How to Stop Bike on Descent if Brakes Fail?
Cycleway town
Yes, but then you have the choice of cable calipers that stick, or rim brakes that are comparatively rubbish.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Bad situation and I've never tried this deliberately, but when something wraps around the cogs on the rear it tends to lock the wheel up. Flop a jacket or strap back there.
They put deep, loose gravel run off pits on long Sierra descents in the California mountains to be there when Trucks lost their Brakes..
I have not ever lost braking on my bicycles , I keep my gear in top functioning condition. the key is; Maintenance and safety checks before each ride..
Erik the Inveigler
Quoted: 1310 Post(s)
Although, I'd say that I have never had a problem with rim brakes. I have disk brakes on my MTB and have also never had any problems. Maintenance is key.
As an aside, I wonder if disk brake systems that use mineral oil as opposed to brake fluid are more prone to overheating. Not sure about this.
genec
Quoted: 13659 Post(s)
Liked 4,532 Times
While folks alude to poor maintenance as the primary issue, and are busy pointing to disc brakes... I have had good salmon Coolstop pads fade on a long descent while touring. I did retain just enough braking to slow, but doubt I could have stopped. This was with a full touring load.
Just sayin' there ARE other possible failures.
Like an anti-lock, braking technology does, a pulsed application and release, will let disc or rim cool ..
I don't win money getting to the bottom of the hill first, so I moderate my speed.. without needing braking so strongly all at once..
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
This thread really scares me. I ride my (Ultegra hydraulic) brakes like a clinically paranoid grandmother, and have never had even a hint of any problem in a very hilly area, but still...
This is good to think about because as in this situation they fail right at the time you need them and since you're already going too fast, there's no time to cycle through all of the conversion requirements of all of the main religions one after the other so it's probably best to just pick one now... e.g., one of the more popular that entails very little skepticism or even much common sense is the religion of global warming alarmism.
Quoted: 5863 Post(s)
Liked 2,709 Times
To start with, this is a hypothetical question about something extremely unlikely to happen on a two brake bicycle.
The systems are independent, and even if not in the best condition, the odds against of catastrophic failure at the same time are staggering. Yes, one can fail, and often will, but that gives you plenty of time to bring the bike under control and consider your options relating to continuing with only one brake, ie. walk down steep hills, pick up and carry a rock to use as a brake shoe on the front tire, or just hone for a ride.
If riding with only one brake which fails, the shoe on tire behind the fork may be one of the poorer options. It can compromise steering, and has a high risk of causing an endo if not modulated well. Also consider the reality that the action of the wheel would be to increase braking, so the likelihood of rider error is increased.
A better option is putting the left foot against the rear tire at the chainstay, Here the worst that can happen is locking the wheel and dumping to the side. This will likely cause road rash, and possibly some other injuries, but side falls are generally safer than endos.
Other options include riding it out using posture to maximize wind drag, looking for a soft landing spot, looking for a potential turnoff toward the uphill side, etc.
So, IMO it's best and easy enough to prevent this scenario altogether, but ride smart once you find yourself down to one brake, being ready to deal with it if that one fails too.
BTW- if we look at causes of injury on bikes,and consider the level of risk we assume every day by riding in the first place, the risk if dual brake failure is so low that it wouldn't even amount to a statistical blip.
FB
Chain-L site
FB
Chain-L site
Occam's Rotor
Liked 2,331 Times
After reading this I took my new drop bar mountain bike out for a long downhill ride, and was even more paranoid than usual.
But one thing I thought about:
There is no smell from bike brake pads. They aren't made of asbestos. So what is going on?
Bikes: Schwinn S7, Schwinn '66 cruiser, couple of MTB's
Quoted: 10 Post(s)
When I was a kid my bike wouldn't stop. Never figured out why but my mama bought me a new pair of shoes and the same day I used them to stop the bike by putting them between the front forks and onto the tire. Wore a hole in both shoes soles. She was not a happy person from that. I had to wear them for a good while until I got another pair.
Occam's Rotor
Liked 2,331 Times
I'm calling B.S. on this story.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 343 Post(s)
Liked 241 Times
Heh, Ted Shred shows how. But you might be doomed if you aren't wearing Vans shoes...
And he never really does stop.
Not so sure about my Giro Trans though.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2137 Post(s)
Liked 1,649 Times
This is awesome. We now have a new dimension in the disc vs rim brake argument.
Bikes: Nashbar Road
Liked 341 Times
I thought that the first serious objection to hydraulic disc brakes from the get-go was the rotor overheating and the fluid boiling, leading to failure on long descents. People could lose one, then doing the same thing lose the other, and were cautioned to feather the brakes, and let off periodically on big hills. My impression was that those problems were mostly solved, but not completely.
So I didn't think it was new, nor unusual for both brakes to fail. Or did I imagine that history?
Bikes: 1983 Schwinn Super Sport
I remember reading in an older book that one way to stop a bike when the brakes had failed was to spin the handlebars to get the front wheel sideways and let the front wheel and forks collapse into the ground! How would you practice that maneuver?
Liked 2,709 Times
Turning the front wheel sideways is a 100% sure way to cause an endo.
FB
Chain-L site
FB
Chain-L site
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Dudes, unless you have naught ahead for as far as you can survey, you will, in the prophetic words of RATT, "Lay It Down"
Quoted: 551 Post(s)
Liked 278 Times
Straddle the bike on the top tube. Put both feet on the ground to slow down. Pray that your flip-flops have enough padding to do the job. Well, at least this was how we did it when riding down a steep hill without brakes.
Cycleway town
Quoted: 18481 Post(s)
Liked 15,772 Times
Look for a long, steep uphill driveway or side road.
Master Sarcaster
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
As I was rolling down the hill, riding the brakes to the point that the pads have become glazed (I was trying to push it), I couldn't smell anything from the bike. I did smell someone using spray paint quite a distance away, so I don't think it was my nose at fault.
tumbleweed
This scenario sounds like a great time to practice surfing the top
tube because you are already screwed.
Might as get some style points and go out with a bang.
