Raleigh Technium 440
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
That's great, Scott. I see that you already have a new saddle for it. You might want to just chronicle your upgrade progress in this string, here. Paul
p.s; bold font was good idea.
Zeke
[QUOTE=1989Pre;20545627]That's great, Scott. I see that you already have a new saddle for it. You might want to just chronicle your upgrade progress in this string, here. Paul
p.s; bold font was good idea.[/QUOTE Yes it is!Much easier on my orbs !
Zeke
Technium 440 Restification
Thanks to all of the Members who have chimed in with useful information on these bikes. Since this thread has already been started, I'll document my progress here. I'm going to keep the Bike it's original color. However the the seat and the Bar Tape will be white. At the Same time I want to try and make it lighter than it is now by using lighter/better components than are on the bike at present. 1989PRE has been helpful with information regarding the upgrades he made to his Technium so I'm going to try and follow his path but with my own spin. ( Pun intended) Lets begin with the Before pics. These are from Craigslist:
Zeke
Show Us Your Techniums! (Technium? Technia?)
This is the parts spek that 1989PRE used and I'm going to try and follow his path somewhat.
Fork: Kinesis Road-D threadless alloy
Crankset: Campagnolo Veloce (53-39)
Chainrings: Stronglight/Miche
Rear derailleur: Suntour Cyclone 6000
Front derailleur: Suntour XCM 3040 (original part)
Shifters: Suntour Accushift (set to friction)
Bottom bracket: Campagnolo Veloce
Rims: Sun Venus 700c, 28H rear, 20H front
Hubs: Royce RH30 high flange rear,
Hope Mono Pro III front
Spokes: DTSwiss single-butted 14g
Skewers: Campagnolo Victory
Stem: ITM The Big One 110mm
Handlebar: Scott LF Liteflite 40cm
Brake Calipers: Campagnolo Veloce
Brake levers: Cane Creek SCR-5C
Brake blocks: Fibrax 310 Sprint
Headset: Cane Creek 110 Classic 1"
Chain: Sachs PG
Freewheel: Sachs 14-28 (6-sp)
Seatpost: Campagnolo Chorus Shorty 26.8
Saddle: Terry Falcon Y
Pedals: Speedplay Frog Ti
Tires: IRC Paperlite Plus (23mm)
Comp: VDO A8
I've already ordered a seat a Selle Italia in White: Here it is
Chain: Sachs PG
Comp: VDO A8
Zeke
That Campagnolo Veloce Brake Set
Paul, found these for $20.00, what do you think? Plus shipping of course. The only thing is, the cables on my bike are routed to the left side of the front brake caliper on the bike.In front thats not a big deal. However out back it kind of stinks since the cable is routed threw the frame on the right and it attaches to the caliper on the right.
Likes For ScottD961:
Bad example
Quoted: 828 Post(s)
Liked 214 Times
I am not Paul, but I would keep looking for a set that has the actuating arm on the correct side for the cable. I also wonder if the arms on the brake are too short to reach the rims on your bike.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Since all of the modern (dual pivot) calipers have the cable on the left/rear, you could consider mounting the caliper to the front of the seatstays, 180-degrees from "normal".
This is nothing new, a few builders did it that way routinely and claimed some small advantages. It gives a bike a different look, and you'll have a story to go with it whenever someone points it out.
I wonder if Campagnolo ever patented their self-destructing finish as applied to their barrel adjusters? No one else did that so I assume they have a patent on it. I would get creative with a solution to that myself, maybe some off-colored paint to set them off? No QR levers on those calipers, so if you want to use plump tires on standard rims then the QR function will need to be in the levers.
This is mine. I think it's a first year model 440. One of my favorite bikes.
Likes For ramzilla:
Zeke
Aubergine, I meant 1989PRE when I said Paul. - He has those Campy brakes on his so I looked around and came up with a set. I have a set of Exage here that are in nice shape as well. They were supposed to be mid to upper/mid level brakes? From what I read they were good, but they're best feature was in the levers (which I don't have). There was a button on the lever that you could Push that would allow you to get the brakes off, like a quick release.
Liked 1,296 Times
I would call the Exage levers better than the calipers, tho as a complete brakeset they really aren't bad at all. The reach tends to be short from looking at them. Campy's newer levers all have the QR function built in, but so did many levers in the pretty-old days.
Zeke
Here is the old rear brake, flipped 180 like you said
Zeke
Ramzilla, Nice looking bike. I was looking at straight bars last night as well. Just a thought for now
Green Biker
Bikes: Cannondale sr400
I have a blue Technium, broken rear dropout. Since the seatstays are CroMoly...
Do I have a chance in hell of getting the broken rear dropout re_brazed or welded back on? barely 5/16" in effective "diameter" , obviously not circular but either there was a metallurgical flaw or the cross-sectional area was too small. The bike was barely ridden by the original owner, or I?
I can round up the serial number if needed.....
Zeke
Greenbiker, can you post up a pic? Like you mentioned the rear of the bike is Steel so it most likely could be welded. Finding replacement dropouts? I dunno. These bikes are old, and the component spec of them from the ones I've seen is not that great. What made them great were the frames. Without seeing a pic of the damage it's hard to say for sure. Also if it were able to be welded, would the heat from the welding, weaken the surrounding metal? Possibly. Perhaps someone with more experience with this can chime in?
Standard Member
Liked 940 Times
My opinion of these, Scott, is that they are worth every penny. As Linda Richmond would say, '...just like butter.' They are so much smoother than any other brake caliper i have used. I'm not sure about how to get your rear cable/housing over to the left, or if it is even advisable/possible. Go over to Bike Mechanics sub-forum and ask. (I'm sure the question has been asked, before...) Exage are indeed above-average calipers with, in my opinion, above-average looks, but you would be doing yourself and your bike a great favor by going with those Veloces.
Standard Member
Liked 940 Times
Cane Creek (made by Tektro) SCR5 and discontinued SCR5C have that quick-release button, if you are looking for a contemporary option. Buy Tektro brand and save.
Standard Member
Liked 940 Times
Check out the Frame building and builders sub-forum. Those stays on the Technium are Tange chrome moly and a competent frame-builder should be able to not only braze on a new set of dropouts for you, but give you a selection of dropouts to choose from. This is a common steel frame repair.
Zeke
I have an Exage front and rearderailleurand Fr,Rr brakes. I think I'm going to sell them and stick with the components list you sent me. Or as close as I can
Standard Member
Liked 940 Times
I think you're really going to be glad you got those!
I am not expert, Scott, but i would not recommend "reversing" the caliper. They were not designed for this. Did you ask about this arrangement over at Bike Mechanics sub-forum? I would say just run your rear brake cable/housing over (or through) your seat stays.
Paul
Paul
Liked 1,296 Times
The calipers are designed to work front or rear, so the reverse mounting is within the design capabilities of the caliper and nothing else changes except for the position of the pads in their slots in the caliper arms, and of course any DIRECTIONAL mounting requirement of the brake pads (open end must face rearward!).
Zeke
Zeke
Campagnolo Veloce Power Torque crankset 170 10 speed 53/39
Work is slowly progressing on the Technium. It will be stripped of all of it's equipment this week and then off to the painters it will go. I bought these for it this week:
Zeke
Zeke
I bought these also
Vintage style CAMPAGNOLO B&W Handlebar End Plugs
