Blasphemy?
#51
Quoted: 2588 Post(s)
Liked 4,826 Times
^ You may hate me in a minute, after your "Rules" post on Rootboy's PX-10 dropout hanger thread
Okay, got the frame back from my LBS (that would NOT be the LBS that almost caused me a heart attack with the Everest alloy freewheel debacle) and now have the new Chorus headset in.
When I picked it up, Darcy (head mechanic and wheel-building Jedi-warrior to boot) told me she had to add in a second compression washer because - you guessed it - the steerer tube was about 3/32" too tall. So, there was a gap of that dimension between the top cup and the locknut. Looked dopey - but I told her I could "fix" that. She agreed once I was done with my fix, she'd re-tighten everything back up for me for free.
So, once I got home - out came my trusty Dremel and I went to work. It was short work to run a reinforced cutting wheel around the area which I marked, then a quick and clean file to the top of the threading. Clean, and I eyeballed it just right - the top nut snugs right down on the original washer and all is flush as it was meant to be:
BTW, those are Robbie's Campy cable adjuster stops and one of Shnibop's Chorus brake calipers - note I have updated the pads for more progressive stopping power.
Now, before anyone labels me a Drew, you should know I did this little bit of surgery after ensuring that I could still install a Super Record headset if I so choose at a later date to set her up in vintage clothing. There was actually closer to 1/8" clearance between the top of the steerer and the point where the threading ended on the SR locknut on the original setup, so I still have room to play with
Here's a shot with the current parts - this angle almost makes it look like a TT frame:
That's it for now. Think I'm going to take a day off tomorrow...
DD
DD
Last edited by Drillium Dude; 12-30-11 at 09:32 PM. Reason: Referenced wrong thread
#52
十人十色
#53
Liked 4,826 Times
^ Oops - that would be Rootboy's thread on the PX-10 dropout/Campy NR rear derailleur solution thread
It may have only been 3/32" but I sorta broke your Rule #1 by modding the fork steerer.
DD
DD
#54
十人十色
#55
Quoted: 556 Post(s)
Liked 132 Times
Nice DREW on that head tube D. Dude Seriously, looks great so far. The job on those lever bodies, which look so alien and space age to this old fart, is outstanding.
Great work. Can't wait to see this build. Yet another of D.Dudes fantastic orange bikes.
#56
Quoted: 821 Post(s)
Liked 256 Times
Jeff, your work is top notch and highly entertaining.
Lots of talent!
I would have to think you would do some knock out work as a frame builder.
Your attention to detail/knowledge base could produce some outstanding results down the road.
Just a thought.
#57
Bikes: 07 Vanilla, 98 IRD road frame built up with 25th Ann DA, Surly cross check with 105 comp, 78 Raleigh Comp GS, 85 Centurionelli
Quoted: 87 Post(s)
Liked 923 Times
"Your attention to detail/knowledge base could produce some outstanding results down the road."
Hell yeah it would. Maybe we should start a "send DD to Framebuilder's School" donation thread.
#58
Liked 4,826 Times
And from what I've read over the past few days, orange seems to be the new red.
DD
#59
Liked 4,826 Times
I have thought about doing a frame at some point in my life, however, I know nothing about the technique of brazing. I suppose I could do all the lugs/BB shell and whatnot and then have somebody more experienced braze it up, but that would defeat the purpose. Maybe someday...
This will be the perfect weapon for our ride(s) this summer in MN. It'll be available for test rides for that week or so in early July.
DD
#60
Liked 4,826 Times
Credit the Navy for instilling the "attention to detail" in me. From day one (20 June, 1988) that was drilled into us day in, day out. I always knew it would pay off
Thanks to everyone for the nice comments and helpful information so far, and a Happy New Year to you all!
DD
#61
Liked 4,826 Times
Seatpost has now been nailed down - this will be sporting a 27.2mm Record Ti soon
My last bike-related purchase of 2011 turns out to be the most modern bike component I have ever procured.
BB, cable set, 8-speed chain and Chorus front derailleur are all that remain to be found.
DD
DD
#63
Liked 4,826 Times
Heck, do they even make tubular rims for modern stuff? If so, that illustrates how far behind I've been lagging technologically.
Nah, I'm going to build up a special set of wheels for the Colnago Super and put them on that. I'm taking a pair of grey-anodized GP-4s and stripping the ano off, then polishing them up before lacing them to a high flange NR hubset. Should look really sexy when complete
DD
DD
#64
Bikes: 79-80 derosa 80 merckx 89 peugeot dolomites 93 bianchi tsx
Quoted: 7 Post(s)
don't know what as means either but <AS> appears on most rings I have seen from the c-record era. I Ihave seen 53/39 combos typical for 8 spd on early 90-91 chorus cranks w/o pins and have have a slightly later (mid 90's campy crankset ) that does have pins in the rings so possible a ltr development.
#65
Quoted: 7 Post(s)
english or italian threaded bb ...braze on for the fd...? ihave a chorus fd nos but it's clamp on....
DD
DD
#66
Liked 4,826 Times
English threaded 68mm width, 102mm spindle as per RobbieTunes. My research was coming up with the same answer. The derailleur would be a braze-on type.
That "AS" marking really has me puzzled - there has to be a reason for that to be stamped on the chainrings.
Anybody have an idea?
Oh, and for all of you wanting to see more drillium: I've relented and I will be doing some bit of drilling on the brake levers and have something interesting in the pipeline for the brake calipers, too. Stay tuned...
DD
DD
#68
Liked 4,826 Times
^ I'll do that. Shnibop and I were discussing how to get polished alloy rims without paying through the nose on Ebay and came up with this as a possible solution. He actually stripped/buffed a section (and is finishing off the whole thing) of a dull-silver anodized Mavic rim and it turned out great. But perhaps the grey might be a bit tougher?
Ah, time to find out - I can't shy away from a challenge
At least my rims are separated from the hubs and spokes!
DD
DD
#69
Quoted: 83 Post(s)
Liked 13 Times
DD
DD
#70
is just a real cool dude
Quoted: 32 Post(s)
Liked 34 Times
They still do make modern tubulars. I just got out bid on some Rolf tubulars I was going to get for my Colnago Mix. A good portion of modern carbon wheels are tubular. I have my eyes on another set of tubulars currently on eBay with tires for dirt cheap with a Campy freehub.
#71
Quoted: 378 Post(s)
Liked 1,410 Times
DD
DD
Ceramic bearings, DT Swiss double-butted spokes, Ambrosio Crono (Durex) rims.
Hope Tech hubs. I traded a bike for them, and I think the deal was fair.
The only real deal I've seen as far as removing anodizing is a product sold to auto body shops.
It's generally in the same catalog as the media-blasting equipment, I think the mfg is "Watson's"
The instructions have to be followed explicitly, but it's not as corrosive as EZ-Off.
#72
Liked 4,826 Times
^ Or try Jestco Products anodizing remover - that's what I've been using the past three years and I'll never go back to the mess and cost of Easy Off. Jestco's hands-down the best thing I've EVER used for removing anodizing.
DD
DD
#73
I should clear a few things up...
I guess I wasn't totally clear with DD and my pictures add to the confusion.
I stripped a section on a Mavic GL330 and polished it up in about a minute.
GL330's start out as the typical dark grey you would see on any Mavic rim from that era, not silver as DD understood.
The rim soaked in Jestco for about 5 minutes, I rinsed/sponged it off with soap and water, then ran it over the buffing wheel for a minute for the results seen below.
IMG_2379 by shnibop, on Flickr
IMG_2378 by shnibop, on Flickr
Only the area between the spokes on either side of the valve hole was polished. The dull silver is what is left behind after stripping the dark grey ano.
In the end it will be somewhat of a pain the butt but I'm saving the cost of new spokes and the time to build a wheelset from scratch.
The results are quite impressive, especially considering the effort involved. DD should have no problems with his GP4's unless they're anodized in something completely different.
#74
十人十色
One thing, though, and this is only something I was told by my old LBS guy, Mr Sugiyama. I don't care for anodised finishes and I mentioned to him that I was thinking of stripping it off a pair of 27" rims I had. He reckoned it was a bad idea because with rims it added to their strength and figured in the makers' calculations. So I dropped the idea. I would love it not to be so but...
#75
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
That IS impressive. I use a Japanese product called 'Pipe-man' but that 'Jestco Products anodizing remover' seems much more effective.
