Show your French bikes!
#3126
Quoted: 35 Post(s)
Liked 54 Times
I am assuming the Gitane has cottered cranks.
In the USA we call these conical bolts Cotter pins. The French were notorious for using at least two, maybe three slightly different shapes.
If they pass through the crank arm, then to finish the job you need a bench mounted vise and a flat file and a steady hand.
Very common back in the day to need to file them to fit.
The trick is that both need to be filed back the Same amount.
Back from a time where mechanics really were mechanics.
Thanks for learning me some vocabular in english !
These pins are original (9mm), because I could remove them pretty easily. They fit the crank arm well, but the new axle must be a little different (height of the flat contact surface on the axle itself)
As you say, i probably need to adjust them.
#3127
Quoted: 35 Post(s)
Liked 54 Times
I could finally managed to mount my crankset after some adjustment (and some hours work) on 2 new conical pins.
Thanks for the precious advices.
But now, I am struglling with the mafac brakes.
I have two problems.
First, I don't have Mafac racers but normal Mafac brakes like that. I have a lot of difficulties to set them up , just because I probably need about 6 or 8 hands, and i don't have only two !
I could not managed until know to mount and pull the brake cable properly, and I really have no idea how to do that. (I follow park tool tutorial but it is all but not that simple).
And not speaking of adjusting an acceptable toe for the pad .
My second problem is that I think that I don't have original mafac cartridge (or they have been cutted for any reasons because they are short), so i am not very keen of spending 30€ on mafac pads if i am not sure they will fit.
Plus my metal cartridge are short and i doubt oabout the braking power.
I currently have purchased basic pads with metal cartridge, about 40 mm long just to check if it works, but they are not very qualitative and optimal in my opinion.
(as i said, I could not manage to mount the brake properly with them until now.
I wanted to know if the original Mafac pads + cartridge can easily replaced by something more "modern" compatible with my mounting system which seems not as easy as mafac racer to set up.
https://www.ultimebike.com/porte-pat...x4-bbs-02.html
https://www.ultimebike.com/porte-pat...re-argent.html
https://www.ultimebike.com/patins-st...r-bbs-01d.html
and maybe something with toe setting (why not maybe Vbrake type pad after all ?)
Sorry for having so much questions which seems maybe basic to a lot of you.
#3128
Quoted: 35 Post(s)
Liked 54 Times
I have to correct myself.
My brakes pads are probably original "short".
My brakes seems to be exactly the same as these ones , and I probably could mount Mafac replacement pads (I would have to cut them to fit the length)
Mafac S
That said my initial question remains , any good replacement "modern" pad for that.
Velosepia: Vintage Mafac « S » front & rear brake set
Mafac S
#3129
Quoted: 804 Post(s)
Liked 2,986 Times
meta6 MTB/
commencal/
#3130
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
^^^ Ok, I get that it is French (actually Andorran), and that MTB’s become “old” very quickly, but you do realize that this is a Classic and Vintage forum, right?
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#3131
Barred @ Velocipedesalon
Simplex FD
Unfortunately, I came to this thread late, but I do have a couple of those "Delrin" body derailleurs. No cracks or obvious signs of deterioration. That FD was on my first new bike I bought, 1980 Peugeot. I actually (at the time) thought it was a decent derailleur for the bike/price; and an easy low cost upgrade if needed to change. I see you ordered a Sun Tour FD, but if you want one (I'm using one on a Gudereit rebuild for a friend, he wanted OE parts) I'd be happy to donate. I haven't gotten to that parts bin for a photo; but if you need a pic, I'll add it to the thread. They both have been cleaned/rebuilt and are ready for use.
#3132
Quoted: 35 Post(s)
Liked 54 Times
Many thanks for your kind offer but the bike is finished now, with the suntour front derailleur.
As i am not looking for 100% original, (my bike has been built around a brand new frame by my father ), I think it is not a bad solution to have opted for this simple but all metal construction suntour.
It should be reliable for the future
It is from the same period, and it works really well.
Of course I will put pictures, but we have here in france continuous rain for about one week and I could not even give a try at the bike until now !
today the weather is better, I will take some pictures after work .
#3133
Quoted: 3814 Post(s)
Liked 3,345 Times
Some pictures of the mercier I picked up yesterday .
I should make a nice bike for my son (wife).
it needs some cleaning and work, but it should be okay.
It is a 1977 model , Mercier 100 or maybe 200 or ??
Normandy hubs
Mavic "Championnat du monde"
Mafac racer brakes,
Tubes allegé pro (?)
Stronglight TS crankset
simplex shifters and dérailleurs.
Belleri stem and handlebar
crankset
Normandy hubs
Mafac racer brakes,
crankset
Thanks very much for sharing this find!
Do you consider the Japanese pedals to be original?
They seem slightly odd on a cycle which is otherwise all French.
#3134
Quoted: 35 Post(s)
Liked 54 Times
I have absolutely no idea if the bike is all original or not .
But japanese pedals on french bike of this period are possible. (I may be wrong of course)
There is for sure a specialist around which could give some more precision on that.
at least, these pedals are from the 70's, which is period correct with the bike
Likes For Manu431:
#3135
Quoted: 35 Post(s)
Liked 54 Times
Hi everybody.
My Gitane bike is now ready for the road.
As I already said, this is a bike I got when I was a young boy, for a Christmas present.
It has been built by my father based on a brand new purchased frame and parts. Some other parts are parts which were available at my father's house.
For me , at that time, It was just a fantastic bike and it has made no difference if it was a "catalog" model or not.
I am happy the he choose it a little big at that time, because now I has the good size for me (size 54)
The bike stayed about 25 years at my father's house before I bring it back home during last Christmas holidays.
I decided to disassemble and clean it completely, polish alu part, ......
I had to change the crank axle, which was about dead.
(The road was not totally dry yesterday, and of course the frame and wheels are not as good as they could be for the pictures , but I could not resist to give it a try )
I could only make a short ride yesterday evening, but so far I could check the bike works perfectly. Of course I will have probably to fine tune some details, but nothing serious.
Some pictures ( I am absolutely no good at taking photos)
#3136
Quoted: 3464 Post(s)
Liked 2,831 Times
Cotters look like they fit, good choice on front derailleur. Exercise it on fair weather days and smile.
Likes For repechage:
#3137
Quoted: 35 Post(s)
Liked 54 Times
https://forum.tontonvelo.com/viewtopic.php?f=8&t=30688
The bike is about a Mercier SALEVE model, and probably not a serie 100 - 200 which are older.
Nothing is 100% sure, but it should be pretty close .
At the end en the 70's, the Mercier bike were designed by the name of famous french mountain pass
Regarding the pedals, they are probably original, based on another information ,again on a french forum (I am a new member there too ; great information there)
Kyokuto top run pedals have been present on Mercier SALEVE models, like this one
MERCIER rose modèle SALEVE 1977 /1978
Likes For Manu431:
#3138
Liked 3,345 Times
I found this Mercier 1977 catalog on a french forum
Thanks so much for this information! Greatly appreciated.
Here is the U.S. we seem to be the most familiar with the Mercier models of the early 1970's "boom."
#3139
More: 50 years later, another Mercier
#3142
Bikes: '01 Klein Quantum, '91 GT Zaskar, '70s Di Lorenzo, '74 Gitane Champion du Monde, '50s Steyr Klunker, Cannondale Singlespeed
Quoted: 18 Post(s)
Liked 21 Times
Yes, that PX10 is superbe. I've always lusted after one of the Nervex lug ones
#3143
I am indeed a specialist. Specifically, a specialist in asking questions, and trying to learn about Mercier bikes from people with actual knowledge. Hopefully with more dialog among all of us, and through examining the history and evidence I'm trying to dig up, we can pin down more details about these bikes. Please add your photos, info, and questions to my Mercier thread! We need all the help we can get. 50 years later, another Mercier
#3144
Quoted: 1106 Post(s)
Liked 1,328 Times
Interesting is the fact that the Weinmann center pulls combined with the Mafac levers produces excellent braking, to the point where frankly I am noi terribly interested in finding some period Mafacs to match, I might even keep on the lookout for some period correct Weinmanns - and besides, mixing and matching as well as upgrading was and is a common practice.
#3145
Liked 1,328 Times
The French sure liked their downtube pump pegs, didn't they! I have them on my current UO-8 and they were on the UO-8 I had as a teenager. On the latter I remember I had a "Number One Pump" to fit the pegs: it was a clear plastic pump which seemed pretty neat at the time.
#3146
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
What I do remember is they broke easily. The handle pulled off mine after maybe two uses. Neat idea poorly executed.
It wasn't French though.
Real cyclists use toe clips.
jimmuller
jimmuller
#3147
So it goes.
Bikes: A few. Quite a few.
Quoted: 432 Post(s)
Liked 639 Times
#3148
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Not mine. Gitane Interclub for sale on FB right now.
Likes For BFisher:
#3150
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
BFisher-
Lovely bikes, those Grand Sprints. Had one identical to the photo but without the dog.
