The C&V Antiviral Thread
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
Yesterday was gorgeous in the northwest corner of Washington State. 'Got out for 47 miles after a few chores in the AM. Pic shows me taking a coffee break while soaking up the sun.
Dean
IMG_3921
Dean
IMG_3921
Roll Me Up and Smoke Me When I Die
Likes For Dean51:
Quoted: 3242 Post(s)
Liked 2,513 Times
If that's the case you better stay home while you're sneezing. I remember these two Bards back in the 80's telling a horrible tale about nasty creatures that only come out at night. They're called maneaters. They'll chew you up. The Bards names were Hall and Oates. I actually heard them telling the tale again the other night on Stingray Quello. Scary!
Likes For seypat:
Old fart
Quoted: 3593 Post(s)
Liked 3,401 Times
I scored a pair of campy aero pedals and now I am trying to make a set of toe clips for them. I am thinking I can just take traditional toe clips straighten the mounting flange, grind to the correct profile and drill some slots. It should make for a good afternoon and some bloody fingers.
Quoted: 964 Post(s)
Liked 1,451 Times
Hehe, that's great. Yeah, my trusty fifteen-year-old Topeak Road Morph attached to the top tube with a toe strap. A temporary solution, it interfered with my knees, so I got a Lezyne micro floor drive to put in a seat pack.
Starting with the cable. The nub/nipple appeared to be brass or bronze. It is soldered onto a "bight" (a u-shaped crimp) in the cable. You could solder two cables' ends in there, so you wouldn't need a very long cable. I made a reproduction nub myself, but it is hard because it's so small and incorporates a round tube with a square flange so requires turning and milling on a super small scale. I used a very flexible bulk 20-strand 1mm cable I bought on Amazon. This cable is similar to Campagnolo cables from the NR era, lots of strands and super flexible, but smaller in diameter than those Campagnolo cables. The original is definitely stiffer, and may work better, but it is smaller diameter than even a standard bicycle shift cable. You should be able to buy bulk cable like this as well, or use a tandem shift cable or two single-bike shift cables. Some people use a nub with a set screw, instead of soldering on. You could also make one of these and it might even be simpler. I've never tried so I can't comment on the efficacy, but it looks like it might stick a ways up out of the drum on the derailleur and that might be a problem. It might introduce a beneficial eccentricity to the drum (see below) or it might make things worse.
The key to setting up a Le Cyclo is to know that the cable slack changes through the range of the derailleur. This is because as the derailleur slides sideways, it changes distance from the cable guide under the BB. That is, its cable drum is a tiny bit closer to the bottom bracket cable guide when the derailleur is closer to the centerline of the bike. This of course happens when you're in low gear. You can envision a triangle between the BB cable guide and the two extremes of the derailleur's travel. Since the rod should be parallel to the axle, the derailleur is moving farther away from the centerline of the frame, perpendicular to it, the distance to the derailleur is longer the closer it gets to high gear. Because of this, the cable will be a little loose when you're in low gear and a little tight when you're in high gear, and you can't do anything about this. René Herse was so annoyed by this that by the early '50s, he had fabricated an eccentric shifter to compensate for it.
You can, however, use this to give yourself some cable slack to set up the derailleur the way you want. Here I'll explain what I do stepwise.
If you have any questions, I'm happy to help. It's hard to explain this without taking mine apart and taking pictures, but PM me if you want to talk on the phone or something.
+1 for Yojimbo! One of the few businesses that I'm super grateful for existing.
Just bought a bike that has one, but the PO cut the cable and took the derailleur off before shipping. So I'm looking for some good setup instructions and instructions for reproducing the cable. I have the old cut cable with the nipple, at least.
The Classic Lightweights site has some instructions but they're not very detailed.
- Make sure the two nuts holding the derailleur shaft to the hanger are snug, but loose enough to turn the shaft. Push the derailleur all the way to the stop on the big cog, and adjust the nuts so that the pulley lines up with the big cog. Now rotate the shaft so that the cable is wound around the drum such that it can pull the derailleur the other way all the way to the low gear. This should give you a lot of slack in one end of the cable. Snug up the nuts.
- Attach the cable to the mounting block in the lever. Leave the screw a little loose. The cable should go once around the lever drum. With the lever still mounted on the frame, move the lever to one extreme (depending on your preference, you might want the lever all the way back or all the way forward. I think Herse used forward as low gear, but I like forward as high gear). Pull the cable as tight as you can get it.
- Take the lever off and pull the cable a little tighter. Snug up the screw that holds the cable in the block in the lever. Put the lever back on the frame. You should just barely be able to get it on. Try to shift through the range. If the cable seems too tight like it's binding up, take the lever off, loosen the screw, and give yourself a little more slack. Iterate this process until you've got an acceptable compromise in cable tension between low and high gear. It's not gonna be perfect. You're going to find that it's slightly too tight in low gear and slightly too loose in high gear, and that's just the way it is.
Hey Patrick,
I most often buy from a seller yojimbogarage on eBay. He’ll cut to your length and Wheelsmith DB14’s are usually around $1 each. I’m sometimes able to find cheaper than that but it’s hit or miss on availability. If you’re thinking of a straight gauge spoke, drop me a line with length. I have a bunch. I’ve been thinking about a wheel build because I find it pretty relaxing.
Quoted: 964 Post(s)
Liked 1,451 Times
Better yet, treat them right and get some MKS alu toe clips. These'll cut and bend like cheese.
Quoted: 1136 Post(s)
Liked 650 Times
scarlson Thanks for the detailed info! I'm trying to get ahold of a copy of Bicycle Quarterly issue 14, which I'm told has an illustrated guide to the setup, but if I can't I'll just go ahead and try it with your instructions and the illustrations from Classic Lightweights and let you know if I have any issues.
Quoted: 85 Post(s)
Liked 74 Times
On mandatory telework. Before starting time and on lunch breaks I’m finally building up this 1981 61x. The seat tube wrap is not oriiginal- the bike had the old school individual T R E K logo, but only on one side of the seat tube. Next challenge is finding an above the bb cable guide — there’s one somewhere in my workshop.
Likes For Whit51:
Quoted: 767 Post(s)
Liked 1,898 Times
Likes For BFisher:
Quoted: 767 Post(s)
Liked 1,898 Times
seypat I hate when that happens. I've put orders in to online shops only to realize a few days later that they have another bit I need that I could have just tacked on.
Liked 2,513 Times
Likes For seypat:
Liked 2,513 Times
Likes For seypat:
Quoted: 226 Post(s)
Liked 309 Times
Thanks! This new-to-me bike is a '95 Trek 5500 in Campy 8-Speed Record / Record Ti trim. A bit unusual is the "SATURN" decals vs. "5500". Research, including here at BF, suggests it was a promotional model, not a Saturn team bike.
Dean
Dean
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
I've done this. Most metal toe clips are tempered steel, which is nigh-on impossible to drill into with normal twist drills, can't be touched with a file, and may crack when bent. Grinding it with a high speed abrasive (like a dremel or angle grinder, what can throw sparks) would be ok, but if you want to have more success in bending/drilling/grinding/filing, I recommend annealing the metal where you want to work it. Simply heat it to red hot (a propane torch or even a gas stove burner should accomplish this) and then let them air-cool. This should make the metal easier to drill into and bend without cracking.
Old fart
Liked 3,401 Times
The only aluminum toeclips I've had that lasted more than a single season are the Campagnolo ones that you pay through the nose for these days. There's nothing wrong with plastic toeclips. They're light, they don't rust, and they don't break. The ones on those Sintesi pedals in my picture are over 30 years old and still going strong.
Quoted: 887 Post(s)
Liked 335 Times
I rode (in a truck) with a friend to purchase blue crab trotline materials. He plans to introduce his grand daughter to trotlining this summer. It's not bike related, but it is C&V. More info here:
https://fishtalkmag.com/blog/three-w...your-own-crabs
Likes For BFisher:
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
Likes For daviddavieboy:
aka: Dr. Cannondale
Quoted: 2156 Post(s)
Liked 3,411 Times
I'm just riding every day and keeping this in mind:
minimalist cyclist
Bikes: yes please
Quoted: 1120 Post(s)
Liked 1,643 Times
^^^ re your bike stand, I just came into a lot of scrap lumber being thrown away in my neighborhood and salvaged the 2 x 4's - pulled the nails out, hit it with a axle grinder sand pad and made a similar stand. I'm making some for friends, but also have enough I might try to sell some on craigslist $10 each or 2 for $15 ???
^^^ 90's version
^^^ We're still doing small group rides of 4 or 5 out on low traffic country roads. Very therapeutic...but who else is having to deal with recently fertilized fields of turkey / chicken ****
Likes For Deal4Fuji:
No one cares
I have moved my home office to my loft, which is also my bike area. In between meetings i swapped the saddle and cleaned the chain on my JT TOB.
I prefer emails to private messages - holiday76@gmail.com
Jack Taylor Super Tourer Tandem (FOR SALE), Jack Taylor Tour of Britain, Px-10, Carlton Flyer, Fuji The Finest, Salsa Fargo, Santa Cruz Tallboy, Carver All-Road .
Likes For -holiday76:
Likes For Whit51:
Quoted: 2588 Post(s)
Liked 4,827 Times
DD
Likes For Drillium Dude:
Liked 4,827 Times
Nice day for a ride:
DD
DD
