Road bike: short legs
Bikes: Trek 1.2 2011 => Trek Emonda ALR 4 2017
Quoted: 73 Post(s)
Hi - I want to ride a road bike with drop-off handlebars, but my problem is I have short legs: I am 5'9" (175 cm), but my inseam is about 30 inches. I've measured it and got my first [used] bike: Trek 1.2 52cm. It fits me fine in standover, but too short in top tube. I've tried gazillion of other bikes - the ones that fit me in length are too high (press on my private parts), and ones that fine in that area are too short.
How do I solve this problem? I've tried to find bike with the right geometry, but found no models made for me. Did I miss something?
Some recommended to get longer stem - I tried, but something did not feel right. Any idea what was that?
The third [maybe stupid] option I am thinking is get a frame if a hybrid bike and built a road bike from it. Anyone has experience doing this? Is it at all worth considering?
I am rather new to biking, so any help is appreciated.
P.S. I want my drop-off handlebars
Silver Comet Fred
Bikes: 1
Quoted: 8891 Post(s)
Liked 3,053 Times
You might want to have the mods move this to the "fitting your bike" forum to get better responses. No offense to other respondents. I am the same size as you and I ride a 54 which might be your problem - the frame is too small. Get the right size frame and that solves your problem. Since that can't happen, unless you want to buy a different bike, my guess is the longer stem and saddle fore/aft position would be where to start. Good luck.
Quoted: 20810 Post(s)
Liked 9,456 Times
Look for bikes that utilize compact geometry, like Giant and many of the Specialized and Trek offerings - the sloping top tube will give you more stand-over height for a given top tube length. If the top tube length still isn't enough, and the next size up doesn't give you enough standover, get a longer stem.
Quoted: 73 Post(s)
I've tried "sloping" women's models (Trek Domane, Liv Avail) -- they're one size better (54 is ok on inseam) - but is still too short.
Quoted: 1814 Post(s)
Liked 923 Times
I have similar proportion- 6' tall, 32" inseam,
and fit a regular size (56 cm) without issue.
That's a lot of bikes to have tried if you're new to riding!
Bikes: Surly Disc Trucker, Ribble Nero Corsa, Surly Karate Monkey, Surly Ice Cream Truck, Cannondale MT800, Evil Insurgent
Quoted: 186 Post(s)
Get yourself a 130mm stem and be done with it. A 52 cm bike comes with a 90-100 mm stem. You'll have your long top tube in no-time.
You could get a bike with compact geometry, but then you have to ride an ugly bike.
Quoted: 18423 Post(s)
Liked 4,540 Times
Your standover height makes absolutely no difference once you're sitting on the saddle. You really don't need any clearance when standing over the frame. You'll learn to mount without mashing something that shouldn't be mashed. Also make sure you're testing the bike wearing your cycling shoes. You're not going to be riding it barefoot are you?
As twodownzero mentioned, a 52cm frame with a 130mm stem will fit you almost like a 55cm frame with a 100mm stem. You can do a lot of fitting adjustments by changing stems. And, if buying the bike at a local bike shop, they should be able to swap stems for free, as well as let you demo the longer stem.
With some luck, you should even be able to find a 140mm or 150mm stem, perhaps even longer.
The Pro Racers often rider smaller frames with long stems to achieve more saddle to bar drop.
As far as conversions. I did do a 26" MTB to 700c road conversion a while ago. It made a most unique bike. Short in height, long in length. Moderately low vertical clearance for rear wheel, but LOTS of width. It also required a wider (vintage MTB) crankset. Road Fork.
Advocatus Diaboli
Quoted: 4760 Post(s)
Liked 1,539 Times
Silver Comet Fred
Bikes: 1
Liked 3,053 Times
Kit doesn't match
^ Agreed. I know it might seem crazy, but if you can forget about standover, you'll actually get a bike that fits. And you'll get used to not being able to flat-foot the thing on both sides if that's how the result.
The trade-off, though, is getting a bike that fits you properly when you're riding it rather than straddling it, as @brianmcg123 wrote.
Quoted: 73 Post(s)
Guys - you are generally right about ignoring standover, but I ride in Manhattan (to work), so frequent stops and I need to have my feet on the ground. Therefore standover in kinda important.
Will look at that Giant TCR, and in a mean time play with stems.
No it isn't.
Liked 9,456 Times
I commuted from Brooklyn to Manhattan for several years and I have similar proportions to you, except I'm a few inches taller. You're making this a bigger deal than it is - it's shouldn't be that hard to find a compact or semi-compact that allows enough clearance (it's not like you need an inch air space or anything crazy) and can be paired with a stem of a reasonable length (probably 20-30mm longer than stock) to give you the reach you need.
Kit doesn't match
I'm not interested in suggesting what I think you should do -- that's up to you, of course. Just trying to help you get a bike that fits well and to get past a common misconception.
Good luck.
If planning to stop with both feet down at every light best hope you don't cross paths with BikeSnob and end up on his blog
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
6' here with a 30" inseam. I ride a 58cm endurance road bike. And I am not sure that any type of stop I have ever had both feet on the ground at the same time. Right foot clipped in, bike leaning a bit to the left because that foot is down. I thought everyone did a variation of this?
Quoted: 7666 Post(s)
Liked 3,539 Times
Quoted: 943 Post(s)
Liked 20 Times
I know that you are kidding with me, but in all seriousness, I keep my right foot clipped in because that is my stronger leg, and I am often riding a high gear ratio fixed gear on the street and when the light turns green, I need to be able to get going quickly.
Liked 4,540 Times
What's this about unclipping for lights? I thought one just slowly rolls up to the lights with both feet on the pedals, then when the light changes, stand up and sprint to beat the next dozen lights
I'm 5'10, with shortish legs. I bought a 60cm bike with a horizontal Top Tube when I was 16, and rode it for decades. I never thought about it being too tall until I joined this forum a couple of years ago. I don't think about flat footing it. I tend to sit with one cheek on the TT, one foot on the pedal, and one on the ground, ready to roll. I suppose standover is tight, but not uncomfortable.
If I had it to all do over again, and to roll time back 35 years... I'd buy the same bike. And it has had a lot of commuter miles.
In recent years, I've built up a couple of bikes. I try to target 60cm or less. Perhaps somewhere around 56cm. Each bike fits just a little differently. I don't have any magic fit size. I have been working on a little extra bar drop, so a shorter head tube is nice. Thus, I'm not a big fan of the sloping top tubes (along with vintage appeal of horizontal TTs).
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Best bet with short legs is to purchase two frames and combine them. Buy a small frame and glue it to a large. That is the benefit of carbon fiber, you can glue it together like a stick model.
That way you have the standover of a small and the reach of a large. Sometimes combining frames is the best solution and ironically combining two frames also satisfied those with long legs but typically requires smaller wheels.
