Vintage looking New bikes??
Where are you located and where have you looked? There are literally millions of older bikes available.
Bikes: Centurion Ironman Expert Dave Scott
Quoted: 18423 Post(s)
Liked 4,540 Times
And perhaps that is some of the differences you should expect between buying a 1988 Bianchi Campione D'Italia for $350 vs buying a brand new Bianchi Eroica for $3500.
Some differences. The Eroica should have stainless spokes. The 1988 bike probably has galvanized spokes. The Eroica has 10 speed on the rear (20 speed total), and the 1988 probably has 6 (12 speed total).
Also, 57cm is probably pushing your size slightly if you're only 5'7", so that might knock out that Bianchi anyway. You could ride it,but it would be tight. Again, buy the $3500 bike, and you get whatever size you wish.
Now, let's compare 3 of the bikes:
- Vintage Meister 10 Speed Road Bike - $125 (Marietta)
Very clean looking.
Probably weighs about 35 lbs.
No quick release. Good for security. Bad for changing flats.
I think it has steel rims. Read about wet steel rims, and make your own decisions... plus they are heavy.
THAT ONE PROBABLY FITS YOU!!! - Trek 1220 Bike - $290 (flowery branch)
Hmmm, maybe aluminum frame and chromoly forks.
Probably weighs about 23 - 25 lbs.
Early brifters, probably 9s or so on the rear end.
Some complaints about aluminum frames, but it won't rust.
Has somewhat more relaxed gearing than the Bianchi (lower gears for hills).
Also a bit on the large side. - Bianchi Campione D'Italia (1988) - $350 (Johns Creek)
Steel Luged
Columbus Tre Tubi Rinforzati Formula Two. Probably a moderate quality double butted steel tube.
Probably weighs 24 to 25 lbs, maybe slightly heavier than the Trek.
Fairly tight gearing as was popular on the high-end bikes of the era.
So, the orange bike would make a good commuter, would fit you, but would be of mediocre quality (which is fine for commuting, and in some cases even preferable).
Quoted: 117 Post(s)
Liked 22 Times
It looks classic and yet has modern equipment. You can also use it in l'Eroica, despite it not being pre-1986. Also, because it's off-the-peg, it's not quite as expensive as a bespoke build.
J.
What do you guys think about this ?
[h=2]Classic Bianchi Campione Road Racing Bike $400[/h]
Quoted: 94 Post(s)
If one gets one of the nicer bikes, be sure to figure out the cost of a good U-lock into the price if one doesn't already have one. One will need to lock it up securely.
Bikes: the bikes own me
Quoted: 18 Post(s)
I'm maybe an inch and half taller than you with a 30" inseam. I've found anything over 54cm to be too large. And around 49cm the toe overlap with the front wheel is too much unless the bike has a unusually long top tube. I only consider bikes in 50-53cm and 19.5-20.5".
Quoted: 18 Post(s)
aka: Dr. Cannondale
Quoted: 2159 Post(s)
Liked 3,465 Times
Yep, very fair price. Shimano 1055 series in what looks to be like new condition, good tires and rims, and if you like purple, well, it appears to be like new.
When you buy that nice lock, take off the front wheel and lock it and the frame to something secure. And keep it in your room at night if they permit it.
My daughter had her very nice Trek stolen the day after she bought it, right outside her dorm at Stanford, as a grad student. They also ripped off her cheapo Pacifica from outside her dorm at Middlebury as an undergrad, and that was a totally c#*p bike.
Liked 4,540 Times
Well, that Bianchi is very purple. The size is probably close enough.
I do tend to like the aero brakes.
At some point, Bianchi moved most of their USA imports from Italian manufacture to Asian manufacture, but perhaps it isn't a big deal.
Personally I'd put $400 a bit on the high side for the bike, but probably not too bad. $300? And, sellers often don't like to bargain the first day an ad goes up.
Do you do your own bike maintenance? It still might not be a bad idea to plan on regreasing your hubs, bottom bracket, and headset. I'm not sure there is a hard fast rule on upgrading 20 year old tires, but that should be on the eventual list, if you're planning to put a few miles on it.
Liked 4,540 Times
There are a few quality Mixte bikes that show up from time to time. Most of the old ones are pretty average, but there are a few nice ones out there.
Or, perhaps that may be a class of bike that would be worth looking for a new build.
Here are a couple of threads to read:
https://www.bikeforums.net/classic-vi...end-mixte.html
https://www.bikeforums.net/classic-vi...5-walmart.html
They are often outfitted with upright bars like a town bike, but they can also be outfitted with drop bars.
I think Soma and maybe a few other brands are making a new quality Mixte frames. It could get expensive to do a frame up build unless you find a good donor bike.
This is a couple hundred out of your stated price range, but as far as new, vintage-looking bikes, I think the Public R24 might be a nice choice!
Best city road bike - the new PUBLIC R24
Bikes: 80's Treks, cargo bike, Lugged LeMond, Eddy Merckx 7-11, Ciocc resto-mod, All City MM disc, and some more
I am still new to biking and I am trying to get my first road bike. I've done some maintenance, but I am still oblivious to how to maintain or setup certain parts.
And about Mixte, I guess I will look into it too , but I don't quite like the design of the frame as much.
Bikes: All 80s Schwinns: 88Prologue, 88Circuit, 88Ontare, 88KOM, 86SS, 88Tempo, 88V'ger, 80V'ger, 88LeTour, 82LTLuxeMixte, 87 Cimarron, 86H.Sierra, 92Paramount9c
Quoted: 188 Post(s)
As for vintage looking new stuff, Velo Orange is all about that. They have a few traditional looking steel frames, though no idea what else is out there for retro new stuff and what is a good price. Frames
Quoted: 1088 Post(s)
Liked 1,207 Times
Linus Bikes are worth a look as well, for new ones. The Libertine is a retro-look road bike, and the 51cm is on sale right now (though that might be a bit small for you).
THE LIBERTINE - Linus Bike
My wife has a Linus mixte and loves it, for what it's worth...
Liked 4,540 Times
How far are you away from that purple bike?
You could ask the seller if he would help you adjust the seat for a test ride.
There are lots of fancy adjustments, but a good start is to put the heel on the pedal at just past the bottom of the stroke with a straight leg.
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
I asked the person for the Bianchi and he said the frame size is approximately 19 inches. I am not sure if that will even fit me according to the conversion scale on internet.
Any thought on this one? As long as the size fits that is
https://atlanta.craigslist.org/wat/bik/5521421016.html
Here are a couple that might at least be worth a look. The brown Schwinn is billed as a "single speed," but it has the double crank and the freewheel, so you would just need to throw a couple of cheap derailleurs and a longer chain on it to make it "geared."
The Shogun looks like it would be the best fit, and would just need a cheap set of drop bars. You could reuse the brake levers.
https://atlanta.craigslist.org/eat/bik/5435403456.html
https://atlanta.craigslist.org/atl/bik/5512262747.html
https://atlanta.craigslist.org/atl/bik/5499380753.html
https://atlanta.craigslist.org/atl/bik/5469152440.html
Quoted: 5893 Post(s)
Liked 3,479 Times
Definitely bigger than a 19 inch frame. Price isn't bad; a bit on the high side but the condition is very good.
What do you guys think about this one
1987 Schwinn Sprint Mens Bicycle Vintage Bike Continental Touring Red 10 Speed | eBay
