Your "I should have known this" story
Bikes: Trek Domane, Surly Disc Trucker
Quoted: 170 Post(s)
Liked 103 Times
Question came to mind in my response to a post in another thread regarding things I probably should have known but didn't or just didn't think about. I recently had one of those do'h experiences when I was repairing a flat (was doing it at home so had my floor pump). I was thinking my floor pump may have been having issues with inflation as the seal around the stem didn't seem to be holding for one of my tubes. So, I figured I'd test the floor pump on my new tube before inserting it into the tire. I started Inflating the tube and got to probably not even 35 psi - the tube was looking deformed (like a snake swallowing a rat) and, of course, exploded. I brought it back to the LBS thinking it was a defective tube and, of course, they gave me that "what were you thinking by trying to inflate a tube AT ALL outside the tire". It was pretty embarrassing and I realized that was something I definitely should have known not to do.
Have you had any situations where, once it happened, you had that "how could I NOT have known this" moment?
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 410 Times
I've inflated a bare tube outside the tire all the time whenever I have to check for a puncture, but not to the shape of a doughnut.
A few weeks ago I couldn't shift into the smallest cogs, so I assumed I needed to adjust the rear derailleur. I got the bike on my stand and tried to adjust, but couldn't get it to shift properly. I released the cable and it got to a point where the shifter didn't seem to be shifting, so I assumed it was a bad shifter.
Brought it to the shop and within a few minutes they had a new cable in and all is well.
I should have known that
Quoted: 18446 Post(s)
Liked 15,678 Times
When I was touring across the country I got lost and realized I should have known to take that left turn at Albuquerque.
And with that, I have reached 20,000 posts. to me!
Quoted: 741 Post(s)
Liked 818 Times
I installed a new chain and cassette on my Roubaix, and just couldn't get the chain chatter to quiet down. Lube, barrell adjust, nothing worked. I even loaned the bike to an out of town visitor, hoping he would want to buy it. I began to hate that bike. Following a 50 mile ride in pouring rain, I was checking things over, cleaning and re-lubing everything. I saw that I had routed the chain on the outside of some kind of guard tab on the cage next to the jockey wheel. It was intermittent, depending on cage rotation. The really dumb part of this is that it was my second time to make this mistake... on another bike. All quiet now, and the bike is a pleasure to ride again.
Quoted: 366 Post(s)
Liked 421 Times
My contribution: when routing shifter cables, you need to make sure that they're routed under cycle computer sensor wires. Had to replace a cycle computer mount and sensor set due to that brain fart. I just didn't think of it.
Quoted: 2281 Post(s)
Liked 1,710 Times
I'm just absolutely amazed that you got a bike tube up to 35 PSI before it exploded.
retrospectively
R60 Friction steering damper is not as good as the hydraulic one on the R69,
on BMW Motorbikes,
in curing, or more like masking , fork oscillations..
of some what imbalanced wheels..
on BMW Motorbikes,
Quoted: 2503 Post(s)
Liked 2,982 Times
I once worked in a bike shop that had been open 45 years (since the 1930s); the shop had a very old handmade wire form about the size and shape of a motorcycle tire, the idea being that to find a slow leak in a tube from a balloon-tire bike, you'd insert the tube, inflate it enough to expand to fill the form, and plunge it into a sink filled with water to find the leak.
Liked 1,710 Times
I agree. That's why I said I'd be amazed at any inner tube being pumped up to 35 PSI before exploding. That's about the pressure that normal car tires use.
Bikes: ...a few.
Liked 410 Times
One time, upon failing to remove the NDS crank arm from an old vintage bike on account of me stripping the threads on the crank arm because I did not seat the crank arm remover tight enough, I attempted to take a hacksaw to the crank. Eventually I did manage to get it off without cutting it, though I forget what I used. I should have known to make sure crank arm remover was seated all the way and tightly.
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I tried to remove the freehub from a fairly nice hub that was not laced to a rim. Lacking the necessary grip and leverage, I came up with the brilliant idea to use a set of vice grips to hold the hub. The vice grips mutilated the hub and basically ruined it.
Like I said it was a rather nice hub... I'm still ashamed enough that I'm not going to reveal what kind of hub it was.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Shoe: "An advance!? Again? What happened to the advance I gave you last Friday?"
Cosmo: "Well, I spent some at the bar, and a lot more chasing women. I lost a bundle at the track...".
Cut to the next panel:
Cosmo: "The rest, I'm afraid, i spent foolishly".
Just think what you could have done with the time it took for 20K posts. You could have learned Italian. You could have learned to silver solder, and built yourself a custom mid-70s Cinelli knock-off!
Seriously, though, I've learned a lot from your posts, Indyfabz. Congrats on the milestone.
Brand new crankset, went out for a test ride, the crank-side pedal came loose and stripped out half the threads of the crank. I usually double check nut/bolt tightness.
I should have known this.
Super Moderator
Quoted: 1173 Post(s)
Liked 931 Times
Quoted: 3259 Post(s)
Liked 2,100 Times
I removed a set of mt. bike grips, hated the feel. I usually pry up the outside end of the grip with a flat screw driver then spray some Windex in, loosens it right up, old grip off, new grip on and the Windex drys out and leaves the grip nice and tight.
Last time I couldn't find the Windex so used som WD40. Mistake. A year later and the grips rotate like a motorcycle throttle, Vroom, Vroom. Great.
I tried cleaning. Nope. Tonight I'm trying some Glue Stick stuff. Doubt it'll work so expect to be buying new grips.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
WTG! Got any tips for someone else hoping to someday reach the lofty plateau of 20 grand posts? (Retiring at the end of December should help free up some time for productive posting.)
Quoted: 4560 Post(s)
Liked 2,803 Times
Quoted: 1105 Post(s)
Liked 1,825 Times
Trying to remove a square taper crank with the washer still on the end of the BB spindle (it didn't come out with the crank bolt). I'm lucky I didn't pull the threads out of the crank.
Breaking a drive side pedal loose without having the chain up on the largest ring because I was "in a hurry". Note to self, it takes less time to put the chain on the big ring than it does to clean and dress a gash from the teeth.
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
I once overinflated my tire at a gas station pump to the point of explosion. I should have known that the pressure ratings are meant seriously. The fun part was that I was running one of these slime-filled inner tubes...
My bike was 'repainted' to faint green within the time span of a loud 'boom'.
Cycleway town
I put a petrol engine on a 1970s Ellswick Hopper, nearly killed myself on the thing, then decided it was probably better without the engine.
I should've known that.
In my defence, the engine is still on it - because it's funny AF
