Emergency braking will wreck your tyres instantly?
#51
Quoted: 980 Post(s)
Liked 582 Times
20 years of daily commuting (25,000 miles) in Chicago. I use my rear brake almost every time I use the front brake. I've learned how much to use each brake to get optimal stopping.
Here are a couple graphs from the book, Bicycling Science, 4th Edition, by David Wilson and Theodor Schmidt (MIT Press; Cambridge, MA 2020). These are from a study by J. Lieh published in Human Power eJournal in 2013 using a computer model.
Briefly, for an upright bicycle, maximal braking is achieved using both front and rear brakes optimally; however, the advantage over the front brake only is small. The book indicates the rear brake contributes only about 10% of the braking force. For a recumbent bike, the difference is quite large, with both front and rear brakes used together providing the shortest stopping time.
This is the graph for an upright bike. A small advantage accrues from use of both brakes together.
Quite a difference on a recumbent.
#52
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
which is less expensive.. a tire or a hospital bill? and that tire looks like a piece of garbage.... Meanwhile, the charts and dictionaries are getting dragged out..RUN! HIDE!
Guys..the OP has responded ONCE to Defend himself.. let it drop, ok?
#53
That supports my view of using the front brake only, no? With that kind of microscopic difference what's the point?
Stopping from 50 km/h to zero is less than two seconds is some kind of balls to the wall braking...
Likes For Yan:
#54
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Not every braking move is an emergency stop, that's the difference.
#55
What twaddle. There are lots of circumstances where rear braking is better - for example descending winding mountain roads - braking with the front screws up the bike handling around the switchbacks. Experienced cyclists know this.
About you second point: if it works for emergency braking then it works even better for regular braking. Why work your right hand when it is making such little contribution to stopping power? Just relax and let that hand rest, be kind to your body parts.
Likes For Yan:
#56
Quoted: 980 Post(s)
Liked 582 Times
It says in the graph that when using both brakes instead of front brake only, the stopping time from 50km/h to zero is improved from 1.95 to 1.9 seconds.
Feel free to not use the rear brake!
#57
It's MY mountain
Liked 2,981 Times
You shouldn't be braking around switchbacks. Brake before the turn and then accelerate through the turn. The rear brake is for heat management in long descents, for low traction scenarios, and for backup in case your front brake fails. It's not there to be used on a daily basis. Most people do not do mountain pass descents when commuting. If you do you are in the extreme minority.
2. This thread is not exclusively about commuting. Your response is irrelevant.
3. Your advice about non-emergency braking is pabulum.
I apologize for being blunt - I've had a lot of robo-calling telemarketers trying to sell me all manner of baloney today and my otherwise genial nature has soured somewhat.
#58
1. Braking around switchbacks is sometimes necessary and all riders should know how to do it. Your response is twaddle.
You clearly have a lot of opinions. You think I'm wrong, I think you're wrong, simple as that. No doubt both of us are experienced cyclists and our experiences have led us to different conclusions. I have no problem with that and how you operate your bike is not my concern.
We have both presented our respective views and the OP is now able to read and make up his own mind. Ultimately using one vs both brakes makes basically no difference to stopping distance, so the entire topic is simply trivial. The end.
For anyone else who wishes to read more about one vs both wheel braking: https://www.sheldonbrown.com/brakturn.html
#59
Really Old Senior Member
Their ignorance is deafening or they are a inept troll.
#60
Quoted: 3513 Post(s)
Liked 2,927 Times
#61
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Careful there. You’re going to be asked to leave a very exclusive club and forced to join the rest of us
Stuart Black
Stuart Black
#62
Liked 2,927 Times
A day without Bill K. shouting to the world that he’s adding someone to his ignore list is like a day without sunshine!
#63
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The theory behind ABS is vehicle control, not maximum braking. ABS allows one to maintain steering control, but it increases stopping distance. Maximum braking/minimum stopping distance is achieved via threshold braking (the point just before lock-up)...ABS takes the vehicle to the point of threshold braking, then releases the brakes momentarily, then reapplies, then releases, etc.
