LHT, Sloping Terrain and Inclined Surfaces
#51
Mad bike riding scientist
Quoted: 6243 Post(s)
Liked 4,260 Times
Thanks. I just checked and didn't even realize it has a Tiagra FD. (The RD is a Deore XT.) I think the guy at the shop said the Shimano's specs say it shouldn't work with a 24t small ring. My thought was to try it and see before spending money on a new FD. I have several bulging disks so t would be nice to have something a bit lower for the really steep stuff.
Stuart Black
Stuart Black
#52
Liked 4,260 Times
Another feature of Feeken's page is that you can share it as a link so that other people can see what gearing you are using.
Stuart Black
Stuart Black
#53
jonc123, I love gearing threads. Changing the granny chain ring is the first step and while it isn't a great difference, it maybe all that you'll need. If it isn't, it's time to look at the cassette (and possibly the chain). A bit OT, but saddle time is the best teacher, both mentally and physically, to help you as a climber.
I think that of all of my roadies and mountain bikes I've ever had, I've fiddled with my touring bikes the most when it comes to fit and gearing. It all comes down to the fact that one maybe in the saddle for +5 hrs. day after day while facing unknown road conditions along with variable degrees of rider fitness.
Brad
Brad
#54
gear calculator dot com
feeken
feeken
am writing this to remember it, it certainly is a neat graph.
feeken
feeken
#55
when I bought a 26 from them, and then saw that the ring was slightly too much inboard on the crank, I tried putting some household washers as shims, and it moved it out just the right amount. Later did the same thing to a friends bike with a 26, but the thing here is that the bike store people really didnt want to commit to it as an idea, so it very much is true that you have to try things and not just listen to what is told you.
The tricky part is when people don't have the experience doing mechanical things, and take at face value being told "you cant do that" (which is completely understandable though, I mean they are the bike shop people, they should know bikes....).
#56
Quoted: 1185 Post(s)
Liked 842 Times
I am also a fan of the Tiagra 4503 FD. We run 9 speed systems on all our touring bikes, and they are reliable, flexible, and hard to find anymore. I've actually picked up a couple of new ones on ebay that I keep for replacements. However, they may stay in the parts bin for a long time.
This is a Tiagra 4503 FD with a Sugino 44/32/22 crankset and 11/34 cassette; it works perfectly, and with STI shifters. However, I'll bet if you asked a bike shop about it they would say "no".
#57
Quoted: 760 Post(s)
Does anyone use 2 different cassettes? For example riding in mountains where you will use super low gears. vs. rails -to- trails where you won't get any hills at all. Or is that where the triple comes in? Sometimes ignore the small chainring.
#58
I guess you'd have narrower Q-factor and a spare cassette, but it sounds very annoying compared with just running a triple and having reasonable spacing over the entire range, and being able to access different ranges with just a front shift.
#61
Quoted: 18483 Post(s)
Liked 15,778 Times
I see no point in having two cassettes (and two chains). Just don't use the gears you don't need. I actually tour and tour in mountainous areas and in flat areas. When I head to South Jersey to a spot I like I may use the middle chain ring on a couple of the hills that come early in the route. Other than that, I use the large ring and that's that. BTW...Not all rail trails are created equal. Go ride the Mickelson Trail in SD. There is one 4 mile stretch that, according to RWGPS, gains 628' in elevation. Not exactly flat, and it's gravel/sandy. Toss in a headwind and it made for a tough stretch. The trail has several other noticeable grades made more difficult than they appear on paper due to trail surface.
#62
Brad
#63
Ozark Hillbilly
Bikes: Long Haul Trucker
Quoted: 136 Post(s)
Brad
Brad
I stopped at the LBS today and ordered a 11-34 cassette and the 24t granny gear. I can always go back to my other cassette if I don't like the spacing but something tells me I WILL like it lots! My previous 2 wheeler was a Trek hybrid which i did put racks and bags on and went on some trips with, including the Katy Trail. I knew what I wanted this time and have fixed the things that bothered me on the other bike namely having front and rear quality racks with *waterproof bags*, a nice seat and dropbars in the proper position for me (and not the guy or gal at the LBS).
I hope to continue the process of changing things out as I go along, I like new things that work. Especially new cassettes and sprockets that will help me get from poingt A to point B. One of the bike shop employees and I were discussing bikes going to 2X11-Speed. If what he told me was correct, you can get a pretty wide gear range with that easily. Sounded pretty interesting to me.
#64
Bikes: Surly LHT 26in 52cm 2008
I put a 24 small ring on my daughter's 5-bolt stock crankset on her LHT without any problems. I think it was an Andel crank. I have since replaced it with a 44/32/22 crank, which she thanks me for quite often The Tiagra FD works very well with all these combinations. The only caution is there needs to be >10 tooth difference between the large chainring and the middle ring. This should not be an issue with what you are planning.
This is a Tiagra 4503 FD with a Sugino 44/32/22 crankset and 11/34 cassette; it work perfectly. However, I'll be if you asked a bike shop about it they would say "no".
I am using 22-32-42t Deore Crank and XT FD
#65
Ozark Hillbilly
Quoted: 136 Post(s)
You got your bike yet?
#67
Liked 4,260 Times
By the way, for the towpaths, I spent most of my time in the high range of my crankset. I do that most of the time on most of my bikes. I still like having a good low gear, however.
Stuart Black
Stuart Black
#68
Ozark Hillbilly
Quoted: 136 Post(s)
Well, looks like I goofed up. Surly says the stock LHT comes with 11-32. I just took the wheel off the bike to check, looks like it has 11-36 on it. I have learned something today.
With the 24t front I should have a nice low of 16.6 inches. I did notice some play in the cassette (freehub). I'll ask them about that. I put the wheel back on the bike and it seems locked in when putting pressure on the pedal. Anything to worry about? I noticed slight play before, it seems worse now.
I am ordering the 24t chainring from Rivendell, LBS did not have a source. Since I have it ordered, might as well install it. I just wanted one lower gear to begin with, looks like I'll get that!
#69
Enjoy the lower gearing.
#70
Ozark Hillbilly
Quoted: 136 Post(s)
My wife bought a new LHT also at the same time, it has 11-36 on it also. Three biggest rings are 28, 32 and 36.
I sent Surly an E-mail about it; I E-mailed them once before and got a quick response.
Both these bikes were purchased last fall, special ordered from QBP, the LBS did not have them in stock.
****EDIT UPDATE***
I looked at the Disc Trucker on Surly's website and it does say 11-36 on it.
Disc Trucker | Bikes | Surly Bikes
Also, the 2016 catalog has 11-36 listed for all the sizes of LHT.
https://surlybikes.com//uploads/downl...LY_Catalog.pdf
#71
Quoted: 760 Post(s)
So is changing out a cassette a big deal? I never have. But when racing on 5 speed free wheels it was common to own several freewheels and different pairs of wheels, change according to terrain and road surface, tires also. Why not for touring?
#72
Liked 842 Times
Sorry Brad. Somehow, I missed your post. I didn't scroll down until after I posted. You are correct.
#73
Bikes: Surly Disc Trucker, Trek Madone 4.7
I counted twice; then I got smart and put my glasses on and saw 36t on it.
****EDIT UPDATE***
****EDIT UPDATE***
#74
Liked 4,260 Times
On the road you have to carry a chain whip, a cassette lockring tool and a large adjustable wrench. And, of course, a cassette. That's a lot of extra weight to carry around on tour. You could, of course, carry extra wheels but where are you going to put them?
You are also comparing cheese to chalk when you try to compare racing to touring. Racing is something that you do near home or at least near somewhere where you can get support easily. If you want to have someone follow you around in a support vehicle while on tour, I suppose you could carry all the stuff to change gearing for every hill you come across. But even racers don't use that kind of support anymore.
But touring is usually more self-supported. If I want something while I tour, I have to carry it. Having a single gearing system that covers a wide range of terrain is better than having several gearing systems to cover the same terrain. And, as I showed with the maps above, terrain changes from hour to hour and sometimes from minute to minute. It's just not practical to stop and change the wheel or cassette whenever a hill appears or disappears in front of me.
Stuart Black
Stuart Black
#75
After aggravating an old knee injury I began using a triple. This pretty much ended the need to swap cassettes as long as a good initial choice was made. With my road bikes and touring bikes, I do treat the triple crank sets as doubles with a bail out ring. The mountain bike? Not so much as in 100 yds. I may use all three chain rings.
Brad
