Idiopathic Bontrager wheel screech
Quoted: 1529 Post(s)
Liked 718 Times
Shhh, Kimmo. If you make posts like this they'll ID you as reactionary. Then they'll come after both of us!
I, too, feel that the older cup and cone angular contact bearings were better: 1) AC gives lateral stiffness, 2) as a result of lateral stiffness, AC bearings wear more slowly, 3) the deep groove radial design means that the inner and outer races are "stacked" and not "nested", meaning that AC hubs can be more compact, 4) the AC hub is held together with the cone nuts and lockwashers - none of the loose pieces held together with the QR and .... o-ring friction!
The only advantage I see to the cartridge approach is that the outer race is easily replaced, which is not so on the older AC bearing wheels. Shops love em I think, because the deep groove radial design wears out every couple years due to higher wear rates from side forces. So it makes for more shop revenue. Sigh.
Does my head in how so many folks can look at an Ultegra hub or similar, and look at hubs by pretty much anyone except Campy or Shimano (ignoring all the low-end loose-ball stuff like Joytech), and not see that one is fully designed for purpose using all bespoke elements, and the other is a result of the engineers just throwing up their hands and saying 'generic part goes here' when it comes to one of the most important aspects.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
@Kimmo: the engineers involved here were concerned with how to 'cleverly' kill two birds with one stone. I'm sure they saved gobs of money simply because they didn't need to shut down a production line to retool for a longer axle.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Quoted: 1304 Post(s)
Liked 1,913 Times
Wiz, Kimmo, and Unca,
At what point in the design process, did anyone think about down the line problems that might occur? I'm thinking (just like the last girl I asked out) NEVER! These guys are taught to do the quick and dirty production process, and save the company as many dollars as possible. So post production problems are up to the QA people who will learn how to explain the problem away. Stoopid easy and stoopid simple is the new way of engineering, and don't try to think about the future in this,,, more to come in the next generation... Smiles, MH
Quoted: 4212 Post(s)
Liked 3,883 Times
MH- I was just talking about this aspect of current bike design/manufacturing with a co worker that I will likely end up teaching how to build a frame. The life cycle of a modern bike is less then the industry wants you to believe. Why? Because the marketing side (and one can lump into this the world of magazines, blogs and such that parrot ad spec/hype) are working harder to create a reason to buy the latest/newest with the promise that your Strava status will go up.
We're never going back to the abundance of small replacement parts availability being important or frame resiliency is what makes a frame better Andy
AndrewRStewart
AndrewRStewart
