in the low gear of 34x28 that my road bike has, which is the lowest you can go with a DA 9000 regular rear derailleur.
pan y agua
Liked 737 Times
A 9x3 gear setup is still more versatile than 11x2. If you know how to design a triple, you basically design it like a conventional 9x2 setup, with the small chainring basically serving the purpose of giving you bailout gears. a front triple of 28-39-51 is going to shift easier than a 34-51, while giving you bailout gears that go to 16% lower than the double. The chain-line of a proper triple setup is also not an issue because you design it so that the chainline is optimized for the two bigger rings, and you don't care about cross-chaining the granny with the 3-4 smallest cogs on the cassette- as you are basically never going to use those gears. In a proper triple setup, you only need to use the granny chainring with the biggest 4-5 cogs on the cassette.
Fresh Garbage
Out here in Los Angeles some do. The city itself is full of rollibg Hills, some long and steep enough to defeat a lot of average risers. Going out for distance you can do centuries full of canyons and mountains. You can on road and off road, trails and fire roads. Getting out of the basin requires a 2000ft climb of varying steepness. Some people can muscle all of it on a fixed gear while others can't and need the gears.
triples are awesome--can climb in the 30 and roll in the 39 all day long without clumsy shifts and gaps in the meat of the range.
I've ridden the same Hill Country routes for >30 years.
The grades haven't eased any and the wind blows undiminished.
What was once doable on a 53/42 13x23 has become 50/34 12X25 and I can sense how this is going to go from here.
I dislike the fiddly shifting on compacts particularly in a paceline.
Next up is a triple 52/39/30 with a 10cog 12X25, good shifting and a bailout with nice tight ratios.
-Bandera
-Bandera
Interocitor Command
I have triples because that's what entry level road bikes (and mountain bikes) came with in 2003 - 2004. Three of my bikes are 9 speed from that time period. One is an 8 speed hybrid with a triple from 2010/11, which I will probably change over to a 9 speed this winter.
I live in a pretty flat area (Indianapolis) and never use the granny gear, except when I go to a local city park (Eagle Creek Park) that has a few hills. If I'm in decent condition I'll stay in the middle ring up front on those hills. Otherwise, I'll have to granny gear them.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12863 Post(s)
Liked 7,782 Times
I hated triples on road bikes for years and years. Also hated compacts. Had a triple on a 1988 Trek 400T briefly in the mid 90s, didn't care for it much, but then I was still happy climbing crazy hills with 42x23 low.
Then I just got too old and too slow for even 52/39, 11-28.
Got my Lemond with a 3x9, loved it. Decided 30x26 wasn't low enough, so swapped out the little ring to give me 52/42/26 x 11-25. I still have 52/39 x 13-27 on my Scapin but I won't pick that bike for anything that has much 5% + action on it.
Quoted: 59 Post(s)
The two wheels that I use interchangeably have 12-26 (SRAM) and 12-27 (Shimano) cassettes. These cassettes are identical for the 7 smallest cogs, and the 12-27 is 1 tooth larger on the two biggest cogs. These are basically are the biggest cassettes that the Shimano standard cage 9-speed derailleurs support.
I bought a BD bike that had a triple on it when I got back into some serious riding. I put something like a 12-23 (might have been a 13 and or 22).
I am getting old, 67, and the need for big gears is a pipe dream. While that narrow cluster is antithetical to most concepts of triple gearing, I could also find exactly the gear I wanted. very few double shifts.
for one reason or another, I have one bike with a 53/39 and 10 sp 14/28 and 11 speed 50/36 12/28. Both bikes have a gap at a sweet spot that bugs !-!ell out of me.
