Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Interesting finds around the web
Old 01-30-18, 11:27 PM
  #1651
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
Liked 23 Times in 20 Posts
Originally Posted by spartanKid
Aluminum track cogs seem like a huge risk for little reward, but maybe I'm wrong.
They are ok when they are relatively new. The problem is that aluminum is soft, but it work hardens along where the fatigue stresses occur. It doesn't wear as fast as it hardens, so differential stresses build up inside the piece. As it wears, these stress lines change in the piece, and the affected area grows until it fails.
Putting a sharks tooth grind on the tooth shape helps.
Cutting them like a regular steel cog is no good.
It also helps if they are 1/8th inch and not 3/32nds.
taras0000 is offline
Old 01-31-18, 12:52 AM
  #1652
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
If it was aluminum, it's not worth the few ounces saved especially assuming he rode like a 12 or 13t. I've owned one. Used it once and tossed it.
carleton is offline
Old 01-31-18, 01:16 AM
  #1653
Poppit's Avatar
Quoted: 111 Post(s)
Liked 5 Times in 4 Posts
I believe it was carbon
Poppit is offline
Old 01-31-18, 01:21 AM
  #1654
Elitist
carleton's Avatar
Wow. Definitely not worth it.
My teeth are worth more than the few ounces saved.
carleton is offline
Old 01-31-18, 01:24 AM
  #1655
Poppit's Avatar
Quoted: 111 Post(s)
He was using a road chainset/chain combo as well
Poppit is offline
Old 01-31-18, 01:33 AM
  #1656
Elitist
carleton's Avatar
I'm glad he's OK.
I'll bet a dollar to a dime that the next time you see him, he'll be on a proper track crankset with common chainrings and cogs.
carleton is offline
Old 01-31-18, 10:55 AM
  #1657
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
those british fellas put some power data on strava from their Minsk World Cup win.
Their TP starts with 20 seconds at 1000w, a minute at 650w, and overall, about 4 minutes at 530w.
A ****load of power, god damn.
queerpunk is offline
Old 01-31-18, 11:25 AM
  #1658
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
That's wild
Morelock is offline
Old 01-31-18, 03:04 PM
  #1659
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
All the more reason to use dependable equipment. Track bikes are so easily made light that one doesn't need to start using questionable ultralight components on their bikes. An average sized frame can come pretty close to the weight limit just using standard parts.
Old 01-31-18, 03:13 PM
  #1660
Poppit's Avatar
Quoted: 111 Post(s)
It wouldn’t just be about weight, it’ll be about watts and feel, e.g. https://www.peekrings.co.uk/
Poppit is offline
Old 01-31-18, 05:47 PM
  #1661
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
A chainring is one thing. You typically have around 3-4x more teeth in contact with the ring than a cog would, yet they both have to deal with the same amount of force being transmitted through them (via chain tension). Add the differing leverage ratios due to the differences in diameters, and the amount of force on each individual tooth is compounded many times.
To me, passing on a carbon cog would seem to be a no-brainer. On the other hand, I would test out carbon rings if they were available to me.
Old 02-01-18, 08:15 AM
  #1662
Quoted: 75 Post(s)
Liked 6 Times in 4 Posts
On the topic of mantis like positions, this has changed a little since the word cup.
59.759
pierrej is offline
Old 02-01-18, 12:23 PM
  #1663
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
My eyeball aerodynamics say that looks like a very slippery position. It's funny, because if you rolled his torso up at the hips a little, he would look like a normal pursuiter in the mantis position, but here, the mantis is so low that his forearms are still almost level, yet still able to close off the airspace in front of the torso.
It looks like compared to his last position, his hands are basically raised "one hand width".
The crappy thing about this, only 2 news agencies have picked up on the story from what I can see.
Old 02-01-18, 01:53 PM
  #1664
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
It's the kind of position that only tall people can achieve with conventional gear - no short person can have a hip angle that can still generate power while being that folded up.
Old 02-01-18, 01:55 PM
  #1665
bitingduck's Avatar
Quoted: 43 Post(s)
I'm not small (ride a 56 cm diamond frame) and I never made any effort to shave weight on the track, and I always had to add weight (sometimes just 20 grams of tape) after I stopped riding the old steel Pinarello. There's really not a lot of value on the track in going for lighter & less durable equipment.
Track - the other off-road
https://www.lavelodrome.org
bitingduck is offline
Old 02-01-18, 02:09 PM
  #1666
Quoted: 75 Post(s)
I'll admit I have no knowledge on the subject of carbon cogs, bit surely it's not in an effort to save weight as it would be one of the most negligible gains for obvious risks.
My thoughts would be along the lines that they might be more efficient/smoother or something along those lines, given the kgf guys do focus on small improvements
pierrej is offline
Old 02-01-18, 02:35 PM
  #1667
Poppit's Avatar
Quoted: 111 Post(s)
Like I said about 5 posts ago
Poppit is offline
Old 02-01-18, 03:44 PM
  #1668
Elitist
carleton's Avatar
59.759
Jeez. I just realized that this is a new sea level world record. Wow.
Are there plans to take him to altitude and take a shot at Purvis' 56.303" that's been on the books since 2013?
carleton is offline
Old 02-01-18, 10:18 PM
  #1669
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
I tried to find some data on Watt savings versus aluminum cogs/chainrings, and couldn't find anything. Any leads?
Old 02-01-18, 10:29 PM
  #1670
Lapped 3x
taras0000's Avatar
Quoted: 325 Post(s)
For all the Campy fans out there (which includes me when it comes to vintage Pista Record)
https://jalopnik.com/campagnolos-408...ory-1822278077
Old 02-01-18, 10:39 PM
  #1671
brawlo's Avatar
Quoted: 288 Post(s)
Liked 76 Times in 57 Posts
Given his speed ATM you would have to think that is was a consideration. Their primary concern right now will be the Commonwealth Games in April which has the kilo TT. From there it would be a worthy consideration before the team changes focus towards Tokyo in 2020 where kilo is not included
brawlo is offline
Old 02-02-18, 05:53 AM
  #1672
Morelock's Avatar
Quoted: 282 Post(s)
I'm usually all for carbon components (ran Fibre-Lyte chainrings on the road for years) but the rear cog... I dunno if I'm brave enough to try that.
I was playing with the idea of a big ring from aerocoach... but even that makes me nervous (plus it's quite a bit more than just a metal one)
Morelock is offline
Old 02-02-18, 10:58 AM
  #1673
Quoted: 70 Post(s)
Liked 5 Times in 5 Posts
Hey Morelock, I tried sending you a PM about the IO clone you have that tested well. Do you have any info on which supplier it came from? I might be interested in getting one.
rustymongrel is offline
Old 02-02-18, 01:17 PM
  #1674
Morelock's Avatar
Quoted: 282 Post(s)
Hmm I didn't get it (or see it, I might be dumb to the forum)
AnglerWang1 was the ebay id.
Morelock is offline
Old 02-02-18, 01:31 PM
  #1675
Poppit's Avatar
Quoted: 111 Post(s)
Not really, at a guess you're probably only looking at a couple of watts, waxed chain will be around 5 watts and the carbon chainring around 3 watts so do all 3 and it could be around 10 watts. Marginal gains? https://www.shopforwatts.co.uk/blogs/news
Poppit is offline
