what wheelset do you ride?
Don't really have a bike.
Quoted: 7 Post(s)
just curious as to what everyone is riding.
i currently have dp18's white with black spokes to black formula hubs, but i just bought a spinergy spox front wheel for the next project.
so post away and even pictures if you want.
Bikes: Fuji Track, Half built 70s Azuki
rear wheel is stock IRO, front wheel is velocity fusion to dimension hub. IRO front wheel got taco'ed in a crash.
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 29 Times
Velocity Aeroheads on Formula hubs, Sun CR-18 on Formula hubs, Mavic Open Sport on Formula hubs, Shimano WH-500, Mavic Module E on Sunshine Professional hubs, Mavic Open Pro on Campagnolo Record hubs, Mavic MA40 on Campagnolo Record hubs.
My current wheelset is the best/favorite I've had
Open Pros
Formula hubs
DT Comp double butted spokes
Brass nipples
Open Pros
Formula hubs
Brass nipples
Quoted: 7 Post(s)
maybe so but if you see that one guy posted like 6 sets of wheels so just curious.
it may be a lot of cheap wheels but thats what i ride right now so right on. dont have to post if you dont want to.
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
Miche Primato hubs
DT spokes
Mavic Refex tubular rims
Handbuilt by me.
DT spokes
Handbuilt by me.
Comanche Racing
Bikes: Presto NJS build, Specialized Allez Pro w/ full Dura Ace and Ksyrium SLs, 1990something Specialized Sirrus
Celeste, machined Deep Vs w/ black spokes to black formula hubs. Ebay wheelset.
Also have a set of Alex DH22 rims to generic, no name hubs. black hubs, all black rims, silver spokes. Selling for 100 if anyone wants. brand new
Raving looney
Bikes: 70s Leader Precision w/Shimano 600 (road), IRO Rob Roy (Fixed)
Originally a black CXP22/Formula set from bicyclewheels.com - I can't/couldn't get the cog off the back (fixed/free) so I had a new back wheel built up with an IRO hub and a Velocity aerohead, so I run that on the back now. The new wheel and hub are silver/silver, so it's a mash up now with the black/black on the front. 36h front/32h rear (formerly 36h rear).
I put a lot of abuse/use into the Mavic/Formula set, for $150 they've been worth every penny and perhaps more. Totally kickass street wheels, and not once had to get them trued (though I will need to replace the hub bearings once the spring is fully here, winter and my lack of maintenance/care wasn't nice to them). The front has been on for over 7100 miles, the back I removed at around 4500 I think and can't free the cog off (my own fault for crap/stupid installation.)
Quoted: 7 Post(s)
no need to take it off just keep going when you hit the 10k mile mark you can take it off!
Yup
Location: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
Quoted: 9 Post(s)
Liked 6 Times
Surly hub, alex disc rim, deore xt hub with vuelta rim
Other bike has weinman rims on hubs. No idea what kind of hubs.
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
Quoted: 7 Post(s)
all vuelta's i have seen look nice yours probably do as well.
the ambrosio is what i might use for my next rear wheel. how do you like it?
Live without dead time
Right now I'm running a set of Alex R500s to formula hubs. Pretty sure it's one of the cheapest setups available but it was handbuilt so it's remained true so far after a year of abuse.
Eventually I'm looking at a set of Alex DA28 to formulas. Right now my wheelset does what I need it to.
Bikes: https://velospace.org/node/18951
the rims are 700c, eighteen paired spoke rolf vector comps. the hubs are high flange, 36 hole formulas spaces 100mm front and 120mm rear double fixed. the spokes are bladed sapim cx rays. the nipples are all brass sapim polyaxs. the lacing pattern is two cross crows foot using every other hub hole.
the whole plan was more than a little unconventional and possibly a bit ambitious for my first wheel build, but i just wanted to give something interesting a whirl. im no tri, track, or weight fiend. i had been using this very model of eighteen hole rim radially laced to an aluminum eighteen hole front hub, and it proved to be very durable and a great performer. my rear wheel was stolen and i got a great deal on the rims and hubs so it must have been meant to be. i wasnt worried about the rim or the spoke count as rolf/trek designed and drilled these rims to be used with 18, 16 and even 14 spokes (albiet at high tension), but the right hub was a concern before i made my decision. fixed hubs with 18 holes are impossible to find so 36 it was. i prefer low flange, but with 36 holes, there would be little metal around each hole. for this reason, i went with a high flange hubset. now i was still on the fence about it, but i saw this wheelset, which, though having a higher flange and non paired spokes, uses about the same depth of rim and even a hub brake, which involves tremendous force. i used spocalc linked at sheldons to figure the spoke lengths. the rims and hubs were in the database, but i think i had to plug in 36 hole hole four cross into the table to figure the lengths of the cross spokes. these will be used on the street without tricks or crub and fents jackassery. since the hubs and spokes are 797g and all together possibly under 2000g if i can find the rim weights, they could be a decent competition wheelset if i do say so myself. i mean, theyre so damn aero right? i understand that the forces are distributed over a fewer number of spokes leading to potentially easier untruing slash catastrophic failure, god forbid, and i will proceed initially with caution.
details
details
α
α
