Is a Trek 760 Too Racy for a 650b Conversion?
A BF member has a Trek 760 frame and fork for sale. I like 650b, but with 415mm chain stays and mid-80's race geometry, do you think 650b x 38 with fenders would work for this frame and fork?
Full spec. and geometry for this bike can be found here:
https://www.vintage-trek.com/images/t...TrekRacing.pdf
I figured I'd ask others who might know before requesting that the seller take measurements.
Quoted: 5888 Post(s)
Liked 3,472 Times
You may have seen this but this link is pretty good in terms of the measurements you should be thinking about when doing a conversion.
https://www.bikeman.com/bikeman-blog...sion-guidlines
I doubt this would fit. I question whether I could fit 700x28 in mine.
Quoted: 2952 Post(s)
Liked 3,106 Times
Likes For caloso:
Liked 3,472 Times
Hey its the OP's bike and this is no big deal. Someone else can turn it back into a racing bike. I am skeptical that this is a good 650b candidate though.
650b with fenders, floaty tires, 10 speed Gevenalle shifters, etc.on a race frame - now that sounds like fun!
Likes For jlaw:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
In answer to your question, no. There are other vintage Trek models that would work.
Unless you remove the fork blades and stays, braze new ones in, then sure!
Seρor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
Had one. Could fit 28's in, but I don't know what you'd do for brakes.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
"Neutering" or "emasculating" might be more appropriate.
I try to "tour" up my bikes- and I've gotten as far as putting a rack and triple on my 78 730. I don't think even I would do that to a 760. That bike is special- and this would, IMO, be disrespectful to that frame.
Commence to jigglin huh?!?!
Since I've got your ear.... I converted a 1985 Trek 410 to 650b x 38 with fenders, Daija Far Bars, etc. - great bike with a True Temper frame that fits me very well and I can hammer on that bike (or what passes for me hammering!) . I also have a 1984 Trek 620 that I cleaned-up over the winter and have ridden a few times - Reynolds 531CS with a more relaxed geometry - seems a little too mellow and since it has canti brakes I'm stuck with 27" or 700c wheels.
So, I'm looking for a Trek frame and fork with 126mm rear spacing that uses butted 531 steel and is suitable for 650b. I now understand that a race geometry will not work. So.... the 400 Elance uses 531 steel...? Any suggestions?
Thanks!
Liked 1,703 Times
A simple answer from a voice with experience. Thank you.
Thanks!
Thanks!
FWIW- the geometry of the 85 620 was identical to the 85 660 race bike- with the exception of the chain stay length and fork rake. I don't know about the 84 model.
If you're that on the idea of cushy tires- I'd do 700C and Compass Bon Jon Pass tires on the 620.
FWIW- my 86 400 Elance has the most aggressive geometry of all of my bikes- with the exception of the chain stay length at 42.5.
I've toyed with the idea of doing 650B on my 400 Elance. While I don't have the tires I really want on it- I do have the brakes I really want on it.
I'm less critical of your thoughts on converting the bike to 650B. However, I think I would be aesthetically critical of any attempt to "fender-ize" it given the lack of eyelets. Seen some ugly hacks out there.
I like where you're headed, though - a quick handling race bike converted to comfy tires. Best of luck.
incazzare.
650B = un-manly now?
Personally I think racy bikes are the best for 650B conversions. You get aggressive geometry with a cush ride--what's not to like? And it's not like this bike is super special.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Bikes: 1974 Behringer Custom, 1975 Schwinn Paramount, 1975 Windsor Profesional, 1976 Gios Super Record, 1985 Schwinn Paramount, 1985 Trek 770, 1993 Holland Ti Custom, 2000 Tommasini Sintesi, 2001 Colnago C40, 2019 Canyon Grail AL 7.0
Quoted: 115 Post(s)
Liked 126 Times
This all has my chuckling because that is in fact MY bike. Well, my old bike, I sold it a year or so back. Those are 25mm Continental Grand Prix Classics and man they barely fit. This bike also had ridiculous toe overlap. I don't know much about 650 conversion but I'm guessing no.
Happy to see this picture though. I remember it was the same day as Eroica in Gaiole so I went out looking for some gravel
Liked 1,703 Times
There's a point to where you take an item that had a single, badass purpose- and gentrify it into a non-threatening, leisure machine... I'm not into racing bikes- most everything I have is cushy and leisure- and I didn't understand why people took offense to my ideas of taking mid-late 80s competitive MTBs and turning them into leisure cruisers. I get it now.
Liked 3,472 Times
Running different size wheels is not mutilating the bike. This mod isn't likely to work on this frame given the tight tolerances but the frame itself will not be touched. You don't like the way fat tires look on racing bikes. I get it but that's the OP's choice, right? Personally I like old European racing bikes because, by and large, they can take a 28c tire and some can take a 32c tire.
Liked 5,803 Times
Thanks!
Thanks!
What you're looking for are "long legs" - long chainstays will give you more width where the tire's widest point is, longer fork blades (crown to axle dimension) gives you more vertical room - fork ID is rarely an issue. BITD, these were sold as sport touring or touring bikes.
A 400 Elance would be an excelent bike for a 650b conversion.
Likes For gugie:
Liked 5,803 Times
Ah, the alternative definition of Gugificazione...
Likes For gugie:
Quoted: 3464 Post(s)
Liked 2,831 Times
There are ideas, and there are questionable ideas.
I think it is time to go frame shopping.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,870 Times
Only the main triangle is 531, and the rear brake needs a little more reach than you get with a Tektro R559. MAFAC RAIDs might do it. Otherwise, it's fender-ready and has good tire clearance. If you're dead set on ful 531, I think the 715 from this period had that with the same geometry.
My Bikes
My Bikes
Likes For Andy_K:
I've got a 1982 Trek 614 that I think would be a pretty good 650B candidate.
Im in process of this now actually. I have (pretty much) all of the parts, just have to put them together.
