What would be a good touring cassette.
Two H's!!! TWO!!!!!
Originally Posted by George_McClusky
I want to change the cassette out to either 11-32 or a 11-34. Which one would give me a noticeable difference.
Someone told me I wouldn't gain that much changing from a 28 to the 26.
So, the bigger the number, the harder the gear and the smaller the number, the lighter the gear. Knowing this simple formula you can calculate and compare gear-inches yourself and see exactly whether replacing the cassette or one of the front rings will give you better ranges and by how much.
Do I use too many commas?
Bikes: Giant Yukon SE
I have a 28/38/48 crank and 11X34 8-speed cassette on my commuter. I couldn't ask for anything better. My 40 mile round trip includes a total of 3125 ft of climbing. There are times when I am tired that I love that 28X34 Granny!
Hi WillisB,did you have to add links to make it work.Thanks
George
George
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Originally Posted by chephy
Well, no wonder. If you think changing chains every 3000 miles is excessive.
If you actually change chains before they stretch all to hell, you'll have a cassette that'll serve you for a long, long time. (Chains are a lot cheaper and easier to replace than cassettes. )
I don't use chains that are excessively worn since I don't relish the idea of walking out of the woods while mountain biking nor trying to ride a single speed while touring. I don't keep track of how long I use them since I have several bikes that I use all the time but I do check them for wear on a regular basis.
Stuart Black
Stuart Black
Liked 7 Times
I'll probably need a new Derailleur with a long arm for the rear as well?
Al
Bikes: canondale silk trail--92 schwinn criss cross--sun atlas x type--fugi odessa--2018 trek domane ALR5 disc
Quoted: 47 Post(s)
George-- If you want to try out a differrent cassette go for it. If you don't have a bike stand just flip the bike over on the seat and handlebars and run the bike through all the gear combinations after changing the cassette. If it doesn't bind up and shifts ok give it a spin around the block. If your chainrings are not 3 seperate rings bolted together you will probably be better off changing the cassette. The hill country will be fun. Hope you got some of this 70 degree, bright sun, no clouds, no wind weather over your way today. Happy New Year.
Hey thanks carlton,my son works down in your area sometimes and he wants me to go down there,but I looked for state park bike paths, but the ones I found weren't very long. One more question before I order the new cassette. How can I tell if the chain is to short,(still learning) I'm thinking I'll try the 11-34 or the 12-34. I just put a Sram PC 48 chain on, what size would I need to do this thing right. Thanks everybody for your replys and have a happy new year,George
George
George
Quoted: 1572 Post(s)
Liked 643 Times
Originally Posted by WillisB
However, I cannot use the big ring - big cog combination. The chain is too short for that. (Not that I would anyway).
Say you're breezing along with a tailwind in your big chainring. Everything is going your way. You come to a little hill and you decide to just sprint up it. You shift down and feel a little resistance but attribute that to the hill so you bear down a bit more.
SURPRISE!!! That resistance that you felt was your chain not wanting to go onto the biggest cog. Something had to give and the easiest thing was the derailleur cage which is now lodged among your bent and broken spokes.
Quoted: 47 Post(s)
George--I believe you current setup is a 11/30. If your current chain is the correct length and it should be if every thing shifts right and you go with a 11/34 you would need to add 4 links to your current link count. 5 extra links should do it on the 12/34. Buy a 8speed chain since you have a 8 speed cassette. Most new chains are to long when you take them out of the box. You will need a chaintool to trim it to fit. Your LBS will trim it for a couple of $ if you don't want to do it yourself. You will also need a couple of tools to remove the cassette. A chainwhip and a cassette lockring remover. If you go to Park Tools website they have an excellent do-it yourself section. It shows how to do it and what tools you need.
I ride mostly on the street here in CC. Along the waterfront for the most part. There is an area just below Lake Corpus Christi that some of the locals go to trailride. Sorry I don't know much about it.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Originally Posted by cyccommute
Everything I've ever read, and my own experience, has always said to change the chain and cassette at the same time. Even short duty cycles on my chains (changing length with gearing, upgrading chains, etc.) of only a few hundred miles have resulted in chains that skip on certain cogs, i.e. the ones I use most. Until now I've never run across anything that said otherwise.
Quoted: 47 Post(s)
Happy New Year.
Quoted: 47 Post(s)
Originally Posted by BluesDawg
This goes against all I have heard or experienced. Definitely change the chain whenever you change the cassette or freewheel, but if you change the chain before it stretches, you should go through a few chains before needing a new cassette or freeewheel. Stretched chains are what wears out cogs.
Happy New Year.
I called a few places and all I could get is the 11-32. I'll put it on tomorrow and I hope it works out. Thanks for all the help.
George
George
Year-round cyclist
I read the original message. You live in Texas, which, if my memory is correct, is rather flat or gently rolling, but with a few steep climbs here and there.
I would probably keep the original cassette, unless it's worn out. If you want to change the cassette, check that the upper pulley of your rear derailleur can be adjusted to float down 4-5 mm away from the "30". My guess is that you might not have enough clearance there to run a 32 without lots of noise, and certainly not a 34. To use these larger cogs, you would likely need a mountain derailleur (ex.: LX or XT), which also has a long cage, but which moves DOWN as it moves inboard.
On the other hand, I would suggest you replace the small ring with a smaller one. You could go for 26 or even for 24. I see four benefits of going that way:
- No front or rear derailleur compatibility issue. IOW, no more money to spend
- Your chain will be long enough. No need to change it, until it's worn and needs to be changed (i.e. as usual).
- You'll get much lower gears that way. Basically, with your present 28/30, you have 25,2 gear-inches. Alternative gearings would give you:
28/32: 23.6 gear-inches (front / rear, assuming 700c wheel)
28/34: 22.2 gear-inches
26/30: 23.4 gear-inches
24/30: 21.6 gear-inches
- By having 48-38-24 in front, you'll keep relatively close gears for flat or gently rolling terrain, which is likely to represent most of your riding. And you'll have the really low gears when you need them.
Quoted: 241 Post(s)
I think the algorithm of selecting a cassette should be like this:
1. Find a "sweet spot" - the most used chainring/cog combination in your current cassette.
2. Find "extremes" - the maximum and minimum chainring/cog combinations that you use for ascending and descending the steepest hills in your area.
3. Get the gear ratio from www.sheldonbrown.com/gears
What we get for your bike:
For 700 X 35 / 35-622 tire with 175 mm cranks
With 8-speed "ak/an" 11-13-15-17-20-23-26-30 Cassette
48 38 28
11 8.6 6.8 5.0
13 7.3 5.8 4.2
15 6.3 5.0 3.7
17 5.6 4.4 3.2
20 4.7 3.7 2.8
23 4.1 3.3 2.4
26 3.6 2.9 2.1
30 3.2 2.5 1.8
So your lowest gear ratio is 1.8.
4. If you get an 11-34 cassette, the lowest gear ratio will be 1.6, not a big difference.
5. If you buy a new mountain crankset 42/32/22, the lowest gear will be 1.3.
6. Now you must consider the "sweet spot". For example, you like the 48/20 combination. The gear ratio for it is 4.7. It's better to have it in the middle (in other words, to create a straight chain line from the front chainring to this cog) of a new cassette and don't have big gaps between it and the adjacent bigger and smaller cogs in the number of teeth.
7. The highest gear ratio is 8.6. Do you really use it? Maybe, it's better to get a cassette that starts from a 13t cog.
48 38 28
11 8.6 6.8 5.0
13 7.3 5.8 4.2
15 6.3 5.0 3.7
17 5.6 4.4 3.2
20 4.7 3.7 2.8
23 4.1 3.3 2.4
26 3.6 2.9 2.1
30 3.2 2.5 1.8
After getting the new 11-32 cassette I was anxious to put it on. The specs on my bike said I had a 11-30 on my bike,well it had a 11-32 on it already. All I can think of is the LBS upgraded it to the terrain we have around here. I took the other cassette back and talked to the mechanic. He seemed to think that I could put a 11-34 on with no new chain or adding links because the chain I put on was setup for an 11-32 anyhow. So I guess I should try what I have in the hill country and see how I do. If it doen't work out then I'll try the 11-34, if that don't work I'll start on the chain rings. They told me that I couldn't just change the cogs out, but the one I took back fell apart when I was putting it back in the box. That got the wheels in my head going again. If I knew what gearing would work smooth I'd probably try and build my own. I better just leave it alone. Thanks again everybody.
George
George
Two H's!!! TWO!!!!!
I've yet to encounter any book or website about mechanics or cycling in general that recommends always replacing chain and cassette together. Maybe that's the only thing that works for your situation (lots of hill, lots of mashing, lousy chains, lousy cassettes?) - I am not telling you what you should do. But this chain + cassette simultaneous replacement is far from the general rule you're making it out to be.
Based on my experience, I still feel that carlton is lucky to not have a chain that pops all the time.
Perhaps where he rides, he doesn't put as much torque to the chain as I do because he doesn't have to climb mountains on a regular basis.
