Tire Pressure
#151
Quoted: 3957 Post(s)
Liked 7,310 Times
The big thing to remember is that if you are the person that has to have your tires at the absolute max on the sidewall, temperature will change it a lot. Your say 120 pounds in your garage, will go a lot higher in the summer riding on black top roads. Black top roads can get burning hot, and then if hilly, add extra heat from riding your brakes down hills. On a 100 degree day, riding down a long hill riding the brakes can cause the tire to go bang. And that would happen probably at a good speed. You would actually be "bleeding" off speed with your hip and arm.
Likes For tomato coupe:
#152
Quoted: 6973 Post(s)
Liked 10,975 Times
Likes For Koyote:
#153
Quoted: 347 Post(s)
Liked 418 Times
It’s not the term for energy loss in the casing you really have to watch out for. As I mentioned, the slope of the surface impedance term above the break point is much steeper, so running too high increases the energy loss at a much greater rate.
Also, that graph is for a surface where the break point is 115 psi for a 700x23 tire. The surface impedances I ride on are a lot more.
Otto
Otto
F = Crr * W * d (where W is weight and d is distance)
To roll myself and my bike one meter (80kg together) requires force of 3.1N-m = 0.004 * 80kg * 9.8m/s*s * 1 m
If the Crr increases to 0.005 then the force is higher: 3.9N-m
In a TT I would be putting down around 260W, that is 260N-m force at the pedals at any instant. Meaning about 1.2% of the force is being used to overcome the rolling resistance for optimum tire pressure, and 1.5% of the force for the worse tire pressure. I think in a 65min TT it would result in ~11s penalty (~.3% slower), all other things being equal. Even if you're casually riding around at 100W your rolling resistance is still a minor factor as far as speed is concerned so you might as well make your tire pressure something comfortable.
#154
Liked 7,310 Times
Um no, it actually is really small? The rolling resistance coeff is literally the force required to move some weight some distance. We can find out how much force is required to over-come the rolling resistance.
F = Crr * W * d (where W is weight and d is distance)...
#155
If you want power, multiple F by your speed.
(~.3% slower)
#156
Quoted: 896 Post(s)
Liked 2,065 Times
I wonder why the rolling resistance guy doesn't throw a rough surface on his drum, even once, to experimentally address the topic of smooth drum vs relatively rough roads.
I expect the answer is, he's confident enough in his current results, and it's his test. But it would be nice to see data from a controlled environment on the subject.
Likes For dsaul:
#158
Liked 7,310 Times
#159
unless the wheel is suspended and weighted properly to simulate the system, there’s no point. A smooth roller captures the relative performance of tires on rough surfaces below the breakpoint pressure and if the wheel is fixed or not correctly mounted, won’t get the breakpoint right.
#160
Liked 7,310 Times
#161
Texturing the drum can theoretically allow you to characterize the hysteresis consequences of more complex tread deformation than a smooth drum, although it's not obvious how much value there is in practice with doing this.
If you're asking about characterizing consequences of inadequate suspension (i.e. due to overinflation), a typical drum setup won't do this because nothing is being suspended. Usually the wheel is just given some static preload before being locked in place for the test. No energy is expended deflecting things upward because that deflection isn't happening, and most of the loads that would be getting deflected upwards don't even exist in the system.
#162
Quoted: 3352 Post(s)
Liked 1,056 Times
Black top can get a lot hotter than you say. If you google it they say at 85 degrees black top can get to 140 degrees. What would it be on a 105 degree day???
#163
Liked 7,310 Times
#164
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
https://schwalbetires.com/technology...rolls%20better.
It's like riding a bicycle
#165
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
I’m amused to report that I had a flat mid-ride yesterday, replaced the tube, re-inflated until it seemed rideable and had what felt like a good ride home.
Turned out I was running the 700x32 rear tire at 40psi on what Silca would call Category 1 gravel. For my total weight, recommended pressure is more like 59 psi or higher.
I should carry a pressure gauge for these occasions.
Otto
Otto
#166
Liked 7,310 Times
Otto
Otto
#167
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
I have no issue with re-hashed threads.
A: As high as you can go without bouncing.
Higher pressure for the same setup always provides lower rolling resistance until the tire cannot absorb the road imperfections. Then lowering the tire until it can [absorb road imperfections] will provide lower resistance.
Likes For Doge:
#168
Quoted: 969 Post(s)
Liked 1,632 Times
DUH!!! I'll put my 2 cents in...
I run several different tires on the few bikes I have. Some are with big and some with thin small tires.
I look at the side of the tire where it's embossed the MAX and MIN psi for the tire and I subtract 5 to 10 psi.
That's it. If I need a change I am really not changing my pressure, I am changing my wheel set...
#169
Firm but gentle
We don't talk so much about rotating mass anymore. If you just want speed, look at what the pros are riding on good pavement. From what very little I see of pro races the pavement looks pretty nice (except for the obvious rough stuff). I ride pavement that is in good to excellent condition, I see no need for wider, lower pressure, heavier tires for everyday use. My biggest efforts are climbing at slower speeds.
Likes For venturi95:
#170
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
The only problem I see with that is that max pressure is often just what pressure the manufacturer is afraid the tire might pop off the rim, and has nothing to do with speed, handling, or comfort.
Likes For urbanknight:
#171
Quoted: 896 Post(s)
Liked 2,065 Times
I imagine marketing people in the bike tire industry are struggling. One upon a time the goal would have been to claim the highest max tire pressure the engineers and lawyers would allow. Now if you project that rock hard high psi image, you're excluding customers. Maybe claiming 90 psi or so is the sweet spot - but then say words like supple and smooth. If you want to attract the "I'm not a racer" demographic, then maybe drop that advertised max down to 70 psi and give it an adventurous name. People eat that **** up.
#172
Quoted: 2333 Post(s)
Liked 2,097 Times
I'd like to see the hystericalesis of a skinny rider vs a fat rider. The vertical motion isn't merely absorbed in the tire's carcass.
#173
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I learned a word today!
#174
Quoted: 4420 Post(s)
Liked 4,873 Times
#175
Liked 4,873 Times
Likes For PeteHski:
