Help identifying this bike. 70s.
I picked it up today with a nice deal. Below are the pictures I took after arriving home. It’s a bit heavy ~11-12kg
Head tube lug looks like a motobecane, but the seattube lug seemed not likely.
There is serial number in non drive side shows J7728, none in drive side.
It also has a campy nuovo record crank
Quoted: 3843 Post(s)
Liked 3,398 Times
Motobecane products of this calibre & era tended to employ Vagner flat top fork crowns.
Bikes: '72 Peugeot PX-10 '78 Motobecane Le Champion '83 Motobecane Grand Jubile '85 Trek 830 '88 Merckx Team ADR Corsa Extra
Quoted: 472 Post(s)
Liked 1,216 Times
Possibly a Schwinn Paramount?
Likes For Sedgemop:
Likes For Mr. 66:
It did have a few schwinn parts.
Likes For ryanl092:
Liked 3,398 Times
Likes For juvela:
Freewheel Medic
Quoted: 1464 Post(s)
Liked 2,220 Times
I'm 100% certain it is a 1977 Schwinn Paramount P15, made in the month of September.
Great score despite the terrible paint. The lugs on the head tub and fork crown should be chrome.
Bob
Bob
Likes For pastorbobnlnh:
I am surprised that it turned out to be a Paramount. The seller said it's about 1976 and rally race bike or a Motobecane. I saw it's crankset looks like a Campy 3x that I was thinking about to find one, so I pull the trigger.
Well, now I will need to thinking about how to deal with the paint. It will be the oldest bike I ever owned.
Likes For ryanl092:
Liked 3,398 Times
lug note -
you mentioned in your initial post that you thought it might be a Motobecane
the lugs on the frame are the frequently mentioned scrolly NERVEX Professional (Dubois)
Motobecane employed a very similar pattern, also produced by NERVEX
here is a closeup of it:
both the blue and the yellow frame in these images are the Grand Record model of 1973
another manufacturer who employed this lug pattern was Jeunet
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 282 Post(s)
Liked 973 Times
Great score! Looking forward to seeing it on the next peninsula ride.
It turned out to have most of parts original except paint, saddle, rear wheel/hub,tires bar tape. I really just want to buy that campy triple cranks. Really!!
Freewheel Medic
Liked 2,220 Times
I'm certain that if all you want is the crankset, it should be easy to find willing C&Vers who are ready to adopt whatever bits of this Paramount you don't want to nurture back to good health and longevity.
Bob
Bob
Quoted: 282 Post(s)
Liked 973 Times
If you're pulling the crank for another bike, be sure to pull the bottom bracket also.
Mike
Likes For Mr. 66:
Stop reading my posts!
Quoted: 1453 Post(s)
Liked 1,078 Times
^yes, start with "mild" stuff like mineral spirits which should not affect cured original paint, then if you need and if you dare move up the refining tower to more risky solvents like Acetone or the blended stuff like "goof-off" or "goo-gone", but go slow and try them on a "safe" area first.
-wear gloves.
-use a good respirator and/or work outdoors or in a well-ventilated area...I always prefer "under a spreading Chestnut tree", myself!
-wear gloves.
Likes For unworthy1:
Quoted: 282 Post(s)
Liked 973 Times
-wear gloves.
-wear gloves.
Likes For SwimmerMike:
It’s time consuming to remove those pain.
40% of head tube done.
Likes For ryanl092:
Quoted: 282 Post(s)
Liked 973 Times
That’s looking so much better!
I think I will do a minimum clean up/lube and ride a bit before disassemble all the parts. The reason is it's not my size.
I used to ride CTT 49-52cm, My 52cm bike has seat post 2 inch out of the top tube. This one has only little space there. It's a ~22 in (55+cm) bike.
The paramount looks so nice to keep it, may be I will wait for a smaller size frame and swap out all parts. It's wheels are quite heavy anyway.
The non original rear wheel plus freewheel seemed to be ~2kg+. No wonder the total bike is about 12kg (26.4lbs)
If I would keep it longer, I will probably change it to have down tube shifter (I'm not familiar with bar end one)and replace brake lever to campy one.
BTW. I have no idea if the tires are clincher tires or not.
Likes For ryanl092:
Freewheel Medic
Liked 2,220 Times
Is the underlying paint (as seen where the head badge should be, and where the derailleurs cable stop has slipped and the band below) white or silver? I wonder if that is the original paint.
Bob
Bob
Yes.the original paint is silver. The condition seemed not good after my removing some underneath the water bottle cage. I will stop removing the paint for now.
when I browsed FB market place yesterday, I found there were 2 Ads for this bike. The pre-pre seller post it as free, local pickup from a lady. She also claimed “This is an old bike with some cool old Schwin and Campy parts. Must take the whole thing. ”. No wonder the guy sold this bike to me has no knowledge of campagnolo and spelled it as campagnola. It remind me to tell my wife to at least donate my good old stuff to charity, not throwing out for free when ‘it’ happened.
Likes For ryanl092:
In the middle of tear down my bike I got stuck on bar end shifter and crank cover.
In a market place about a 7400 bar end manu I saw that it need counter clockwise to tighten it. Is it true applying to all shimano bar end? I think the schwinn one is shimano. If so, I was totally wrong.
And then how about this. I doubt if I can remove it by a 5mm wrench. Which direction to go?? Help me. The worst case is to drill 2 holes and use BB tools that has 2 pins to loosen it.
Quoted: 282 Post(s)
Liked 973 Times
I haven't taken out Shimano bar end shifters except for 9/10/11 speed on my tri-bike(s) so I'm no help here. Except I would expect them to be the standard CCW to loosen. For the crank bolt cover, they are standard threaded so CCW to loosen. I've encountered some bad/neglected bikes and never had an issue removing the Campy crank cover with an Allen wrench. If it is stripped, I would try penetrating solvent (PB blaster is my choice) and shove a flat end screw driver in to try to somewhat save the cap.
