Was this cheating?
Was this cheating?
Just a question in the past Tour De France with Lance Armstrong.
It is the question of the one where Lance avoids crashing with another rider by cutting across a field to the road on other side? how come this was let go, did he get a time penalty for this? since he cut the course?
Here is the link to this
So tell me more about this. since he did take a lead over other riders on this stage?
Ninny
No penalty because he didn't benefit from the shortcut (he ended up further back than he would have been otherwise).
Beloki on the other hand received a significant penalty. Part of his leg is still embedded in the tarmac, which is why that turn has henceforth been called the "Beloki femur."
Bikes: 2017 Ridley Noah SL - Candy Apple DA9000, 2011 CAAD10 Berzerker Ult6800, 2013 FOCUS Mares CX Ult6800
Perhaps it was a legitimate question, given the fact that the rules do state one cannot shorten the course. Benefit of the doubt to the OP may apply here - the same benefit that Lance was given during this particular stage, for a 'shortening' that was outside his control and deemed to be fair play on his part....
cheers
Announcer
I'm sure the commissaires spent time discussing it after the race. They may even have fined him 50 Euros.
I've sat in on those juries that take place immediately after the finish where they dissect every little thing that happened in the stage. Sometimes it becomes a competition among officials to show how much they know.
And this little run-off would give them tons of fodder. They'd call up every single rule that applies and then debate it for several minutes before declaring it a non-violation.
Bikes: 1979 Raleigh Team 753
Liked 372 Times
Seem lately that these rules are frequently cited at the starting line, just before the race almost to get the rider nervous, then nothing done. It develops a big callous as to really listening to rules that will be enforced.
Racers learn what they are allowed to do and do that - not what the rules
Maybe in 12 years they will nullify his race wins when they see this on video, with an official allowing it - it can't be cheating.
Examples:
-Right before the TT start in VOS - referee to my son. "Is there any reason your bars are not round?, Rules state no clip on or aero bars." (they do state that). Same type of bars he used last year. He was allowed to use them last year, this year - so why ask.
-Big call out on the start line about crinkled number. So we always (400+ races) take the number and put it in a ball and then flatten it out. The primary SoCal promoter decided to call him out on the start line of the State Crit and everyone had to wait about 5 min to start. Then...nothing happened and we all started. And we/he still do the same thing with the numbers.
-"No tolerance on the centerline rule" - I see not being reasonable and allowing crosses on corners and when bumped.
Examples:
out walking the earth
it makes it hard for the camera to pick up the numbers. learn to pin properly. if you can spend a whole day worrying about what your kid's VO2 max number means surely you can invest enough time to pin him properly.
Horner was in violation at Snelling, I should've reported him.
Version 7.0
Pinning numbers properly is an advanced racing technique.
Liked 372 Times
It is cheating when it is against the rules, known about by the participant and ( hidden from an official OR penalized by the official).
Here are two...which if any are cheating?
1 Son does a TT. I think he has junior gears, he thinks he has junior gears. Officials don't do roll out. Two weeks later I am changing cassette and find its one that was used for training and was not legal.
2 Son does Brentwood crit. He wins. He does rollout. He does podium. He says to me it looked like he failed but the referee didn't say/do anything. I look at home - he does not have junior gears.
It doesn't matter. Things are stopped when they are BOTH rules and enforced.
Liked 372 Times
I taught both of my kids not to be covert and to respect the officials ruling. That goes both ways - when they judge for you and when they judge against you.
Version 7.0
USAC
Rule 1J7. Racing numbers.
Hip numbers shall be attached securely at least at the four corners and no accessory or hair may obstruct a clear view of the number.
I use 3M 77 and 4 pins to comply with Rule 1J7. My goal when showing up at the line or technical inspection is to be totally complaint with all the USAC / UCI rules. That way there is no pressure on me at the starting line or during the race to have to debate, discuss or anything else with officials. Sometimes USAC / UCI officials get it wrong but it is up to the racers to be compliant.
Liked 372 Times
Ditto - except we don't follow rules that don't apply to the race - for example UCI rules at Chico SR are not applicable.
My son is compliant with 1J7 - all the rules.
The numbers are not folded - they are flat on his back and very readable. They are not defaced. All corners are firmly attached.
