Photo of the bike you use to pick up your groceries
Gets large rear panniers when on grocery duty. Otherwise, front basket for beer runs.
Likes For bear_a_bug:
bicyclatte!
Quoted: 45 Post(s)
That's a little disappointing - I was really hoping we'd get a photo of your helmet mounted periscope.
If someone can pour a Guinness with a cycle instead of a shamrock on top, I'll update my profile pic.
Pedal to the medal
Quoted: 3811 Post(s)
Liked 6,713 Times
bicyclatte!
Quoted: 45 Post(s)
Saddle to handlebar drop seems a bit aggressive. I prefer a slightly more "French fit" myself. No worries about saddle bag to tire clearance, though.
Quoted: 2338 Post(s)
Liked 2,827 Times
since i havn't done a build for while (don't really need to as my bikes meet what I do......until i find something cool, italian and cheap)
my torpado with macgyvered rear rack (use bolts, washer and rubber cone from ACE to mount rack to the triangle in the rear drop out), use some performance transit grocery panniers
my nishki with wald baskets.... this will haul a ton
Quoted: 443 Post(s)
Liked 27 Times
Thanks for sharing @Grand Bois.
The copper sleeve on your handlebars, is that a shim for the stem?
They came as a set from Belgium. The brand is Luxe. That's all I can tell you.
52psi
Quoted: 790 Post(s)
Liked 802 Times
...It's been somewhat modified since the pic, with Cyclone shift levers, more upscale seatpost, removal of the half clips, and a more conventional bar position. (Trying to get away from my amateurish "ramps level with the ground" setup.) Hauls groceries, a trailer containing a 5-year-old boy, or both.
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
Not a good pic as its from a family overnight camping trip(hence the panniers).
I usually use an '80 Schwinn Voyageur 11.8 which has been changed over to a Suntour 3x7 bar end shifting drivetrain. But sometimes Ill use my gravel bike or touring bike.
If its a genuine grocery run, the converted Burly comes with since groceries are for a family of 4. I ripped out the seating and cut a plywood floor to fit so it can hold 8-10 large bags of groceries if needed.
Interesting that this thread is 2 pages deep and this is the 1st trailer mentioned. Everything else is panniers or baskets.
Bike Friday Haul-a-Day, which I use with or without the converted Burley kid's trailer:
Likes For southpawboston:
Quoted: 7350 Post(s)
Liked 2,475 Times
Boy, these are some fancy shopping bikes!
This beast has served dutifully many times. My locks are lashed to the rack. I can wear a backpack full of groceries at the same time and then roll carefully through the streets. It's a bit tricky, but I can do it.
Likes For noglider:
bicyclatte!
Quoted: 45 Post(s)
Meant to ask - it seems like a few of you (@Vintage_Cyclist, @jmeb, @Grand Bois) are possibly using rear racks flipped around as front racks - am I correct in that? Or are those front racks with to-the-axle-length stays?
I'll add my Volpe to the one posted by noglider. Just picked this up last winter for $150 including everything you see here except the C-dale rear panniers and h-bar bag (had those before). Even came with a Flight Deck computer.
Likes For bargainguy:
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Bikes: 1966 Carlton, 197X MKM, 1983 Trek 620, 1988 Schwinn High Sierra, 1995 DBR Axis Ti, 1999 Waterford, 2016 DBR Release, 2017 Surly Travelers Check
Quoted: 65 Post(s)
Liked 7 Times
Quoted: 443 Post(s)
Liked 27 Times
He put his first name on the earlier ones.
Quoted: 1608 Post(s)
Liked 2,216 Times
Can't recall if I have hauled groceries, don't think so. I have hauled a number of other items (commuter gear and items) including fairly heavy stuff (800+ rnds of ammo) and somewhat awkward packages (item to go with the former). I call it my truck. It just turned 20 years old so almost it is arguably C&V candidate. It also just turned 5200 miles that were tracked. Don't know how many prior to tracking. I did buy it new as a last year sale bike.
[IMG]1997 Specialized RockHopper, on Flickr[/IMG]
Should I consider a front rack? Will one work well for this bike?
Quoted: 8 Post(s)
Has anyone found bike bags that double as...well, grocery bags? Here in California we have a $0.10 charge per grocery bag to encourage reusable bags. It would be nice to have the reusable grocery bag incorporated into the system of the bike bags to go from bike to store to bike to house in one foul swoop.
Quoted: 3015 Post(s)
Liked 3,804 Times
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
Built this up for my Seattle daughter-in-law...
Likes For 67tony:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Quoted: 2324 Post(s)
Liked 4,992 Times
Steel is real...and comfy.
Myrtle Beach Crab
Bikes: enough one would think, but thinking isn't my strong point
Quoted: 271 Post(s)
Liked 541 Times
for groceries... but not of the main food group kind. vintage Walmart frankengoose.
Quoted: 938 Post(s)
Liked 2,944 Times
I just made my first run on this build tonight. It's my '71 Raleigh International, now with 8-speed Sturmey Archer hub gears, upright bars and racks. I intend for this to be my new commuter/townie/grocery bike. 3 bags of Trader Joe's finest later, I'm declaring it a success.
Likes For ascherer:
