Paraffin waxed chain skips in freezing temperature
#126
In the wind
As a fellow Calgarian, I've just converted to the chain waxing cult. When I ride my bike on the rollers, my wife complains about the occasional oil drop on the carpet - cleaning and waxing the chain seems to have cleared this up!
As for the bike I ride outside in the winter, anything will do as long as it lubes the chain. The bike is going to be a mess anyway. If I get cold while applying it, I don't bother even wiping it down.
(-32C here today )
(-32C here today )
#127
Quoted: 645 Post(s)
Liked 797 Times
I live in a dry climate (Calgary, Alberta) and have always used the ProLink Chain Lube to maintain my chains. This lube done a good job in summer.
I commute 22 km (about 14 miles) round trip to work 3-5 days a week.
This winter we've got quite a bit of snow and the temperature swings dramatically (sometimes 20 degrees within a day).
On the wet slushy days the lube washes off the chain fast and I have to re-lube daily. So I become interested in waxing the chain because of all the benefits it promises: 200+km between rewaxing, clean chain and longer chain life.
I tried the hot waxing method last weekend. Cleaned the chain (it's a used chain with less than 0.5% wear), soaked it in three mineral spirit baths, dried, and "cooked" it in a paraffin bath (no additives, pure paraffin). Before taking the chain off the slow cooker, I waited for the paraffin to cool down to the point when a film started forming on the top. There was quite a bit of paraffin left on the chain after the process. I did not wipe it off, thinking that it will serve as a protection layer for the chain (a mistake, as I found later).
I've cleaned the cassette and the chain ring, loosen the chain (it was hard as a stick) and installed it on the bike. I also used paraffin on the jockey wheels bushings (again, not a good idea). Spun the crank for good 10 minutes to clear the excess of the paraffin from the chain.
My commit on Monday (it was -5C (23F)) started with some skipping. But I was optimistic and expected the skipping to go away soon. I checked the jockey wheels in the evening and found that they were very stiff and had lots of resistance. So I cleaned them and lubricated with a dry chain lube. The chain was still pretty stiff.
On Tuesday it was much colder -15C (5F) and the chain skipping became much worse. On my way home it was snowing and the skipping was so terrible that I was afraid to switch gears. I've noticed that the skipping gets worse on lower gears (when derailleur bends the chain less).
I'm fairly confident that the cassette is not worn out. There were no skipping before I waxed the chain. This is the second chain on this cassette and I replaced the previous chain when it hit 0.5% wear.
What am I doing wrong? Should I try to mix the paraffin with the paraffin oil?
I've heard that some guys that live in Anchorage, Alaska wax their chains. And I'm hoping that paraffin can work in winter.
Any help or advice is appreciated
#128
Have you checked if there is any wax build up in between cogs of the cassette? Especially the smaller ones, sometimes there will be build up on the side of the cogs closer to the teeth which causes regular skipping.
I also never wait for the wax to cool down to pull the chain out. On the contrary I pull it while the pot is working and everything is hot. Much less build up on the outside. I don't think the additional wax building up on the outer links is doing anything good.
I let the wax to cool down and thicken a bit before pulling out the chain to make sure that the wax won't run out of the rollers. I'd like the rollers to be filled with wax, the wax residue on the outside of the chain is just a nice bonus to protect the chain from corrosion.
#129
If the chain is stiff enough it will not allow the derailleur take up the chain slack effectively and we end up with the chain skipping.
This is my understanding of the bike drive train mechanics. Please correct or feel free to laugh at me if I'm wrong
#130
(-32C here today )
(-32C here today )
The winter bike doesn't have to be a mess. If you convert it to the paraffin and use a bucket of warm water to rinse it after especially wet rides, it will look pretty clean. That was my experience.
Plus, you would need to freeze in a garage while lubricating the chain. Instead, you'll be drinking hot coffee, listening to soul-warming jazz near a fire place while keeping an eye on a crock pot.
I went for a ride over a lunch brake today. It was sunny and beautiful, Garmin measured -24C. Not the ideal cycling temperature but I enjoyed the ride.
#131
Quoted: 645 Post(s)
Liked 797 Times
This is true for a single/fixed gear bike. On a multi-speed bike there's a substantial chain slack that is compensated by a rear derailleur, and the stiff chain is now fighting with the derailleur spring.
FTR I use standard eBay paraffin, soak the chain in wax for 20-30 min in a small slow cooker, giving it a swirl every few mins, then retrieve it hot and hang it to solidify. I usually wax all three chains at the same time (doing each chain individually) and run each on the bike for ~300 miles.
#132
Not laughing at all - just that my experience differs - the newly waxed chain starts out jumping around the place, and the RD bounces back & forth a bit, but 1-2 trips around the sprockets and the rings breaks up any wax that's hindering chain articulation, and everything settles down. I install a waxed chain, give the cranks a few turns on the stand, run through the gears (which I do anyway if I'm doing anything to the drivetrain) and that's it - there's no residual "wax effect", even in cold temps.
What's the coldest temperature that you tested the waxed chain in?
#133
Quoted: 645 Post(s)
Liked 797 Times
down to ~zero C. I really don’t know how the wax will behave at significantly lower temps, but I imagine it would get harder and more brittle
#134
Quoted: 8 Post(s)
Hi Axel.se. I'm happy to hear from you, and glad that the experiment with wax mix worked well.
I've been paying attention to how long does one waxing lasts for me. And my results are not as good as yours (although I'm still quite happy with them). I get less than 200kms on one waxing, but I ride an e-bike (Mid-drive pedal assist motor) so there's much more stress on the chain.
However, this wax mix is great for extremely cold weather. We are going through some harsh cold conditions, it's been -30C (-40C with wind-chill) for a week now. The mix performed flawlessly, no chain skipping, shifting is crisp and fast.
I also use a E-Bike, specifically a Scott axis e-ride 20 with the bosch performance cx motor that I bought around Easter 2018 so the wear should be rather similar.
I wish that the temperature here actually got down to -30c but I live right by the ocean so we usually only get it down to -10c or -15c and it is so much water in the air when it is warmer then -10c so it rips any warmth from your bones and it fells worse then -40c in other parts of the country, when it gets colder then -10c the last water freezes out of the air and suddenly it don't feels so bad any longer.
Anyway it have only gotten -15c here for a few days this winter and the wax mixture worked really well for that and I did test the mixture I made by putting a bit of wax it in the freezer and from how pliable it felt after cooling it down to -22c I think it would work well down to at least -25c if not -30c . Though it might be a good idea to use a bit more oil then I used if it seems to turn too hard or the weather get much colder then that.
The fact that it was still pliable at more then -20c is why I will test a mixture with a bit less oil and more beeswax next as I don't need it for really extrem temperatures and I plan on making testing a really low oil high beeswax mix later in spring.
I'm curios how do you clean new chains before waxing? The procedure that I was using is to soak the chain in several mineral spirit baths, then rinse it in rubbing alcohol.
I want to reduce the need for harsh chemicals in my bikes maintenance practice and was thinking about skipping the new chain degreasing. Wouldn't factory the chain lubricant soften and wash off in a hot wax? The wax adhesion is likely not going to be great on the first waxing. But it should improve on the next applications. Do you think this sounds crazy?
I do not recommend that metod (atleast not for connex chains) as for some strange reason the gasoline managed to get the stainless steal in the connex chain to rust, the next time I will try to just let it sit in aceton from the start (used that to dissolve some of the rust so hopefully it will not no have the same problem)
What the factory oil would do when put in hot wax is really hard to say as we have no idea what they actually use for that oil, I think that even with doing 100km wear in with the factory oil you should be able to get away with just 0.2-0.3L of aceton.
This could be done by putting the chain in the aceton letting it sit for a while and shaking it, then just fishing out the chain and putting it in a new container and after letting the aceton sit so the solids settle to the bottom of the first container then you can just pour that aceton into the container with the chain just being careful to not pouring the solids with the aceton, clean out the stuff left over and repeat until no more particles are dislodged from the chain. Sure you will lose a small amount each wash and it might be a good idea rinse it in some "fresh" aceton to be sure to get rid of absolutely all factory oil, but that aceton can be used with the other aceton for the next chain so the total amount needed should be rather low and should not really need to be discarded until it have been used a few times if ever. (just remember to put a lid on the containers).
I would recommend testing putting the factory oiled chain in wax by putting a few spare links in a small amount of wax first to be sure that nothing really unexpected happens. Worst case would likely be if the factory oil get burned to the metal by the temperature and even harder to remove later I don't think that is too likely but it might be a risk.
It might also lead to some extra wear to not do the initial run in as apparently chain manufacturers aren't as diligent with deburring their products as they should and that would result in metal particles stuck in the wax inside the links and accelerating the wear. Talking about chain manufacturing I suspect that connex actually make their chains slightly undersize as I am still not able to even get the KMC tool between the links to measure the chains at.
I would also like to ask your opinion on using beeswax on a freewheel as a rust inhibitor. I have a (vintage?) 1989 Miyata 618GT touring bike that I use as my winter commuter (when the weather is not too harsh). The bike has a 6 speed Suntour Accushift system. Maeda Suntour are out of business since early 90s but they used to make a high quality and reliable components (some say better than Shimano). The freewheel on this system does not have any protective coating and rusts easily when exposed to road salt. I was thinking about taking the freewheel apart, cleaning the cogs from rust and dip them into beeswax to protect from rusting. Do you think that would be efficient rust protection?
While I am personally not too worried about rust I do understand wanting to keep vintage from getting any unnecessary wear.
And I need to get the connex sprocket of the motor and put it in the wax bath some time as that have started to rust, I am not too worried about that as I see it is as part that I will wear out and replace sooner or later. For the back cassette (CS-M5100 Cassette 11-51) I honestly don't even know if it is steal or aluminum, the website where I bought it said steal, but the box say something about aluminum but nothing about what is aluminium and Shimanos website is less then helpful, I would suspect that the gears are steal as they should wear a bit too quick otherwise but I have too inspect it for rust the next time I take it off to move it to the new wheel I am building.
#136
I did check for the paraffin build up between cogs. There's no build up at all.
I don't think the wax in between rollers can run out of the chain as fast as you pull it out. When pulled out, the exposed wax on the chain immediately begins to form a slight skin and only a few drops come out.
Here is what I think:
1. Whether you have too much build up on the side plates that it causes the jump.
2. The chain because of the cold gets too stiff hence causes the jump (similar to what happens when you have a stiff link). I don't think the stiffness caused by the excessive buildup outside necessarily mean that inside is better lubricated.
Do you mind putting a photo of your drivetrain and chain ?
#137
It doesn't look like Bosch sells any spare parts for it either. If it suddenly fails, I fear, the repair is going to be very costly if possible at all.
I tried the 100g paraffin + 100g beeswax + 20g motor oil mix. The wax turned to be just a bit harder than my old wax (with paraffin oil). The new mix is more durable than the old one - it lasted 250km in wet conditions and the chain was absolutely quiet at that point.
I rewaxed the chain after 250km because it started rusting pretty bad. The new mix, although doesn't feel oily, still attracts dirt and the wax that remained on outside chain plates turned black.
The biggest issue with the new wax, however, is the smell: beeswax mixed with motor oil makes this disgusting, vomit inducing smell. The smell alone is enough to consider the experiment failure.
My next mix experiment was 100g of paraffin and 30g of beeswax. The wax turned to be much harder and the chain was very stiff. Took quite a bit to loosen up the links, I first loosen them up by hands and then put on the bike and spinned the cranks for good 5 minutes.
I doubt that this mix will work in -30C, but in -10C it works quite well. I'm still testing this mix. We had a week of warm and wet weather - lots of deep and long puddles. I rode about 100kms so far. The chain is soaking wet but quiet.
Tried the idea of remoting the factory lubricant by dipping the chain into hot paraffin. Used a few chain links left after shortening a new chain to a needed length. The method works quite well. After waxing, the chain doesn't feel oily or sticky and does not attract dirt. I even took apart a couple of links and inspected rollers, pins and plates - no signs of the lubrication, paraffin sticks quite well.
The factory lube did, however, turn paraffin cloudy. So it seens that a separate paraffin bath needed to strip the oil prior to actual waxing.
I have seen some videos of people that use the wax in that way, the only problem as I see it is that the wax will be worn away from the areas that is in contact with the chain so maybe it could be good idea to combine it with some spray or something but cleaning it and waxing it most likely will save you from having to take it apart completely in a long time and save it from getting water ingress between parts and rust buildup there.
#138
Quoted: 645 Post(s)
Liked 797 Times
Mineral spirit =/= acetone. The first is a mix of short-chain hydrocarbons, the second is a specific low molecular weight ketone. Very different. IME acetone works way better at degreasing than MS, but it’s very volatile and really should only be used with good ventilation. Think “nail polish remover” - it stinks up half the house when my daughter cracks the bottle to do her nails. Great also for cleaning chains prior to waxing, and for removing pretty much anything organic, including old decals (probably wouldn’t use it on a carbon frame, though!)
#139
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
I used to use mineral spirit (another name for acetone, in my understanding) to clean chains. It works well but the smell is terrible. Also, I would like to avoid keeping harsh chemicals at home if possible. I also tried citrus degreaser - it's less effective than mineral spirit but smells nicer and biodegradable.
Instead of short rinses, I leave the chain in for hours and it works equally well then.
#140
Quoted: 857 Post(s)
Liked 1,090 Times
#141
Quoted: 857 Post(s)
Liked 1,090 Times
I switched to something like this successfully: https://www.homehardware.ca/en/500ml...=1525535421021
#142
Quoted: 181 Post(s)
Liked 14 Times
@Crankycrank: Thanks! I've been doing this overnight, so something like 8-10 hours. So far, been fine.
#143
Thank you correcting me and for pointing out that the mineral spirit and acetone are two different things.
Good point. Also, citrus degreaser doesn't work nearly as good as OMS especially in unheated garage in winter.
I wish there was a chemical as effective as OMS but with the roses scent
Used citrus cleaner is no longer biodegradable when contaminated with bike spooge. Many of us here on BF put some OMS in a jar and swish the chain around or soak and and save the used OMS. After a few days the gunk settles to the bottom of the jar and the good solvent can be poured into a clean container and used over and over again so not all that harmful to the environment. Just Sayin'.
#144
Quoted: 164 Post(s)
Liked 44 Times
mixing oil with wax defeats the point , first thing you could try is flipping your chain around , it might have got broken in in one direction and reinstalled the other way can cause some skips , ive been dirty waxing my chain all winter it take about 10 minutes !
#145
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
My wax experimenting is on pause at the moment because the wax mix (paraffin wax, paraffin oil and bee wax), I tried last, works pretty well. I rode over 150 km since the last waxing and experienced no skipping (with the temperatures down to -20C (-4F), mostly dry and compacted snow surfaces). The chain is quiet and shifting is smooth. I'm curious to find out how long one waxing will last.
The next things I'd like to try:
- add more bee wax to my current mix to improve the wax adhesion properties
- try a mix of the paraffin wax and transmission oil (3:1 or 2:1 proportion by weight) to test the theory that the motor oil is better than paraffin oil. I hope that the heated transmission oil is not too smelly. That will be a deal breaker.
- try a mix of the bee wax and transmission oil (2:1 proportion by weight). There's a Russian gentlemen that claims that this solution better handles rain and lasts longer. He claims, however, that the mix needs to be heated to the temperature higher than 100C to be thin enough to penetrate into the links. That would mean that I can't use crock pot and have to heat the mix directly on a stove and keep a close eye on it.
Here's the video of his method (it's in Russian but the subtitle translation is pretty good).
- try Molten speedwax. It's quite expensive comparing to the home brew waxes. But who knows maybe the MSPEEDWAX guys found the perfect wax
Why would you mix oil with wax? The entire reason to use wax is to lubricate the chain cleanly. Adding oil just makes a huge mess of it. A wet chain holds dirt and filth that gets on everything. Don't waste your time.
At one point I did add oil, transmission fluid, alcohol, mineral spirits etc. In an attempt to keep the mixture liquid at room temp. Its a waste of time. It takes too much carrier to keep the mixture liquid. Once the carrier evaporates it leave an insufficient amount of wax to lubricate things properly.
Paraffin oil or lamp oil is added to the mixture to soften the wax. If you use straight wax it is quite brittle, the application of pressure causes it to shatter and fall off of metal. Using the paraffin oil allows the wax to conform and bend which allows it to stick to the chain. And stay where it's needed.
I purchased A one quart slow cooker on Amazon for $10.00.
It holds twice as much wax as it needs to , to wax a chain. I have been using Tephlon with this batch but I can't see any difference in its use. I put the chain in and let it soak for 10 minutes , swish it around for a few seconds,, then I hang it over the pot to let the excess drip back into the pot. When it's cool.enough to handle ,I put it back on the bike.
As far as mileage, I have had chains go 400 miles on a single treatment. But I would stay around 200 just for safety sake. The chains noise changes when it's time for relubing. It gets rattly-er , more metallic sounding.
Kmc makes a "Stretch proof" chain. Don't use wax on it. It will not work with whatever they are coating the parts with. I was only getting 20 miles of zwifting before I needed to lube this chain due to the racket it made. I have swapped it out for a different chain.
Edit for additional; You need to clean all the shipping lubricant off the chain before you wax it. Leaving it on only contaminates your mixture. Mineral spirits in a jar works just fine for this. soak it briefly, give it a shake, remove it. let it dry. I use another jar with a degreaser and water, then rinse. Toss it in the wax.
#146
Quoted: 181 Post(s)
Liked 14 Times
#147
I wax my chain rather than oil it. I don't use anything special -- I use Gulf Wax, available at your local hardware store or supermarket.
I'm not a hardcore roadie or anything -- I commute just about everywhere in New York City by folding bike. Including work, so I need a clean chain.
It works.
And, to circle back to the topic of the thread, I haven't noticed anything different when I'm riding in sub-freezing temperatures. Not that the temperature here gets down to the Calgary range. But still, I ride often when the temperature is in the 20s (F). Seems to work fine. I know I'm not stressing stuff like a roadie, or riding hard enough to notice increased resistance or anything, but for me, it works fine no matter what the temperature.
It works.
#148
In my experience, adding less that 10% of paraffin oil to the mix makes the wax more pliable without making it sticky.
Adding 10% of the motor oil, on the other hand, does make the wax somewhat sticky. I should point out that I did not strip the factory lubricant from a new chain before using this new wax mix. So the stickiness could be blamed on the factory lube, or motor oil or their combination.
This "motor oil" wax smells revolting. I do not recommend using it indoors (again, the smell might be a result of factory lube contamination).
#149
Two reasons:
- There's a huge chain waxing thread on a Ukrainian biking forum that was started in 2014 and is still very active. Some of the people there strongly recommended the paraffin + beeswax + motor oil mix. I wanted to try it. I already had a mix (paraffin + beeswax + lamp oil/paraffin wax) that works well in extreme cold but lasts only for about 150kms/~100 miles (I ride a mid-drive ebike that puts extra stress on a chain). Lazynes is a very strong motivator - I was hoping that the "motor oil" mix would last longer. And, to be fair, it did. The chain was still quiet after 250kms, but I noticed that it gets dirty and rusty. It wasn't oily-sandy-grinding pasty kind of dirt. More like mud and soil stacked to the chain. The hot water rinse cleaned the chain pretty well. But the chain still had slight oily feel to it.
- Childish curiosity
How much paraffin oil did you add to the mix? And what kind if oil did you use (lamp oil/IKEA food safe wood treatment oil/something else)?
I use a crock pot for waxing. It came with a nice thick ceramic bowl, which heats and cools VERY slowly. I'm sure it's great for cooking. But not so much for waxing. It takes an hour to melt 200gr of wax. I might look for a crock pot with a stainless steel bowl.
I used KMC X9 chain with my first (with paraffin oil) waxing mix. The chain worked great, never had any rust issues with it.
Replaced the chain with SRAM PC-971, waxed it with the "motor oil" wax and the chain was all rusted within 150kms. I blame it on a lower quality SRAM chain but it's possible that the "paraffin oil" wax better protects the chain from rust.
You’re right. The factory lubricant contaminates the waxing mix. Therefore, I’m going to have two mixes: rinsing and waxing. Where the rinsing mix is going to be pure paraffin and will be used to strip factory lubricant and rinse a chain prior to waxing in a clean(er) waxing mix.
I know, this starts to sound a bit crazy … but who cares. In modern society, serious cyclists are considered somewhat crazy. And the waxers seen as nuts even among cyclists. So why not take it up a notch? 😊
I was using a similar cleaning routine: mineral spirit, degreaser, rinse in water, dip in rubbing alcohol for faster drying. It’s a long and smelly process. My girls dislike the smell of mineral spirit and I try to limit it’s use.
