9 Speed VS. 10 Speed (Dyna-Sys) for Bicycle Touring?
There is some progress but not by that much. If you take nearly identical cassettes and chains the 10 speed will be less durable. It is not like they have vastly changed the metal compounds they are using for 10 speed. Thinner plates on a chain will surely take more stress from shifting and grit and grime.
Again I am not saying a huge difference but there will be some.
I know it's hard to accept, because it is received wisdom around these parts that newer = more delicate, but it's not true, at least when it comes to 9 vs. 10 speed. Whether it's appropriate for touring is really up to the individual, but the argument that it's going to wear out sooner isn't a very good one. I would say if someone is equipping their touring bike with tech as new as 9 or 10 speed shifting that they shouldn't worry about it and just go with whichever one is easier or cheaper to get their hands on. If I were planning a trip for next week, I wouldn't hesitate to use the 10-speed gear I have on my current bikes. It's going to work great and last as long as anything else out there.
TL;DR: a modern chain is a highly engineered component like any other, and a 10 speed chain is a not a shrunk-down 9-speed chain is not a shrunk-down 8-speed chain. Wear life is affected by materials, engineering and manufacturing process improvements, not number of speeds.
Bikes: 2012 Masi Speciale CX : 2013 Ghost 29er EBS
9 Speed VS. 10 Speed (Dyna-Sys) For Bicycle Touring?
I don't know when Shimano and Sram will Stop making high end 9 Speed Bicycle Parts
and I here you can't use 10 Speed bike part with Dyna-Sys with 9 Speed Shimano XT RD-M772 Rear Derailleur and the New 10 Speed bike parts are marked (Dyna-Sys) and
New Crankset 24-32-42t will work both 9 Speed and 10 Speed and I am using a new
Shimano Deore 24-32-42t Crankset 10 Speed on 9 Speed on my Surly LHT 26in 52cm 2008
and both Shimano Dura Ace SL-BL79 Bar Ends Shifters and Shimano Mtn Thumb Shifters and both Right Shifters are marked (Dyna-Sys) and Left Shifters are non Dyna-Sys
I just Replace my Crankset, Front Derailleur, Cassette 9 Speed, Chain 9 Speed,and
Shimano Mtn Thumb Shifters 9 Speed
my new bike parts
shimano Deore 24-32-42t 10/9 Speed Crankset
Shimano XT M771 Traditional front Derailleur 9 Speed
Sram PG-970 9 Speed 11-34t Cassette
Sram PC-971 9 Speed Chain with Powerlink
Shimamo XT Mtn Thumb Shifters 9 Speed
Raceface XC mtn Handlebars
Adid Speed Dial V-Brakes
I am looking at 10 speed Dyna-Sys to upgrade Soon
Biketouringhobo
my new bike parts
Biketouringhobo
Clark W. Griswold
Quoted: 4431 Post(s)
Liked 4,074 Times
I do got SSI and SSDI for Bipoler 2 and I do work the Carnival Games in USA and I also do some
Medical Studys for Pay and I do Rent a Storage Unit in Oceanside CA and Since my MOM got me
my Surly LHT 26in 52cm 2008 I have been Dreaming and Planning to take and Few Trips
from Portland,Oregon to San Diego, California and from Sacramento California to San Diego, CA and from
Sacramento to Eureka, California and Eureka, CA to San Diego, CA in 2016 or 2017 and in 2016 I maybe going back to work in the Carnival Games and I came Homeless by Choice on 4/2008
Biketouringhobo
Biketouringhobo
Bikes: Surly LHT 26in 52cm 2008
Unless you need 36T from the 11-36 for an even lower gear, 9 speed is fine. I run a 2x10 speed Dynasys on my road STI equipped Masi with a 11-36T rear and a 36/26T front. 10 speed cassette is more expensive than 9 speed. 10 speed chain can be more expensive; although you can use SRAM 10 speed with your 10 speed Dynasys. Durability is the same if you kept a good maintenance schedule (clean chain, check chain length and lube only the chain links). I just came back from a tour that caused my drive train to be infested by mud and grit and the chain was squeaking like hell. Cleaned it thoroughly and lubed it again. Works like new now. It should. Durability compared with my 29er off-road tourer which is a 9speed system is the same.
thanks and I maybe Staying with 9 Speed and Stock up on some 9 Speed Bike Parts and
Sram Cassette and Chain and I do have 2 Spare Sram pC-971 and PC-951 and 1 Cassette PG-970
and mt my Crankset is Shimano Deore 24-32-42t 10/9 Speed running 9 Speed Chain
Biketouringhobo
You seem to have all of the specifics figured out to model numbers this shifter and this cassette paired with that chain.
What are you bothering us?
10 speed? I guess everyone has opinions. I tried the exact stuff you listed. Don't use it now. No since listing what I use because:
1: I don't know the exact numerical designations of the parts.
2: It works for me, I know---I use it not.
3: I don't need you disagreeing. I really don't care what you use.
Have fun and ride safe.
I'd stick with 9 speed for touring as well. I dislike Shimano for it's constant stream of planned obsolescence. I like Shimano for doing a pretty good job of ensuring that older parts are available. You can still find shimano 7, 8, and 9 speed stuff without much problem. It won't be the top end expensive stuff but it will be fine for touring.
It is quite possible to set up a proper 10 speed touring bike. Just take a look at the REI novara randonnee and the Surly long haul trucker. No doubt other companies are going 10 speed with their touring bikes without using Shimano's road triple which is not a great choice, IMHO, for touring.
The way that Salsa set up their Vaya 2 for example is not that great for touring with a shimano road triple; Bikes Direct uses that type of crank (50-39-30) with their windsor touring. But that's the kind of choice forced on bike manufacturers/vendors if they wish to stick with Shimano's brifters for triples. Bar end shifters are more forgiving of the triple being used as long as the left is friction.
Biketouringhobo
Biketouringhobo
Shimano XT M772 Shadow RD
Considered switching over to 10-speed because the new clutch design eliminates chain-suck. However I could be screwing myself on finding a replacement if it broke. 10 speed is 1:1 actuation. ****ing Shimano.
Quoted: 605 Post(s)
Liked 285 Times
Good luck finding new Ultegra 9 speed triple brifters for a reasonable price, that is if you can find them. A touring buddy lost his left Ultegra brifter on our tour in northern Michigan this summer and had to settle for replacing with Microshift 9 speed shifters. I bought an extra set of Ultegra 10 speed triple brifters for later on when my 9's finally puke as that won't be a big deal to switch over vs. 11's.
Good luck finding new Ultegra 9 speed triple (>brifters?< What is a brifters for a reasonable price, that is if you can find them. A touring buddy lost his left Ultegra brifter on our tour in northern Michigan this summer and had to settle for replacing with Microshift 9 speed shifters. I bought an extra set of Ultegra 10 speed triple brifters for later on when my 9's finally puke as that won't be a big deal to switch over vs. 11's.
Range of gear gear ratios, touring, matters more than how many cogs that got packed into the space available on your back hub.
I vote for keeping your drivetrain as is. Try a few short weekend tours to a mountain locale near you. Save your hard earned money for your west coast dream tours starting next year. You'll have a lot more fun doing that than worrying about upgrades.
BikeTouringHobo: Fietsbob is absolutely right on this. You are not going to notice any major difference whatsoever by going to 10 spd drivetrain. Your 9-spd 11-34 cassette along with triple mtn crankset are plenty OK for your touring purposes. Range of gear is what matters the most here. You've done a great job with that aspect already. It's easy to fall in the trap of upgrading parts especially when people in the industry (e.g., bike shops) tell you that you better upgrade soon or you won't find parts. First, it sounds like you wouldn't make the mistake of starting your dream tour with worn out parts. Then it is simply a matter of planning when to replace things like chains, cassettes, chainrings to keep everything running smoothly. All of these things can be ordered easily over the internet and have them shipped to a particular location quickly.
Sram PG970 11-34t 9 speed cassette on my Surly LHT and I also push my bike uphills
Quoted: 33 Post(s)
Doesn't Nashbar sell a 9 speed chain that is highly rated and costs about 12 bucks?
I'm still sourcing parts for my 7 speed freewheel system. People keep saying you can't get stuff, but it is always out there somewhere a few clicks away.
There are diminishing returns with every step up. 5-6 increased options 20%, 10-11 only 10%.
High, 95 gi, low 18 gi has been fine for a range .. In cassettes the Shimano 7 Speed K cassette I though was sufficient ..
But the marketing wanted more parts so pushed 8,9, and onward..
14~34 .. 50-40-24 . (K is 13~34 )
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
9 speed downtube shifters have a friction setting. 10 speed is index only. 9, 8 & 7 speed road & mtb have the same cable pull. 10 speed mtb derailleurs do not. 9 speed is way more compatible.
Bike hobo, you push your bike up hills??
That is shameful! You need to get good mate. Maybe snort less glue or whatever hobos get up to.
Quoted: 7666 Post(s)
Liked 3,534 Times
I believe you can buy a Shiftmate 6 to coordinate the cable pull for 10-speed Shimano road to MTB derailleurs, so you can use the ultra-wide-range long-cage Deore stuff with brifters. Compatibility regained.
Pushing is classic cycling at it's best, from the hills of Ireland to Cyclocross.
and I am Not Racing to go from A to B! and I am not going to kill my legs and muscles hurt when I ride hills in
Southern California
Quoted: 275 Post(s)
Liked 417 Times
Yeah yea, most people are lazy and most people don't even ride bikes. Well, that's just wrong man. I am always racing and you should always be racing. Push yourself until you reach the top or die. My dream, like all proper cyclists, is to win the Tour De France, Giro, Vuelta back to back. I will play you a sad song on my tiny violin for your hurty muscles.
XT RD m771 9 speed, XT FD m771 9speed, Shifters XT m770 thumb pods 9 speed
I was asking about 10 speed
Liked 3,534 Times
You cannot use 10-speed Shimano road shifters with 10-speed Shimano MTB derailleurs--different cable pull. If you wanted to switch to 10-speed and use road shifters with MTB derailleurs (to match your MTB chainrings and cogs), you would need an adapter.
Since you run flat bars and MTB thumbshifters, no problem.
All you would need to change would be the cassette, shifters, rear derailleur, and chain. FD and chainrings are fine. (You don’t mention what rear derailleur you have in the first post, but obviously it is 9-speed.)
Sorry to provide info you don’t need.
