where to learn bicycle repair?
Quick thoughts:
Bowden cables are based on tension- one direction is a human input and the other direction is spring energy stored from the human input. Basically, if you remember that you can't push a rope, you'll be lightyears ahead of the game when it comes to cabled systems.
Mechanic/Tourist
Just a heads up- There is a point when the knowledge of how things work won't be enough. There have been so many analogous, but distinct and incompatible products in the history of bicycles (threadings, tapers ISO/Metric) that there will come a time that you need to catch up on your history and educate yourself to the universe of parts.
Mechanic/Tourist
Yep, understood - and thanks much for your addition.
Bikes: 1989 trek 660, my chilly conch cruiser, blacked out brakeless fixie, gunnar crosshairs, 1964 raleight sports, LHT, bumblebee bike
tinker with some garage sale junkers and sheldon brown!
Mechanic/Tourist
Disconnect the cable at the brake/derailleur end and hold on to the cable as you move the lever and you'll realize that the cable only moves back toward the caliper/derailleur if something is pulling on it and the lever allows it to move.
Observe and think about the housing stops and what they do. What is the difference between the function of a fixed one on the bike and a moveable one on the derailleur or brake? How does the housing act in opposition to the cable the end is allowed to move?
The cable is routed around curves by the housing. What does the cable actually do when pulled around a bend in the housing, and how would that change if the housing is much longer, or shorter, as far a friction and flexing, and what would the result be in terms of ease and amount of movement transmitted between lever and mechanism?
Bikes: Fandango DC-9 Mtb Tandem,Co-Motion Supremo,Trek T-1000 tandem, Specialized Allez Elite, Dolce,
Just got back and checking in. Thanks to all for replies and for some great leads. I am not looking for a career change as I am to old for that. I would like to be able to do more than just change a flat, tape handlebars, fix a chain.... Going to check our local university and see if they offer anything like Texas State. BTW, i am in Beaumont.
ironic, my daughter is going to Texas State after graduation this year. I dont think she wants good ole dad starting bicycle maintenance with her on first day! LOL.
Bike Recycler
Bikes: Huffy Cruiser
I just wish that someone would offer an online course. I also would like to see more sites on documentation of bicycle repair. I have several of the big manuals that have helped me out greatly but sometimes I need the paperwork to actually sit down to do the repair. Like right now I have a bike that has Lee Chi shift levers and I cannot seem to find anything on them or suntour derailluers. Now I try to get whatever information I can off of forums like this which are a great asset.
Thanks...Greg
Thanks...Greg
Mechanic/Tourist
For any given repair/install procedure there are dozens of credible resources - videos, online tutorials, manufacturer spec sheets and books. You really have to work from your own staring pont rather than a structured course, because both what you will encounter and what you know control what info you need. Most instructions will cover the clean, straight, uncorroded world that is seldom seen. They can't possibly cover all you may enounter, so you either need to be able to observe, analyse and then solve problems that come up or use Google or this forum for those situations.
There is very seldom any need for separate documentation or procedures for a particular brand of derailleur or lever, unless you plan to disassemble and want an exploded diagram to see what you can expect ahead of time, or intend to get a part - which is usually futile anyway.
Derailleurs all work under the same principals for a given type (some go in the reverse direction when the cable is puilled). The only variable typically affected by brand is whether a certain derailleur will index properly with a cassette or lever.
As for levers, there are different types and cofigurations: Non-indexing friction shifters are mounted on the handlebar stem or down tube, non-indexing ratcheted shifters (ratchet on pull, friction on push) are also on bar-ends. Indexing levers are on the down tube, stem, upright handlebars or grips, or integrated into brake levers. Each type and configuration may require different troubleshooting, but there are many fewer differences when it comes to brand.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,443 Times
Lots of good advice above, one recommendation I would add, read through SB's Glossary. There are lots of great diagrams and cutaways that make pretty plain how all the systems of the bike work together, and perhaps more importantly, if you learn the names of everything, it helps you search for online tutorials. For almost every aspect of bike maintenance, you can find a few YouTube tutorials.
Bike Recycler
I am new to fixing bikes and have found Sheldon Browns site very informative and has sure helped me out a lot. I also recently got a copy of Barnett's manual and with the older bikes that I get that book is like a Bible to me.
