How much do you care about bike weight?
#101
Quoted: 20810 Post(s)
Liked 9,456 Times
I'm not claiming the latter, just that aside from racing or following specific training regimens.. iow, just grabbing a bike and going out on a course, dragging the heavier bike thru that course is likely more effort. Take your example of that solo ride you chose to do.. comfort aside, if instead you had grabbed your lighter bike, and (if you're familiar with Strava?), would you expect to have seen a lower, same, or higher resulting "Relative Effort" score versus having chosen your heavier bike?
Likes For WhyFi:
#102
Advocatus Diaboli
Quoted: 4740 Post(s)
Liked 1,533 Times
Your only explanation tried to bring in some variable about how people's efforts vary on different days, or how intensity varies by the distance someone rides. That's a given but it's not what's being discussed. Take the example in front of you and answer the question.. if Riveting had grabbed his lighter bike instead on that day and done that solo ride he referenced, are you saying it would have been the exact same effort? It's a yes/no question.
#103
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
#104
Quoted: 590 Post(s)
Liked 445 Times
Assuming my power output to the top of a mountain is equal on any bike I ride (and why wouldn't it be?), I would assume that the lighter bike would make the ride up a little bit faster and therefore shorter in duration, making the Relative Effort less on a lighter bike. Which adds to the hypothesis that lighter bikes are for those that want less of a workout, and/or want to ride less? Yes, that's sarcastic trolling.
#105
Why wouldn't it be? Because the highest average power that can be maintained is a function of time, decreasing as the duration of the effort gets longer. So a faster bike would allow a higher average power.
Likes For asgelle:
#106
Liked 9,456 Times
It's not a yes/no question - it's a matter or putting in what you want to put in or are capable of putting in. If I'm absolutely gassed when I get to the top of a hill on a 17lb bike, putting in the same power on a 20lb bike is going to leave me short of the summit... so what happens in that moment? Do I bang my head against that wall and fall over? Do I magically tap in to energy reserves that I didn't know I had and power on? Or does my predicament dawn on me before that, at which point I lower my effort so that I can still limp to the top?
#107
Quoted: 590 Post(s)
Liked 445 Times
Good point. So if the lighter bike allows for a better avg power, and the heavier bike causes a longer ride and therefore a lower avg power due to fatigue, which bike would burn more calories overall, for the same climb? Is it the shorter ride with slightly higher avg power, or the longer ride with slightly lower avg power?
#108
Clarification - the difference will depend on the P/D curve. The faster ride will always burn more calories.
Likes For asgelle:
#109
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#110
Advocatus Diaboli
Liked 1,533 Times
Then you don't know what's being discussed.
I really don't understand why the such absolute "you're wrong" take on this whole thing.
Likes For Sy Reene:
#111
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
It is a yes/no, as we're supposing Riveting was in the same frame of mind before the ride he rode -- pretend he was blindfolded and chose the bike. So your argument is that road cyclists everywhere, grab a bike to go out on their ride, and their intent is to finish at a level of complete exhaustion or comatose? Strava's proxy for effort is a combo of heart rate and time spent at those heart rates. If a rider's endurance zone HR is eg. 160 and they run that for 2 hours on a light bike, but the same course takes them 2 hours and 5 minutes on a heavier bike to complete, which was the better workout?
#112
I'm a casaul/fitness rider. Last year I took a bike to Burning Man, and brought home 10 more. One was a 1990 Diamond Back, chromo dubble butted frame. I also volunteer at a Bicycle Kitchen and so have access to lots of old parts. So I completely rebuilt the thing, taking special interest in light weight stuff. I even took parts to my drill press (Seat clamp, quick releases, etc... I got it down to 26lbs and was quite proud of myself. But then it absolutely killed me to add a cable lock, pump, and seat pack tool kit. So was it a waste of time? In one sense it was. It was a fun project and still makes me feel good to show it off and ride it.
So if you have the money, and a lighter bike makes you feel good, I say go for it.
#113
Advocatus Diaboli
Liked 1,533 Times
Let's try a new topic. 2 bikes that weigh the same, one with flat tires, one with air in them. Which will provide a better workout over a 50 mile course?
Likes For Sy Reene:
#114
Liked 9,456 Times
Likes For WhyFi:
#115
Advocatus Diaboli
Liked 1,533 Times
No, but you didn't seem to understand the more nuanced approach previously.
And this is where the disconnect is. The contention that being discussed is "you get a better workout with a heavier bike." If you're riding a 20lb bike and you want a better workout, you simply. go. faster. If you're riding a 17lb bike and you want a better workout, you simply. go. faster. The difference in energy required for the 3lb swing in bike weight will quickly and easily be swallowed by wind resistance.
#116
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
No, you're wrong. I'm just supposing, that unlike yourself, some riders' goals when they go for a ride are different than yours -- which apparently is to have the highest Total Suffer Score in a specific amount of allotted time.
Let's try a new topic: 2 bikes that weigh five pounds different. Which will provide a better workout over a two hour session?
#117
You dont want to be too lite. I heard below 16 lbs and you start floating into the air, hence why the TdF limits the weight of your bike to that.
#118
Liked 9,456 Times
Ahh.. so that's the disconnect.. I'm using the term "workout" generically/colloquially. As in any ride is some sort of a workout since by default you're getting some exercise. And you're coming from standpoint of a workout implying that there be a specific desired goal or set of goals.
#119
Advocatus Diaboli
Liked 1,533 Times
[QUOTE=Bah Humbug;21706199]No, you're wrong. I'm just supposing, that unlike yourself, some riders' goals when they go for a ride are different than yours -/QUOTE]
Good.. so we agree.. there aren't any absolutes.. and to tell everybody that they're "wrong" is just flat-out wrong.
#120
just another gosling
Quoted: 3895 Post(s)
Liked 1,944 Times
I'll do a reductio. In 2016 my wife and I rode a 154 mile 9500' course in 11:30. on our tandem. The next year, I rode the same course on my single in 9:47. My wife's watts/kilo is a little more than half mine. My hrTSS score was almost the same for both rides.
Why? Because the longer ride sapped my power and thus HR. One only has so many kj to give to the cause or IOW if one is an experienced rider, when one can go faster, one can go harder. Or not of course, but I was riding for time on both rides.
Obviously this relationship would not hold true for shorter rides, where the tandem produces a higher hrTSS for me, about 10 extra hrTSS per 20 miles because it's slower than my single in our local somewhat hilly terrain. On the flat, the two bikes move at about the same speed for the same effort because our lower stoker power is made up for by the increased aero, tandems having about 1.5 X drag of a single bike..Of course on the descents we rule, down on our aero bars. These figures are only approximations, but the idea is solid.
Results matter
Results matter
#121
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#122
Advocatus Diaboli
Liked 1,533 Times
#123
Quoted: 1088 Post(s)
Liked 1,028 Times
#124
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 171 Post(s)
Liked 395 Times
As the original poster has stated both bikes are disc brakes, same components, very close in price they are literally the same. I would do an in store weighing of each bike without pedals. All things being equal I'd probably take the lighter bike.
If you want to make the bike faster, drop 5kgs. To make it even faster drop 10kgs!
#125
Quoted: 18883 Post(s)
Liked 10,646 Times
How did we decide that burning more calories is what a better workout means?
