Have you ever broken a front spoke?
Quoted: 4421 Post(s)
Liked 4,874 Times
I've never broken a spoke (front or rear) in 50 years of cycling on/off road. But last summer I did witness another rider's rear spoke break when the guy I was following up a wet & slippery 20% slope suddenly tried to downshift (no idea why he wasn't already in his lowest gear by that point) and then stomped hard on the pedals. His back wheel momentarily slipped and then when it regained a bit of traction - crack!
Quoted: 4806 Post(s)
Liked 3,933 Times
I have. Once or twice pure miles. Lesser spokes. The early SS ones popped heads when they were having a bad day. In every box of 100 zinc plated DB Robergels, 3 or 4 would break; just because. Broke 8 on one side and 1 on the other simultaneously once. (There was a QR from another bike in there.) I've broken nipples when the spokes were not quite long enough. And had a run of spokes that broke across the threads just below the nipples.
Want stories for the internet? Ride 200,000 miles. I promise you will gather a few.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2590 Post(s)
Liked 5,659 Times
only one on a factory wheel when I hit a good sized pothole That was probably 35 years ago,
broke a back spoke on my MTB a week ago and wasn’t doing anything too crazy.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 1088 Post(s)
Liked 1,028 Times
I want to say yes but excepting crashes I'm not certain its really true so maybe one.
With modern rims I will say that 36 spokes is more than needed unless you're north of 300, even my touring bike is only 32 though the rear wheel is built single butted 13/14 for spoke strength at the head. Front is regular butted.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I have been curious about this and disc brake wheels. A front disc incurs several times more torque and weight transfer than a rear cog but only occasionally instead of constantly and rhythmically
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Quoted: 506 Post(s)
Liked 639 Times
Yes, once in well over 300K miles of riding. Good quality spokes on a good quality hub with a good quality rim built well. It just broke (at the hub). Grain defect in the spoke I suspect. Absent a crash it is a VERY rare experience with quality equipment.
What? If you never broke a front spoke you need to ride more.
Note that Greg Lemond won his second world championship at Altenrhein, 1989, with two broken spokes in his front wheel. In the mountains. In the rain. Safe to assume Greg had a properly built wheel and a low mileage or new wheel. It happens.
I have, although my situation is a little different than most. I have a highracer recumbent. I broke a front spoke on a Velocity wheelset. After having the spoke replaced, I broke another spoke on the same wheel a few weeks later. Figuring there's something wrong with the wheel build, I swapped to another brand-new Velocity wheel. Nope, the next week I broke another spoke. At that point I had the most recently-affected wheel completely respoked with heavier spokes. It was rock-solid after that. Both wheels were 20-spoke front wheels and I was at 200 pounds riding smooth pavement. I have since retired that wheelset to my spares and now use a set of Roval wheels with similar spoke counts, which have been problem-free for 5-6 years.
I can only figure that putting the pedaling forces in front of and over the wheel caused extra stress on it and the wheel just needed to be a little more heavily-built.
Grupetto Bob
Liked 5,659 Times
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Assuming your regular riding is on paved surfaces, not bombing down mountain trails, jumping off elevated surfaces onto pavement below or other bike-abusive situations.
Have you ever had a front spoke break just riding along? I've had a number of rear spokes break which is why I just went to a 36-spoke wheel with triple-butted spokes, but so far have never had a front spoke break.
Spokes on bikes break because of the asymmetric loads on the spokes because of our use of multigear systems. The spokes on the rear wheel are under very different tension depending on the side of the wheel they happen to be on. There are three actions that put stress on the spokes…pedaling, cornering, and just rolling down the road. (Braking is in there also but it’s the same as rolling down the road with minus sign.) Rolling down the road (and braking) probably put the least amount of stress on the spokes but they are of high frequency. Each time a spoke hits the bottom of the wheel, the tension on the spoke is reduced to its lowest level. As the spoke moves away from the bottom of the wheel, the tension increases. This happens roughly 140 times per minute at 12 mph on a 700C wheel. For a one hour ride, a spoke is stress/distressed over 16,500 times. Low spoke tension can cause this flex to be more pronounced than high tension. The left wheel in the picture below illustrates this detensioning in an exaggerated manner.
During braking and pedaling, the spokes are subjected force as well…and a different kind of bending…as the hub tires to spin the spoke ahead of the rim. The flex in the spoke is different from the flex of loading and unloading.
Cornering probably is the largest force on the spoke because the spoke is bent out of plane as the rim flexes to the side (middle picture). Pedaling dynamics can also have an effect on this kind of side loading as well, especially during hard efforts either out of saddle or just climbing. The asymmetry of the rear wheel exacerbates this problem because of the unbalanced load on the spokes.
In my (considerable) experience of spoke breakage, if I hear a ping, it will be when the wheel is bent out of plane on a corner or when pedaling. Seldom does a spoke break when just rolling down the road. The front wheel is symmetric (or just slightly asymmetric with discs) so it doesn’t have the same problem.
Stuart Black
Stuart Black
Quoted: 3241 Post(s)
Liked 2,512 Times
Back when I was in grade school sometime between 1973 and 78, I was booking it across a golf course between groups teeing off. One of my brake levers slipped off and went into the front wheel. All of the spokes ripped out of the rim and wrapped around the front hub. The fork/front hub dug into the ground and the bike just stopped. I stepped off like Legalus in one of the LOTR movies. I picked the bike up, then started the 1 or 2 mile walk of shame back to my house.
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times
A whole lot of people have the wrong idea about what breaks spokes. Impacts aren’t going to break a spoke. Spokes aren’t “attached” to the rim. The rim holds the end of the spoke but put enough force on the rim to bend it and it simply slides up the spoke. Bicycle spokes are only under tension and never under compression.
Liked 4,222 Times
Read my post again. It addresses why front spokes don’t break all that often. It also addresses why rear ones do.
Stuart Black
Stuart Black
Quoted: 3958 Post(s)
Liked 7,312 Times
Liked 4,222 Times
Explain how an impact can break a spoke. There is no solid connection between the spoke and the rim. The rim can slide up and down the spoke which makes transmission of the impact’s force zero to the spoke itself. The rim can be damaged but not the spoke. Railroad tracks are nothing to the rocks, drops, and jumps encountered in mountain biking. I don’t think anyone would argue that mountain bike wheels are more prone to spoke breakage than road bike wheels nor vice versa.
Stuart Black
Stuart Black
Liked 7,312 Times
Quoted: 506 Post(s)
Liked 639 Times
Quite simple really. Impact forces cause the spoke to unload and then "snap back" with the snap having a significantly higher force than the equilibrium forces of just riding. If that force is enough to break the spoke, there you have it.
Liked 4,222 Times
The same spreading of tension works as the force of the impact lessens but in the opposite direction. The spoke won’t “snap back” with enough force to fracture the head of the spoke. The rest of the wheel spreads that same increase in tension as it did the decrease in the tension. The return of tension has an impact on the fatigue of the spoke over time but it’s not an instantaneous failure.
Stuart Black
Stuart Black
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
yes once. best I can tell it was from running over neighborhood speed bumps to hard or with too much force. The spoke pulled a hole/gash in the rim
This was after several thousand miles of riding, so that's my best guess
Liked 4,222 Times
That is not the impact “breaking” the spoke. The spoke was already broken and just waiting for the right time to fail completely. Additionally, since this is a discussion about front wheels, the spokes are far less likely to be fatigued than rear ones.
Stuart Black
Stuart Black
Liked 4,222 Times
That’s not what most people would call a broken spoke. The rim failed but the spoke didn’t. That’s a common wheel failure but not a spoke failure.
Stuart Black
Stuart Black
Liked 7,312 Times
Originally Posted by KerryIrons
It will if the spoke is already fatigued and getting ready to break. Most of the time it won't break the spoke. Once in a while it will.
