I only ever ride my $200 Giant mtn. bike to get somewhere. Not today!
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
This sounds like an issue with your bike’s sperm tube angle.
Likes For Kapusta:
Likes For Milton Keynes:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Quoted: 1084 Post(s)
Liked 687 Times
Sometimes it's just the opposite. With the saddle tilted nose-down, you slide forward putting even more pressure on the perineum. It sounds counterintuitive but sometimes the way to relieve pressure on the perineum is to tilt the saddle back. It's not uncommon to have the nose slightly higher than the back.
Quoted: 1218 Post(s)
Liked 298 Times
You really want the seat to be be mostly flat.
Having ridden that saddle before..... try a new seat! I hated that seat.
As for your latest question that one bolt ( it will be like a 5 or 6 mm allen) above the reflector. Losen it to adjust your saddle front to rear, and also to tilt saddle down or up.
Edit : btw that same bolt being very loose is what will allow you to swap seats. That one bolt on top of the seat post is your seat clamp bolt.
Liked 687 Times
Loosen the bolt. The saddle will slide back and forth on the rails, and also allow you to tilt it forward or back. In general, start with the saddle level and work from there. Small changes make a big difference. If you find that you have too much pressure in the front, try tilting it back a little rather that tilting it forward. It sounds counterintuitive until you realize that if it's tilted forward, that's the way your're going to slide. A slight backward tilt is sometimes all you need. You want your weight to be on your sitting bones.
Likes For Jeff Neese:
