Good wheel tension by Feel
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 228 Times
Here's a link to the "optimal" pitch.
The pitch varies with spoke diameter. Some wheels are being built with 1.8mm diameter spokes, where 2.0mm used to the standard. This means the pitch to tension chart needs a column for spoke diameter as well as length.
I don't agree that there's an optimal tension that's based solely on spoke length. Lateral movement is the most sensitive to tension differences. You want the same restorative force. That depends on the number of spokes and steepness of the angle due to dish. To build a 32 spoke wheel that's got the lateral strength 36 spoke wheel, means the spoke tension in the 32 spoke wheel has to be 12.5% higher than in the 36 spoke wheel. Similarly a rear wheel with 10 speed cassette will have a steeper dish than an old 5 speed freewheel. This means more tension for the 10 speed wheel. It also means a greater tension imbalance between driving and non-driving sides.
The final analysis is to pluck a properly built wheel with the same geometry and components and remember the note. You'll be able to write the book, with enough experience.
It was a nice rigida rim... even though the spokes were 2.0mm thick... besides, this chart doesn't mention if it valid for front wheels, DS or NDS rear wheels. I'm actually bulidng a 700c with 36 spokes clincher wheel with a 8sp hub...
I have no problem to evenly tension the wheels by plucking the, it's a nice method indeed
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 228 Times
I once tensioned an ACS Z Wheel by feel, the same as I did the aluminum rims before we got a tensionometer. It was perfect... then I went put the tire on. It wouldn't hold the tire bead because the tension was so great for that rim that it shrank the rim.
After you get a tensionometer (and they are only 30usd give or take) you won't build without them. And they will teach you more about good vs bad rims than you ever knew existed.
I true my own wheels by the pitch when the spoke is plucked just as indicated in the link by SBinNYC, (post17). To get the pitch right I have an inexpensive pitch pipe such as a music teacher may use. This is a fairly objective method far better than squeezing spokes. A highly regarded source of all sorts of information is the web site of Sheldon Brown, a bike mechanic, now deceased and missed. The recommended pitch of plucked spokes is from his former web site. That site with a wealth in bike information can be found here. https://www.bikeforums.net/bicycle-m...shortcuts.html
Likes For holytrousers:
Quoted: 7359 Post(s)
Liked 2,502 Times
I have nothing against tensiometers. It's just that I haven't used one yet.
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 228 Times
BTW, i wanted to thank you for that tip with the thumbnail it's much more reliable than checking by sight and less expensive than sheldon brown's method with filing a screwdriver's head..
As mandolin guitar player I used plucked tone & compared with other well built wheels.
Have wheels I built in the 70's, that are still fine..
Of course dished rear wheels pull the hub to the left from a tension balance differential..
Quoted: 2614 Post(s)
Liked 1,960 Times
Rear drive side spokes and front spokes are tuned per the chart (assuming you're using rim brakes, I'm not sure what you do with discs). Non-drive rear spokes are as tight as they can be while keeping the rim centered; they're usually substantially lower tension.
the front disc hub wheel I built used same length spokes , but the disc side is dished .. a little tighter .
axle ends and rim symmetrical..
Quoted: 663 Post(s)
Liked 496 Times
For the rear wheel, the drive side spokes are tensioned as per recommendation, then the non-drive side spokes are tensioned only as much as necessary to maintain a straight rim. I just slowly bring everything up to tension, a bit on the drive side and a bit on non-drive and repeat this until desired tension is reached. Good luck.
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 228 Times
but i managed to tension NDS spokes up to the point where plucking them gives a clear tone.
i hope that means they are tight enough. maybe that was my mistake on previous builds because i remember NDS spokes made a dull sound.
Quoted: 3352 Post(s)
Liked 1,056 Times
To do ANY job right use the proper tools. If you are building a wheel you need a truing stand and an tension meter.
As an aside to this I worked in the computer industry, and had to go out COUNTLESS times because the other techs were NOT using the proper tool for the job.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 187 Times
i am a jazz guitarist and repair guitars. I could tension a wheel by ear completely but I use a Park Tension meter. It works well and it also tells me my ear is still very good. The pitch of the DS and NDS are different but they all should be close. I would have to say the a 16 or 20 spoke rim is a bit more work and I have only done a 20 radial front. Lower spoke count you want more confident numbers.
Likes For deacon mark:
Quoted: 140 Post(s)
Liked 72 Times
i've tried that method, but each time i finish a tensioning round the wheel gets out of true, so i keep repeating that process until the spokes become really tight. I haven't noticed that special moment where the wheel becomes particularly deformed. am i doing something wrong
em
Quoted: 140 Post(s)
Liked 72 Times
I always measure tension. Most of my wheels have been 10 speed rears with 28 or fewer spokes. There really isn't much margin for error in a wheel like that. There's just not much difference between too loose to prevent the nipple from unscrewing and tight enough to break the rim. Keeping a record of the tension also assures me that my wheels are stable.
em
em
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 228 Times
You're not doing anything wrong. Jobst preferred wheels that were common 50 years ago, with 36 spokes and very light rims. You could barely get enough tension in all those spokes before the rim deformed. With modern heavier deep section rims with fewer spokes, the nipples are more likely to pull out than the rim is to deform. Jobst's method is obsolete.
But how do you explain then the same method in Musson's book?
I have aluminum 36hole rims, with a square profile, and they didn't taco that much.
In the end i guess tension is not that fussy, it has to be just tight and my previous builds' mistakes might have been loose NDS or uneven tensioning. Musson says the cracks appear because of overinflated tires and spokes fail because of loose tensioning, which could happen when spokes are not evenly tensioned..
This would be to much tension 😉
I fall into the camp that thinks if you're building a wheel for money you absolutely should be using a tensiometer to set a reasonably precise average tension. That said, with the relatively wide range of reasonably performing tension values on a conventionally spoked wheel, Musson's general advise to tension until the (appropriately lubricated) nipples become somewhat difficult to turn will probably put you in the ballpark. Do absolutely use plucked spoke tone to make sure that tension is even, however--if you just true to a reasonable dimensional tolerance you can end up with pretty wildly uneven tension. Aside from that, a tensiometer is the only reasonable way to be precise about absolute tension.
Off grid off road
So my question is : How would you describe the feel of a wheel when it's properly tensioned ? What's the general idea describing a well tensioned wheel ? What signs tell you the wheel is just fine ?[/QUOTE]
I find that simply squeezing two neighbouring spokes together on various new/maintained wheels gives me a good idea of the tension required. It really comes down to feel and methodical perseverance to true and tension a wheel by ‘instinct’.
There is little doubt that with the correct components one can build a good wheel successfully every time.
I am somewhat oldskool so please do not flame me!
Quoted: 2529 Post(s)
Liked 3,014 Times
The easiest way to reduce the likelihood of rim damage from excessive spoke tension is to use thin butted spokes. DT used to (and might still) refer to 2.0 straight-gauge spokes as "tandem" spokes, meant for use with robust rims only. If there's a downside to the use of thin butted spokes, I haven't yet encountered it.
Best practice: use moderately light butted spokes for front wheels and on the drive side of rear wheels and very light butted spokes for the non-drive side.
Likes For Trakhak:
Quoted: 140 Post(s)
Liked 72 Times
The rim is definitely the limiting factor for spoke tension. TOo much tension and either the rim will fold in comression or the spokes will pull oout of the rim. Unfortunately, rim manufacturers never publish maximum tension specifications.
Back in the day we used to 36 spoke wheels with very light rimes and very light spokes. Quality control then wasn't what it is now, so we broke a lot of spokes, which we usually replaced with 2mm straight gauge. The straight gauge spoke couldn't be tensioned enough to prevent the nipple from unscrewing, so the wheel became unstable. Modern wheels are way better.
em
em
I've built a few wheels, maybe a couple of dozen over the years, 'cutting my teen's with Jobt's book about 35 - 40 years ago. Just rebuilt one on Monday to replace a front wheel on our tandem that I crushed in a pothole the day before.
I have built them exclusively by 'feel' and have never had a problem. Rarely even having to re-true after riding. Now, does that mean I'm some kind of expert or a wheel building artist? Nope.
I think it means that as long as all the spokes are 'reasonably' tensioned, that you follow good wheel building technique, and the wheel is de-stressed and true, that there is a fairly wide range of builds that will result in an acceptable wheel that will last for years.
Under tensioning spokes is the killer of wheels. Better to make the spokes a 1/2 turn too tight than a 1/2 turn too loose.
Having had good success 'by feel' doesn't mean that I would not use a spoke tension meter. I'm just sort of cheap and didn't want to spend $90+ for one. But seeing one on Amazon for $30, that excuse is now gone. It may not be as accurate as the Park tool for showing actual tension, but as long it can consistently show 'relative' tension, that's good enough for me.
Building a wheel by feel does involve a certain amount of plucking to listen to the tone of each spoke (again, for relative tension). I was interested in seeing Sheldon's table of notes for various spoke lengths and gauges. I don't think that table takes into account how the wheel is built, (2X or 3X, etc., which is essentially like fretting a guitar string). I would love to see an app developed that you could input all the relevant data and come up with a frequency that you could check with your phone.
With a mighty wind
Quoted: 1111 Post(s)
Liked 906 Times
It has been a while since I said I'd get back to y'all. Been busy.
Anyway, I've checking of and correcting my builds with the tension meter.
In some cases, I nearly got it perfect. In other cases, I was way off.
You can't use the times I was nearly perfect as an example, since the wheels were just as straight and I couldn't really tell they were evenly tensioned or not.
So this is definitely an argument for using a tension meter. It's a little tedious though.
So yeah, if I was in the middle of nowhere with few resources, I still feel like I could build a great wheel with just the frame and spoke wrench. However, I definitely feel better about my wheels after this project. I really haven't noticed any difference in ride quality.
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
In a similar vein, when gyroscope-driven artificial horizons and turn-and-bank indicators were introduced for aircraft, seasoned pilots insisted that the instruments must be faulty because they showed the airplane turning or flying upside down every time they flew into clouds...
Quoted: 297 Post(s)
Liked 245 Times
My built I used 2 mm straight , because I had to buy 90 of them 40 f, 48 r & a spare or 2..
