Steepest hill that you frequent
Quoted: 8333 Post(s)
Liked 9,162 Times
In other words, a 45 degree angle would be (roughly) a 100% grade.
Likes For CoogansBluff:
Quoted: 176 Post(s)
Liked 57 Times
I live a little over a mile away from my parents, and there's a nasty 20% stretch when I ride over there. Fortunately it's pretty short but when I was in high school, I didn't have the strength and/or gearing to make it up without stopping to walk it. Some years after college when I moved back to the area and started riding again, I got a bike with a triple and was pretty pleased the first time I was able to make it up without stopping.
A couple of years ago I rented a bike while visiting Pittsburgh, and hit some of the Dirty Dozen hills, including Canton Ave (cobbled!). Definitely some seriously steep and nasty stuff around there; good times though.
Liked 9,162 Times
In L.A. there is Fargo street.
Likes For big john:
Randomhead
Liked 3,720 Times
I think the perfect bike for the dirty dozen race would be a tandem. I would do it on mine, but then I would have to climb steep hills. Wouldn't be prudent.
Have you ridden up Canton Avenue? It's been called the steepest street in the country, although there is one in San Francisco and one in Hawaii that might have it beat. Top 3 for sure. I would love to try that. But not in clipless pedals. Would need to be ready to abort.
Yes, on my 3rd try. The first time I took a bad line to the left, and ended up in some slick leaves; back wheel slipped so I aborted early. The second time I was maybe 2/3rds of the way up when I hit a cobble wrong and it threw me off balance; I managed to unclip in time (I was on SPDs). The 3rd time I got it right. The rental bike had 34-front/36-rear gearing; clearly they knew their clientele and terrain.
Canton is short, but the next one I did (Boustead) was a real lung buster as it was quite a bit longer. When I was approaching the steep part a young local kid (clearly having witnessed a lot of attempts) yelled out "You're not going to make it!" I took some pride in getting up without stopping, although I was definitely gasping for air at the top.
Likes For jfh:
Quoted: 176 Post(s)
Liked 57 Times
Yes, on my 3rd try. The first time I took a bad line to the left, and ended up in some slick leaves, back wheel slipped so I aborted early. The second time I was maybe 2/3rds of the way up when I hit a cobble wrong and it threw me off balance; I managed to unclip in time (I was on SPDs). The 3rd time I got it right. The rental bike had 34-front/36-rear gearing; clearly they knew their clientele and terrain.
Quoted: 1284 Post(s)
Liked 1,405 Times
i believe canton in pittsburgh is 37%.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2616 Post(s)
Liked 5,741 Times
It's "flat" around my house. But there is no way to get in or out of my neighborhood without a 10-15% short grade, one hits 18% for a short section...
The dead flat canal MUP I ride has 3 short 8-10% climbs in each direction - these little blips catch the Sunday riders off guard!!...
These small hills are not good for working on a climbing rhythm or steady pace, and often hit you pretty hard if you are hammering on the flats. I use them to do full gas sprints once a week or so...
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 2333 Post(s)
Liked 2,097 Times
I'd try the dirty dozen in sneakers or trail runners. Carbon soles is suicide, how you do walk down Pave with leaves. I know I'd walk on some of them.
24/34 gearing on a bike with super long chain stays and large tires at low pressure and wide handlebars.
Quoted: 3980 Post(s)
Liked 7,429 Times
There's a section on our road that exceeds all of those, but it's really short so I just bunny hop over it.
interestingly there’s always a fair amount of debate about this, with some lists including things that aren’t really “streets” proper, and grade measurements depending on how long a distance once measures, and whether they’re measured along the fall line or crown or whatever.
Likes For tomato coupe:
Quoted: 681 Post(s)
Liked 949 Times
here are some 20% grade roads. even on my mid drive ebike this is hard.the path one was so short and steep and mossy we walked down since it had that 90 degree turn right at the bottom.
Likes For fooferdoggie:
Quoted: 624 Post(s)
Liked 399 Times
Florida is pretty flat, but can have some hills where I ride around the Ocala Nat Forest. One part of SR 19 you are either going up or going down. There is one area where the Juniper Wayside Park sits in essentially a bowl. Either side is fairly steep. To the north of where I live is the unpaved roads in the forest. There's one hill that always gets me. I call it "hell hill". It's bad cause it has many pot holes, cracks, and large stones. Makes getting momentum hard. Here is a view looking down from the top.
Quoted: 1425 Post(s)
Liked 1,946 Times
have not done Canton - but have done a few of the Dirty Dozen climbs including Sycamore and Logan ... did those climbs on road bikes - 38/28 and 39/27 gearing
we did frequent rides down into Sewickley PA *** (near the Ohio River) - with a few options to return including the Redgate climb which I believe is around 2 miles in length (? can’t recall) ... one part (1/2 mile to 1 mile ?) might be around a 10% grade and another part (1/2 mile to 1 mile ?) might be around a 12% grade
*** SweetWater Bike shop is located in Ambridge PA - near Sewickley ... great bike shop
Liked 1,946 Times
Liked 1,946 Times
just gotta hope the small rubber attachments/ thingies on the carbon soles stop you from
skiing down the hill lol
