View Poll Results: How often do you clean your brake rotors (or rim surface) and pads?
Regularly (How often)
3
7.89%
Here and There
12
31.58%
No
23
60.53%
Voters: 38. You may not vote on this poll
How often do you clean your brake pads?
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Maybe because I regularly go up mountains with long and steep gradients, I probably use the brakes hard and long enough to make intense heat and vaporize any unwanted stuff on the brake pads and the rotors.
Quoted: 2333 Post(s)
Liked 2,097 Times
IPA on the rims about weekly. In the rare case that pads are glazed, sandpaper.
Advanced Slacker
Liked 2,537 Times
I think the reason you find sanding helps or is needed is that you’ve got contaminated pads. Sanding is often just a temporary solution, as the contamination makes its way back to the surface.
Brake dust should have no negative effects on braking, and unless you have comtaminated the pads and feel a decrease in braking, there is no reason the clean/sand them, which is why no manufacturer recomends doing it as a part of regular maintenance.
Quoted: 643 Post(s)
Liked 1,526 Times
I'll clean the rotors occasionally with automotive wheel cleaner that is suitable for painted wheels. I've never cleaned the pads and haven't felt the need to..
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
So assuming that the rotors are clean, this should help ensure that the majority of potential contamination doesn't make it's way to the pads?
Since sanding works really well , temporarily, how can I prevent contamination, period?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Advanced Slacker
Liked 2,537 Times
Aside from the obvious stuff like keeping oily stuff off the pads and rotors..... Just ride the bike and hope for the best. Sometimes it just happens. By road bike pads have never gotten contaminated, but my MTB pads have, and I really don't know how. For some reason when my XT pads on my MTB sit over the winter, something happens to them and the act like they are contaminated. This year I picked up on the blowtorch trick and it worked.
Quoted: 569 Post(s)
Liked 590 Times
I have no opinion on bikes but for cars and trucks this is backward. For years I was responsible for a maintenance department with a fleet of 251 mobile vehicles from cars to 350 ton haul trucks traveling up and down open pit mine haul roads and spent a lot of time studying this issue and the literature is clear.
Quoted: 6202 Post(s)
Liked 4,816 Times
Drip, Drip.
Liked 193 Times
Firm braking (at least for cars and trucks...) Assuming you're not locking up the brakes or braking too hard, helps recondition the pads/rotors and promote even wear, assuming that everything is mounted properly. Assuming we all have the same idea regarding "firm" , what he was saying makes sense. It's actually important to occasionally do some firm "bedding" type stops here and there when the brakes are often subjected to uneven use patterns with Insufficient heat build up, using them lightly, or too hard, whenever they ARE in use.
ignominious poltroon
Quoted: 2245 Post(s)
Liked 3,449 Times
Quoted: 4806 Post(s)
Liked 3,933 Times
Rim brakes - I regularly hose my bikes off with a light spray but blast the brake shoe from both directions to both clean out the ugly black dust and remove any grit.
Right now I have a little tubular glue on my rear rim and a shudder when braking. Persistent stuff! I've done two cleansings so far with Simple Green, paint remover and dish soap. Better each time but still there.
Quoted: 426 Post(s)
Liked 274 Times
It not obvious to me.
For cars, trucks and even bicycles, most of the stuff I've read suggests firm braking is better for brake pad and rotor life. Dragging ones brakes is ineffective for stopping and just creates unnecessary heat which is bad for every thing.
Now if you are talking about hard stops where the bike or any other vehicle is going so fast that the braking can't be accomplished before the parts get too hot, then I might agree.
Likes For sean.hwy:
