Goat Head Thorns?
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 278 Times
Has anyone tried tire-savers on their tires? If not, why not? They wouldn't stop all goathead flats but done right, should get most of the goatheads that didn't penetrate fully the first time.
https://www.renehersecycles.com/shop...s/tire-wipers/
Not advocating for Rene Herse, just found this website and its nice picture. (And $18? For a little wire, plastic tube and ancient technology.) We were using the exact same tire-savers 50 years ago, just no color and no stainless steel. Also minus that cute little loop around the throat. They worked very well. So did ones I made from scratch. (I used them on the east coast so I have no goathead experience with them, hence my question.)
You can make your own with 14 or 15 gauge spokes and that tubing sized to be a tight fit. I'd rather have 15 gauge but the tubing and a nice fit would decide it for me.
(I regularly rebuilt mine with the spoke wire after the tire area wore out.)
They are not perfect. They make noise, are a small amount of friction and spray dust and debris over your bike. It is normal to run them from the brake bolts; easy before the short bolts and recessed nuts. Sheldon nuts and a little re-working of the bolt loop with needle nosed pliers solves that nicely. You can also spare the seat tube and BB area clean(er) with the rear one mounted on the fender bolt hole on the chainstay support if you are lucky enough to have one. Aim the one at the front brake forward. Most of the dust you will see will be blow back, not a direct hit. On fendered bike, I used to mount them inside the fender. Not as easy but that did cure a lot of the mess. Other plus - they wiped your fendered rear tire - hard to do savely with your fingers
Ben
Ben
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Did I mention dinosaur tracks?
Pugatory 6 by Stuart Black, on Flickr
96090018 by Stuart Black, on Flickr
Apatosaurus tracks showing herd behavior.
89150010 by Stuart Black, on Flickr
Allosaurus track
DSCN0033 by Stuart Black, on Flickr
More Apatosaurus tracks
89150011 by Stuart Black, on Flickr
Allosaurus track showing stalking behavior.
There's even sex! Those are tail drags. Dinosaurs didn't drag their tails except for one reason.
IMG_0491 by Stuart Black, on Flickr
I do warn people before we go but they don't grasp how many goat heads there are out there.
Allosaurus track
Stuart Black
Stuart Black
Liked 4,222 Times
Goat heads by 14 country miles.
Stuart Black
Stuart Black
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Ben
Ben
Quoted: 171 Post(s)
Liked 278 Times
cyccommute - Awesome pics!
Darth Lefty - Yeah I've got 3 young kids (and all their friends) constantly tracking thorns into the house in their shoe bottoms. We try to catch 'em at the door, but that doesn't always happen. I've had more stuck in my feet than I ever imagined possible.
Quoted: 599 Post(s)
Liked 284 Times
OK true, seeing dinosaur tracks would justify the risk of goat heads but I do hate the damn things and glad we don't have to deal with them here.
Btw, goat heads are present on the ever popular Katy trail so take a good look at Stewart's photos so you know what to avoid.
Bikes: 1988 Specialized Stumpjumper Monstercross Touring Rig, and a couple of others
Quoted: 46 Post(s)
+1 on tubeless and I advocate for Orange Seal. It coagulates better than Stans IMO but at the expense of longevity. Add a little every 90 days and it's fantastic.
But be warned - if you get a big flat because of cut (I went through six Maxxis Rambler tires in less than a thousand miles) the spare innertube needs to have sealant too. All those goatheads the sealant has been covering for will perforate the tube in about a minute.
thenomad
Commuting
22
09-17-10 02:18 PM
