What C&V small parts would you like to see repopped?
Quoted: 1641 Post(s)
Liked 831 Times
Hoods for Spidel LS2 and Weinmann 400 Carrera brake levers....... they are almost unobtanium!
And what about those older, really small "chain catcher" screws that go on Stronglight chainrings. Other than scavenging them from old chainrings, I cannot find a direct replacement for them. The few newer ones that pop up at eBay are too big.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 15 Post(s)
First prototype just arrived today. Not quite ready for prime time, but very promising.
- John
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Something like this?:
Attachment 590589
- John
Attachment 590589
- John
Already done. Want some? I need to make another batch anyway. Couple people over on the Paceline are still waiting on 'em.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Quoted: 15 Post(s)
The problem with the original design is that it puts the Delrin under tension right where the two mounting bolt threads end. There is also bending stress in the same area, because of those little partial flats that touch the chrome clamp piece. The original has metal nuts molded into it so the threads are strong. It will eventually crack and break where the nut ends.
Aluminum or another metal is probably strong enough to survive over time.
- John
Moots mounts already mentioned, Campy blue rubber tips for a Silca frame pump, Blackburn handlebar bottle cage, and also as mentioned a modern version of Command Shifters
They seem so and are so easily lost (by me anyway) that I'm not surprised. Funny enough all three pairs of my old suntour bar end shifters aren't missing the bolt.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Man, there are some stellar lists going on here! What I can think of, in addition to some of the things already mentioned:
1) Hoods for various eras of Suntour (specifically Superbe and Superbe Pro, because, well, you know...) brake levers.
2) Hoods for more Shimano brake levers (late '70s-all '80s), including the AX/aero stuff (not that it looked that good or looked like it fit the lever body at all!).
3) Replacement freehub bodies and the freehub body removal tool for 740-era Shimano Dura-Ace units, for when mine dies and I sit there despondent with a pretty, and broken wheel.
4) Various single pivot caliper conical cap nuts for various companies. I am using Dia Compe BMX cones on my early Superbe calipers--they are super close, but could be closer.
5) Replacement parts for all Suntour Superbe Tech and Mountech RDs...stronger springs, please!
As for "modified stock," it would go something like:
1) New .833 quill stems in 26.0mm clamp size, along with a host of lengths. High polish or gloss black. My Super Le Tour 12.2 and I would be most happy.
2) Variable strength single pivot brake caliper arm springs (looking at you, Campagnolo!!), because nothing says counter-intuitive like a braking system that resists your efforts to brake...
3) Super dream: a vintage groupset that employs all the benefits of modern metallurgy, other materials, with new (shiny) finishes [I've worked off and on, on designing this].
elcraft
elcraft
https://i.ebayimg.com/images/i/32242...0/s-l140/p.jpg
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 643 Times
(A) hoods for Universal brand brake levers
(B) decorative cover place for the Simplex 543 derailleur. I have one option as I have two derailleurs and only one is missing the plate (fell off the one time I used it about 40 years back presumably because I did not tighten the retaining screw), and I recently found out a nephew bought a 3D printer, so maybe he can make one using the plate I still have as a pattern?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 787 Post(s)
Liked 521 Times
Quoted: 1830 Post(s)
Liked 3,385 Times
but maybe make them out of a softer white rubber, like the white Campy brake hoods?
I never figured out why they made those Carlton/Raleigh hoods out of such a hard rubber, nor why they gave them square corners at the bottom. They look nice enough, especially with white tape and cable housings (as on my '74 International, below), but are the most uncomfortable hoods I've used.
Steve in Peoria
Steve in Peoria
Quoted: 1613 Post(s)
Liked 2,599 Times
Not so old, but I should have bought a few when Jenson had them on clearance for $5. 6500 Ultegra faceplates.
Quoted: 787 Post(s)
Liked 521 Times
Steve in Peoria
Steve in Peoria
Quoted: 3811 Post(s)
Liked 6,719 Times
Well, I learned from a project last year that the black Carlton hoods are really hard to find. It's possible all of those white ones ate them.
Quoted: 7353 Post(s)
Liked 2,483 Times
@altenwrencher, I have one or three of those Pletscher plates. You want one?
Bicycle Repairman
https://www.mscdirect.com/product/details/08411076
Bikes: 1977 Raleigh Record, 1987 Schwinn Prelude, 1971 Raleigh Record, 1988 Schwinn Traveler, 1967 (?) Carlton Super Course, 1959 Huffy Sportsman 3 speed, 1972 Raleigh Super Course, yet another 70-something Raleigh Record
Quoted: 50 Post(s)
Liked 18 Times
Cones for Maillard hubs... okay, better than original cones for Maillard hubs.
