I need 38cm handlebars?!
Old 10-28-09, 10:54 PM
FBoD Member at Large
khatfull's Avatar
Quoted: 30 Post(s)
Liked 7 Times in 7 Posts
Just got through putting the Ergonova back on...we'll see how it goes, thanks. Love this stock white Cannondale gel tape. Thinnish gel...I took it off and to the sink, scrubbed it with hot water and soap, cleaned 'er up shiny white again, dried and reinstalled, like new. Good stuff.
khatfull is offline
Old 10-28-09, 10:55 PM
khatfull's Avatar
Quoted: 30 Post(s)
Oh, and I dumped 97g in the process over the stock CDale Controltech bar, whee!
khatfull is offline
Old 10-29-09, 01:59 AM
AnthonyG's Avatar
Quoted: 3450 Post(s)
Liked 420 Times in 289 Posts
You've already noticed that most handlebars flare out at the bottom. I was going to mention this this morning (well morning for me) but I had to go to work. Its a good idea to try out the bars that you have now fitted and what I was going to suggest is that you should measure at the end of the bars the actual width of the bars that fitted you shoulders perfectly and then take this measurement as what you require at the hoods.
Anthony
AnthonyG is offline
Old 10-29-09, 02:08 AM
I'm 6'2" and ride 40cm bars; have shoulders like the Schleks.
Back in the day, bars were narrower and 40cm was considered quite large.
Hendley is offline
Old 10-29-09, 02:31 AM
Roadie/Duathlete
Bikes: Colnago ExP, Look 595, Look 496, plus a few more...
My wife uses Salsa Poco 38cm bars, but she's only 5'2 1/4" (that 0.25" is very important to her...)... I'm really surprised that someone 6' tall would ever ride bars that narrow... you must be built like a shoe string!
audiojan is offline
Old 10-29-09, 06:42 AM
khatfull's Avatar
Quoted: 30 Post(s)
The Controltech bars I just took off are 42cm the entire length of the bar, as were the Kore bars I fitted to in the LBS a couple of days ago. I got the Ergonovas on last night, I'll hit the roller tonight and see how it goes. Thanks!
khatfull is offline
Old 10-29-09, 06:56 AM
Braden1550's Avatar
Bikes: I hate bikes.
I just went from a 40 to a 42. My shoulders have been measured at 385mm, so number one on list of upgrades is a set of 40cm bars, which I find to be great. Then a 90mm road stem (if I can find it).
Braden1550 is offline
Old 10-29-09, 07:03 AM
Bikes: DeRosa, Marinoni, Cannondale
You'll be more "Aero" with narrow bars, but I like the feel of a slightly wider grip, especially for climbing.
garboplex is offline
Old 10-29-09, 07:26 AM
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1102 Post(s)
Liked 559 Times in 446 Posts
Some of the newer models are even narrower at the brake hoods, so don't go overboard. I doubt you'd like the brake hoods spaced at 36cm.
I found FSA K-force compacts in a 40cm to be too narrow becasue the hoods were 2cm closer.
DaveSSS is offline
Old 10-29-09, 08:00 AM
Older than dirt
CCrew's Avatar
Bikes: Too darn many.. latest count is 11
Originally Posted by cyclefreaksix
I don't think I've ever even seen a 38c road bar.
I have. 38c/31.6 bar on my wife's WSD Trek.
CCrew is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
