Carbo Loading XLII
#151
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 913 Times
I'd love to have 1/10th his skill and courage
Rule #10 // It never gets easier, you just go faster.
#152
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Not to mention budget for gear (aka amount of free/sponsored gear)
#153
Quoted: 632 Post(s)
Liked 913 Times
yah here's your job today, break this rim
#154
Quoted: 632 Post(s)
Liked 913 Times
tis the season for night rides. I'm trying to update my light system w/ something more then the fully encased NR lumina.
Seems like quality china light are harder to find
#155
SuperGimp
Also learned that I can charge my garmin 520 while riding, but because of the aforementioned headlight mount, I had to flip the garmin upside down so the cable would fit. I need to find a low profile / 90 degree micro USB cable, trying to follow a map upside down while riding is interesting.
#156
I used my shiny new cygolite 900 whatever model it is Monday night when we took waaaaaay longer than anticipaged to get to Ventura. Worked great! Cobbled together an upside down gopro mount so I can mount it under my garmin, which was much more fabulous than on top of the handlebars (blows out the garmin display)
https://www.amazon.com/StarTech-com-.../dp/B003YKX6WW
#157
Quoted: 632 Post(s)
Liked 913 Times
I ordered this 1900lumen beast and two 4cell 6800mah battery. Light head is driven to 1500mah on max so 1 battery should be good for 4.5hrs of suffering
#158
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
I doubt you'll need to run it on max, so you can probably double/quadruple your suffering time!
Let us know what you think of the beam pattern. I have 2 magicshine (knockoffs) like that, with only one LED, but also with the beam-spreader/diffractor, and that basically spreads the spot from a 1ft wide circle, to a 1ft wide ellipse.
#159
Quoted: 632 Post(s)
Liked 913 Times
I have this one, it's wicked bright, but draws heavy current and overheats if on high for more then 30mins. I'd run it on med and high for DH only. It's heavy flood so needed to be paired w/ another light that had throw to it otherwise it was too easy to out run.
https://www.amazon.com/dp/B00BJCDH3K...d_i=B00BJCDH3K
Here's the full review that someone else posted about the C&B seen 3up vs the BT40 4up LED.
C&B Seen 1900 3up- Mtbr.com
amazon link to the BT40, which is 90% of what I was looking for, but needed more throw and longer battery. I only want one light on the bars, so I got the C&B though more expensive, better QC from china i'm reading. I"ll post up some comments once I get the stuff in. I"ll run it off older batteries til the new one comes next week.
https://www.amazon.com/Revtronic-160...JP9JK7D0DKCZ08
#160
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Cool beenz, that triple looks pretty good! I might end up buying one and giving away one of my singles
#161
SuperGimp
It's good for road riding with some ambient light, not suitable for totally dark trail riding, that's for sure.
#162
I have a Cygolite headlight, I think the Zot 250. It's a very good "be seen" light, I like the steady-pulse mode for riding at night to both light the pavement and have a subtle flash to get drivers' attention. Riding the streets of Irvine that are generally pretty clean, smooth and well-lit, it is a good enough "see where I'm going" light. For unlit roads or trails, I'd want a bit more light on the ground head of me.
So when you going to give us a write up of your cc tour, @TrojanHorse and @tunavic?
#163
Quoted: 632 Post(s)
Liked 913 Times
Amazon just restocked on Monday aka after I placed the order for the C&B, I guess they were out for months. Could only get the light head from china/ebay.
#164
SuperGimp
Um, soon. I'll give you a heads up though -we got shut out of Refugio because it was locked down and felt like the 154 was the only viable option given that we needed to make Ventura and damn, did it suck. It sucked! At least we found an alternate path down so we didn't have to dodge cars bombing down the hill at 40 mph (while they're going 80)
#165
Quoted: 632 Post(s)
Liked 913 Times
yah that's kinda why I stuck to the 1 til the 101....Used Harris Grade road WAAAY up by where the 135/1 split off. That shot me out into middle Lompoc. I had little desire to get to Solvang as I started the ride from Morro Bay that day. I knew once I hit the ocean, I'd have some yummy tail wind to whisk me away to Santa Barbara. And I did, I covered like 22miles in that last before sunset..on a loaded bike
#166
Yeah, I saw the out and back on Refugio on Strava. Given the choices of either going W all the way back to 101 or taking the 154, I'd probably do the same as you, but yeah.
#167
SuperGimp
We didn't get to enjoy much of a tail wind at any point of our trip though, which was weird and unfortunate both.
#168
https://www.lupinenorthamerica.com/L...Alpha_7200.asp
#170
An esteemed bike forums member recommends this light for true performance .
#171
SuperGimp
#172
Non omnino gravis
And yet in that thread where I (half-jokingly) said you could just get 15 Light & Motion 900 lumen lights for the same money and put them all over the front end of your bike, a couple of guys didn't see the humor in it.
You could also by at least five 2000lm lights from several manufacturers. Or, just buy another entire bicycle. The Lupine Alpha is the Birkin Bag of bike lights.
#174
Quoted: 632 Post(s)
Liked 913 Times
so there is a beach and ocean in this picture, 1/2 mile away was sunny and 70s
Since my Mavic Carbones split, this is the first ride limped back together. Actually using the stock wheel the Pinarello came with (Fulcrum 5s). Better note was also the first ride w/ the new carbon zipp bars and fresh highlighter wrap with fiziks 2mm
Ride was def smoother, not sure if from bars alone or the stubby wheels. Rides nice, bumps are muted vibrations so I'm thinking more bars then wheels, just short 30 mile slow coffee ride. I'll put it through the paces better next time.
#175
SuperGimp
Aha! The stock wheels! Is that the first time you've ever ridden on them? I don't think there's anything wrong with them, just a bit heavy. Mine still have the reflectors on.
