Handlebar Width?
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
The situstuon with my MTB will change as I'm moving to a more rural area this month.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
My only MTB is my old 26" XC race bike. Back in our prime (mine and the bike's), my typical setup was a 135 stem and narrow bars. In its currently set up as a singlespeed, and I went to a 100 stem with 630 bars, then to 80x720. It took me a bit to get used to, but I've found that I like the leverage of the longer bar for technical sections. If I was cruising non-technical paths, however, I would probably opt for the longer and narrower option, more like a road bike. FWIW, I have wide shoulders and prefer 44cm road bars.
Likes For Eric F:
Drip, Drip.
Liked 193 Times
I currently have my grips mounted at about 60cm wide on the felt and I like the way it feels.
I dont want to and can't rreally ride anything super technical, but in that case. Im sure going wider woukd help.
Likes For Mike_Kelly:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I may have finally reached my bar width limit.
After slowly creeping up from 560-580mm in the 90s to 750-780m in the last few years, I tried bumping up to 800mm on my FS bike. This is the first time I have ever gone 20mm wider and not been sold by the end of the first ride.
It seems counterintuitive, but it is actually on the climbs that I really liked the extra width. In particular technical climbs where I am out of the saddle pushing a higher gear. I also liked it in the corners. It was the "just riding along" part that it seemed like it might be too wide.
I'll give it another couple rides, and it I don't change my mind I'll go back to 780mm.
Quoted: 236 Post(s)
Liked 171 Times
When the vast majority experienced mountain bikers - even ones like me that started on sub-600mm bars - have gravitated towards bars 720 and up, you need to ask yourself what they are getting that you are missing.
I assure you that whatever trail it is that you think you are going to be hitting every tree, folks are riding 750mm bars on it without issue.
Well, son, I been crushing gnarly, b****in' single track since the late 80s on bars that could double as a straw in my post ride mai thai they're so narrow. So I'm down w/ moisture: don't get these giant 'surf board' bars. I guess you need extra stability to make up for other defects in your skillz. and suspension? what's that?
My new Specialized Stumpjumper has 780mm bars so that is what most people want to use. A 780mm bar can be easily shortened for those with short arms with little effort. It is after all a recreational activity and not something to get a swelled head over.
Advanced Slacker
Liked 2,537 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
My MTBs have drop bars with a little bit of flare on them. They measure 44cm at the hoods and 49cm at the drops.
Bikes: 2014 Avanti Circa (Rd Dist), 2020 Giant Toughroad (Rd Tour), 2021 Trek Allant+ 8S (eCommute), 2021 Scott Aspect 940 (Mt HT), 2014 Santa Cruz Superlight 29er (Mt FS), 2022 Scott Spark 960 (Mt FS)
Quoted: 35 Post(s)
Liked 52 Times
For me it depends on the discipline.
I used to run 725mm for my Reign, but I'm likely to update this to 760mm on the next bike (currently no fully for me ).
My hardtail in comparison currently has 800mm, and its just too wide for open gravel, so I'll likely swap this back to 720mm, maybe even narrower...
Quoted: 2976 Post(s)
Liked 1,182 Times
They work fine as long as you aren't trying to tackle single track trails. Buddy of mine tried this idea on his Specialized hard tail than complained about how crappy the bike handled on single track trail.
Drip, Drip.
Liked 193 Times
600 or maybe up to 620mm is about the widest id want to go in terms of actually getting the bike through trees and what not on the narrow rail trails near my new house.
Liked 1,182 Times
Guys,
I just took my handlebar right off. I mounted the brakes and shifter onto the top tube and I just hold onto the stem now. I can REALLY ride some tight single track trails now!!
Advanced Slacker
Liked 2,537 Times
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I was running 700 for a long time but with the shorter stems, I slowly moved to 760 and then 780 which I have used for maybe 4 years now. I recently got an 800 but it has more sweep so it effectively 785-790 and I really like it. It is the most comfy one I have used so far. However, I am 6' tall with longish arms...6'3 span. Shoulders- not sure but I were a 42 jacket.
