Why a 650B Conversion?
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 33 Times
Aside from the fatter tire possibilities, wouldn't the smaller diameter wheel result in quicker handling. This was the case when sportbike motorcycles in the early 80's started using smaller 16 inch diameter wheels. It was more of a novelty as after a few years, riders ended up demanding the manufacturers to bring back bigger 17 inch diameter wheels because the smaller wheels felt too nervous/skittish on the road for many riders.......quicker handling could be an advantage for bicycles used in races like Criteriums though......just my thoughts....
Chombi
Chombi
Not if the overall circumference is comparable, right? Add to that that a bigger, lower pressure tire would be "less quick". This is just conjecture on my part. I'm not a physicist or an engineer.
Quoted: 28 Post(s)
Liked 60 Times
Chombi
Chombi
So what did YOU do to it?
Bikes: 2006 Fetish Penna, 2014 Fuji Cross 2.0
Chombi
Chombi
They really went from 19f/18r" wheels to 16f/18r" wheels. Then settled on 17f/17r" wheels.
Quoted: 150 Post(s)
Liked 33 Times
Chombi
Quoted: 7355 Post(s)
Liked 2,490 Times
OK, I do see the point for some people (bikes) but very few. I took a quick test ride on the bike I just fixed up. It's an old Trek 830. I pumped the tires to 80 in front and 90 in back. It felt very quick. Best mountain bike I ever rode, but that's because I don't care for mountain bikes much. The tires are pretty light, too.
I should get picky and point out, that with the weight, and speeds involved in bicycles, wheel diameter isn't going to limit the transition speed of the bike. On a motorcycle, with a 30-40lb wheel, with a 30-50-100mph rim speed, sure, diameter is going to seriously affect stability. But on a bicycle, even at 40mph, with only 2-3lbs of mass on the rim, you shouldn't be seeing any effect that even moderate muscle can't overcome.
Liked 6 Times
SP
Bend, OR
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
^ those psi's must be for a narrow 1.25 or 1.50" slick.
I'm running 1.95" gumwall near slick tires on a rigid MTB. 65 psi max. @ 60, it's fast but bordline harsh. Some of that is on account of the quality of the tire too. But playing with tire pressure will get you your sweet spot.
Honestly, I don't think there's any logical reason. Everyone will say it's to get a cush ride on racing bike but that's BS. IMO, it's just something to do for those of us, me included, that want something nobody else has. With that said, I want to do one myself, just to be different.
Liked 2,490 Times
Slicks!
I can't wait to hear from the customer.
Abu Mahendra
20
08-03-18 04:25 PM
