Front derailleur adjustment issues....
Quoted: 1840 Post(s)
Liked 1,713 Times
Usually, when you order a crankset, the seller will include a recommended spindle length. If your current spindle is either too long or too short you can run into compatibility issues that can affect shifting.
You mention that you are considering installing a rear disc brake. This will be of limited benefit if your current brakes work well. Think about this: There are still some cars that have disc and drum brakes, but the disc brakes are always on the front wheels
Bikes: A Janky Schwinn
Quoted: 59 Post(s)
Liked 17 Times
After reading this and looking at that article mine looks odd. With the wheel off there is a lock ring that has to be removed to remove the sprockets. There are individual sprockets that have spacers between them and they slide onto a two-stepped splined hub. The article says that freewheel sprockets are bolted together. Mine are not.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1300 Post(s)
Liked 742 Times
Quoted: 59 Post(s)
Liked 17 Times
The bottom bracket I have will need a 36mm spanner to remove it. The removal tool I have fits a splined model. I want to get a new bottom bracket. This one grinds. The crankset vendor says I need a 110mm bottom bracket. More measurements to take but I need the bottom bracket out first to get good measurements. More too come.
Quoted: 3577 Post(s)
Liked 2,997 Times
We've got a guy replacing all the parts on his Huffy with Campagnolo parts. This sort of reminds me of that thread.
You shouldn't need to remove the BB to measure the spindle. But if you're gonna take it out anyway...
Quoted: 59 Post(s)
Liked 17 Times
I actually haven't bought anything expensive at all. The new bottom bracket is a Shimano and is $16. Not exactly top of the line.
Liked 2,997 Times
Likes For aaronM46:
Liked 2,997 Times
Looking forward to it!
