View Poll Results: Who do I blame?
Speedplay - they suck
8
15.38%
You. You need to glue your screws in place or something.
21
40.38%
Adidas. Your shoes are the problem
5
9.62%
Blame wear and tear. After 18 months it's time for more stuff.
5
9.62%
Blame no one. Forget about it and keep tightening screws
13
25.00%
Voters: 52. You may not vote on this poll
Cleat keeps coming loose. Who to blame?
Not obese just overweight
Bikes: Trek 7500fx, Cervelo Soloist
My left cleat keeps coming loose. This is huge pain in the butt because I have Speedplays, which require removing four screws just to get at the screws that go into the shoe. This happens about every month or more frequently. This is very annoying. Who do I blame?
Je suis ici !
Bikes: 2006 Scott Speedster S20, 2005 Trek 7200FX, 1988 White Cannondale Criterium Single Speed Conversion, 1986(?) Peugeot...I don't know what model it is, but it's a road bike
I have about 4000 miles on my X5s and have never had a problem. Well, I did have one problem when I unclipped, got off my bike and stepped in some mud.
Guest
Posts: n/a
I have Zeros and sidis. Two sets. Both are setup perfectly now and I never have issue with the base screws. I would suggest it might be more to do with your shoes and the threads in the sole rather than the speedplays.
We have rough, old roads here and I'm heavy at close to 190 pounds, so just stopping at lights mean Speedplay screws are constantly grinding small stones to bits. Speedplay's brilliant engineers have chosen not to recess the screws, meaning they intended the screw head to be a point of contact with the road. This means the screw heads are often filled with tiny bits of rock and gravel.
I don't check my brake cables before every ride. That's stupid. I've ridden close to 70k miles and have never broken a brake cable. Usually a couple times braking during my warm up let's me know the state of my entire braking system. And no I don't pay anyone to maintain my cleats on a daily basis. After having no maintenance cleats for many years, I'm not about to spend 5 minutes per ride checking my cables and cleats.
Road, MTB and SS Rider
Bikes: Trek 5200, Yeti Kokopelli, Clockwork
You can't consider user error a catastrophic failure. If you don't properly secure the screws then of course they are not going to remain installed.
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Liked 317 Times
Which Speedplays do you have? Do you want to sell them for cheap? I've got Loctite...
Never try to teach a pig to sing...
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
I don't know what you are talking about... my screw heads do recess into the cleat. However, when the metal plate wears down, the heads to become exposed. I replace my cleats when the phillips slot on the head starts to wear down to the point where I won't be able to use it... or about 5,000 miles as the instructions say.
FOR SALE CHEAP! Comes with new cleat covers!!!
I don't coddle or protect mine. I wear the cleat covers when I get to my office because I have to walk up stairs made of concrete and polished river rock (I want to shoot whowever designed that!). I've replaced mine I think 3 times this year but I've ridden 18,000 miles so I can't say I'm surprised...
Have bike. Will travel.
Bikes: '06 Orbea Orca, '03 Rocky Mountain Vertex 70, '05 Surly Steamroller, '06 Fetish Fixation
Maybe your cleats are defective. Maybe your shoes are defective. Either case, it doesn't seem to be a global issue. I've never had that problem either
Guadzilla
Bikes: Pinarello F4:13 W/Campy Reecord & Blue RC6 W/SRAM Force
QFT
Thats the reason I ditched Speedplays. Dealing with the cleats coming loose was too much of a hassle. Not to mention trying to walk with those cleats is like trying to walk with two bricks under your toes.
How much does it weigh?
Bikes: Lotus Fixed, Bianchi Virata 2004
You shoulda got Bebop pedals from the start. Pedal systems designed around the idea of plastic holding your cleats in place is bound for failure.
I never had any problem with the Eggbeaters -- ZILCH, ZERO -- but didn't trust them for sprinting. I'll ride those while I wait. Never had problems with the old Looks either. Toe straps? No problems either.
Speedplays are prima donna BS.
Sensible shoes.
Bikes: A few.
Joe I guess you draw the line at pedal systems, but how do you feel about proper set-up and maintenance with other systems on the bike? I maintain my Speedplays like the drivetrain they connect to: good set-up, periodic cleaning and lubrication, and the occasional adjustment with, perhaps, annual replacement of wear items.
Just a thought.
Just a thought.
