Di2 wireless unit
#52
I had it installed when I bought the bike, so I don't know. My battery is good for about 600-700 miles, I expected more, but I live and ride in hilly terrain and shift constantly.
Changing seat posts took about five minutes, and that's where my battery is too. It's not a big deal.
#55
Quoted: 3242 Post(s)
Liked 2,089 Times
And they’ve gotten creative with battery placement. You can get stems that have a slot built in for the cables when placing the battery inside. That plus h-bars now designed for internal cable routing and a bar end A button placement. Makes for clean installs,
#56
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
I extensively went through options to see if I could get a steerer mounted battery setup on my last build. There's some stuff readily available but I found that the way I would have to route the rest of the wiring to make everything work just made better sense for me with the frame I had to just go seatpost. Also had to do with stem options and the stock status of the steerer tube compression plugs that hold batteries.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
#57
I’m thinking of pulling the trigger on a wu111 to use with both my phone E-TUBE app and my wahoo elemnt roam...I believe I’ve read I can replace a jc200 inline junction box with it, without having to buy an additional cable, correct? My TCR has a jc200 in the tangle of wires underneath the bar...
now to research how to do the firmware update since I’ve read that can be tricky...
#58
Likes For Chi_Z:
#59
Someone would have to probably buy a ticket to Taiwan...
Once the WU111 arrives I'll see if there's room for improvement in cable management. But back to my original question:
The WU111 should be able to replace that JC200 unit in the pic, with no additional wires, if I understand correctly?
#60
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
Not familiar with the jc200 unit, and the photo doesn’t really have a good view of it for my eyes, but if it is a short box with two “female” ports in it, you shouldn’t need extra wiring.
#61
- Di2 two port adapter
- Used for extension purposes (female/female)
- E-Tube project compatible
#62
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
It will absolutely fit as a replacement for the F/F coupler. I just installed one myself, although internally in the seat tube, but I put it in place of that very coupler up front to update the firmware and get set it up since doing so requires disconnecting and reconnecting it. I also didn't use the app; the BCR2 charger/programmer and E-Tube Project on a Windows computer can update the firmware and it's a whole lot more reliable than some BT app.
#63
I installed it very easily, and used Windows E-Tube to update the firmware. Everything seemed to go swimmingly until my iPhone X failed to sense it over BT. Not sure why. I pressed the junction box button until the alternating lights. Phone couldn't sense it through the normal bluetooth connection. Tried to launch the E-Tube iPhone app, it claimed a "firmware update was needed" even though it was at it's latest, then would just spin the wheel non-stop. It never even asked for the 000000 passcode to authenticate the connection.
Fearing I had bricked it, I plugged it back into the PC and everything appeared fine. Unplugged, tested gear shifting, everything was fine. Tried to pair with iPhone, failed again. The decided to power on the Wahoo Roam...it sensed it and I paired it. Used the Wahoo app to add the Gear page. But I couldn't enable D-Fly yet because I couldn't connect via the phone. I'll try again tomorrow via the PC, otherwise I'm just going to ride to my local Giant shop where I bought the TCR and they'll do it for me.
I am a beta tester for Apple's new iOS 13...so the problem may lie in the beta iOS screwing up the E-Tube app (which was last updated a couple of months ago). This beta iOS has bricked one or two other apps I use, although the majority of them work just fine.
#65
Bikes: Giant TCR Advanced Pro 0 Disc
Quoted: 105 Post(s)
Liked 69 Times
#66
Di2 fanatic
Quoted: 53 Post(s)
Liked 65 Times
When I first got my Wireless Unit it also crashed at least five times until I finally managed to update the firmware on the EW-WU111.
What seems to help is to update every component's firmware using the SM-BCR2 charger (and windows e-Tube app). That should decrease the chances of the mobile app crashing. You can then use the mobile app to update the EW-WU111. And if it does crash apply the same fix as you did before, or have a look at https://di2center.com/2019/02/09/how...rmware-update/ (disclaimer: my site ).
#67
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
It's not you or iOS' fault - the e-Tube apps tend to fail during firmware updates. Just have a look at the reviews for the Android or iOS versions. There's loads of people complaining about this. The apps are just not very good. I tried using my wife's iPad mini this morning and on that device the app doesn't even get past the splash screen.
What happens? I'm guessing...
1) You connect wirelessly to Di2
2) You D/L an update.
3) The Di2 system applies the update...but to finish the update, like in Windows it must reboot the updated component
4) The wireless app (and the D-Fly) looses connection during the reboot, because well--the connection hard-hangs up.
Which means that E-Tube and D-Fly cannot handshake-check that the update worked...so they thought vomit at one another. E-tube errors out, and Di2 soft-bricks to protect itself thinking something went wrong.
#68
Di2 fanatic
Quoted: 53 Post(s)
Liked 65 Times
It is the nature of how firmware updates have-to-work. The problem is the wireless unit itself and its updates IME.
I have no problems with the rest of the apps, they are pretty nice, if a bit confusing at times.
#69
The problem is clearly the app on my iOS beta (not sure if the fault is in the app or the beta). The WU111 unit clearly works, my Roam senses and connects with it. I just double checked on the PC E Tube program and it works and has the most up-to-date firmware. And most importantly, I see on the web that if I had "bricked" it, it would have bricked the bike. Everything works and shifts perfectly. The iPhone app meanwhile, spins in that stupid gear circle endlessly. I've even uninstalled and reinstalled it, gone through the tutorial, and it says "firmware detected" then downloaded then spinning circle. But I haven't even turned on the pairing yet on my Di2 junction box! So this "firmware" it's sensing...is it for the app? Who knows, but the app is broken af for me on beta iOS13.1
Update: I just used the update sensors on my Wahoo App and configured the gearing (52-36 and 11-28T) and suddenly now D-Fly 1 and 2 are also working. So now I have all gear info on my Roam, as well as being able to cycle through pages by clicking on the top buttons of my shifters.
It is clearly the iPhone app that is the problem (or the beta iOS).
#71
I understand this, it would just be nice to get access to those features and make changes while I'm not near a PC. Also being able to connect to E-Tube Ride would be nice, in case I'm on a long ride and have forgotten to charge my Wahoo fully, if that dies I can switch over to E-Tube Ride and get most of the vital stats. Right now neither iPhone app is connecting to the Di2 via BT...
#72
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
It's kinda hoakey on my Pixel 3 also. ET Project sits and spins trying to connect, then says it failed to connect. Immediately after it says it connected to an unlisted device, and from there on seems to work properly. ET Ride can't connect at all. Even after Project has connected and the device is listed among connected devices under the system bluetooth settings... My guess is Google added some permission for enumerating BT devices at some point, and the E-Tube apps aren't configured to request it, so are unable to find the WU.
#73
#74
Liked 406 Times
#75
Di2 fanatic
Quoted: 53 Post(s)
Liked 65 Times
The e-Tube RIDE app will only connect to a STEPS (city/urban) e-bike, I have never managed to get it working with a road Di2 bike.
(feel free to prove me wrong though)
It works fine on my Pixel 3 sfrider. I am currently on Android 9 though..
