Park INF-2 Inflator Qiuestion - Hissing Sound
Quoted: 913 Post(s)
Liked 515 Times
Yes , I agree the male plug came with the Park INF-2 inflator - I feel it's the female quick release coupler that's the problem - I plan to bring the hose with both connections to a local woodworking shop that uses a compressor with fittings all day , I'll see what they recommend , thanks !!
senior member
Park INF-2 & Compressor Plus Fittings - Success At Last
Thanks for all the thoughtful comments and suggestions - took the hose, inflator, & hardware to a friend at a local wood shop - he said that in his experience air tools can be finicky - he replaced the Park supplied plug with one that is made by the company that produced the QR female - air leak diminished considerably - the fit tolerance between plug and coupler is very small but not generally airtight - I'm happy with the Park INF-2 inflator , very rugged , along with the Craftsman compressor - it takes a few seconds for the compressor to reach readiness but then pumping to 100psi is super fast - as mentioned b4 I'll keep a dedicated hose with ball chuck for the cars .
Thanks all for your time !!
Likes For blinky:
Quoted: 6234 Post(s)
Liked 4,839 Times
We aren't deaf!
senior member
Liked 4,839 Times
I'm sure I won't be the last person to jab at you for using bolded text.
I'm assuming you are aware there are settings in your computers OS that allow you to manipulate the size of the text on your own display and even change the display to display text in higher contrast and in the colors of your choice. Though without me being you, I certainly don't know if those are useful or not.
If you wanted to, I'd certainly appreciate a <ctrl><a> (or <cmd><a> on a mac) and toggle of the bolding before you push reply. Though I'll try to keep it in mind that it does help you if you choose not to.
