7/8-speed road cassettes going away?
Bikes: Peugeot Mont Blanc . Bianchi 28c 1980. Coppi Giro di Lombardia. Vitoria Vintage 1990. Orbea Luarca 1977. Trek 950.
Quoted: 51 Post(s)
Liked 12 Times
Not a concern here in Spain, Im in a Decathlon shop right now, I can see Sunrace, Shimano and Decathlons brand BTWIN , 8s cassettes and 7s cassette and freewheel. 12.95 € the cheapest. Perhaps its true that 12/28 and 13/32,34 no narrow ratios, "road" ratio are not so easy to find in less than 9s cassette. Im a 8s fan too but my heavy body needs 13/28, in fact my only bike with 12/23 runs triple chainset.
Bikes: 1989 Cannondale SR400(?)
Quoted: 27 Post(s)
Liked 15 Times
Amazon probably has them. That is where I get Sram PG-850 8 spd cassettes. They work good with shimano. I use sram chains too.
Likes For letenn:
Quoted: 76 Post(s)
Liked 19 Times
I received a brand new HG50 12-25 8 speed cassette in the mail today. I took a Dremel to the rivets holding it together so I could remove the 25 tooth and put the first 7 on my wheel. I used a thin spacer (1/16th" or so maybe slightly smaller) behind it to take up a small amount of play with everything put together and no spacer.
I had to adjust the derailleur swing for both high and low, but it shifted great both up and down the cassette while on the stand (RSX 7s brifters and Alivio derailleur) no road test yet.
I have a 7 speed cassette I can tear down for the spacers, but thought I'd try it after reading on Sheldon Browns site.
After doing that I hit a yard sale and found a fairly new 13-23 7s HG70 cassette on a 105 hub with a Mavic rim. I also picked up 4 more bikes.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
I bet you can have a bike shop order what you want through Euro Asia Imports:
https://www.euroasiaimports.com/prod...peed-c1141.htm
It'll be pricey, though- they don't lower their prices to "clear out" old inventory.
Air-cooled VW's? My first car was a '71 Squareback, then I "graduated" to a '61 crewcab pickup. Working on bicycles was great training for working on VW's... very simple machines. Nowadays I drive a Camry: boring boring boring.
Jeff Wills
Jeff Wills
For my commuter: so far, I'm happy with the Sunrace 12-13-14-16-18-21-24 7-speed I installed in December. ~1200 smooth-shifting miles so far.
For my weekend bike: last night I purchased an Ultegra 12-27 9-speed, and I plan to run it as an 8-speed per Sheldon's "8 of 9 on 7" recipe. It's 12-13-14-15-17-19-21-24-27... and I'll try it without the 19 tooth sprocket. So, close ratio for flats and then one big jump to the granny gears. I don't know if that's a good idea...
First though, I need to swap a Hyperglide freehub body for the Uniglide one on my spare wheel. It's got a Wolber GTX2 rim and a tricolor hub.
vintage Bianchiist
Bikes: Bianchis, 84 Superleggera, 86 Giro, 87 SportSx, 87 Campd'Italia, 87 Limited, 88 Proto, 95 TSXChorus, 94 TSX105/DAax, 94 Super Grizzley RC, 94 Genius Record, 06 Pinella Boron, 18 Volpe Avanti, 00 Megapro ST Veloce00 EM Strada OS
Quoted: 35 Post(s)
Liked 13 Times
i too like the thicker chains. The tight ratio 7’s & 8’s make really robust racing triples. I have an Ultegra 6503 triple (52-42-30) on my commuter bike matched to a Dura Ace 7400 freehub (7 speed) with a 12-23 cassette. It makes for a super versatile performance oriented moderate climb capable commuter. The intermediate gears are quite tight. Uniglide cogs are the bomb - not only are they really durable, but they are also very customizable since individual cogs can be switched out.
Quoted: 1861 Post(s)
Liked 665 Times
I just found a bunch of Campagnolo 8-speed cassettes on Ebay.
tantum vehi
Quoted: 1168 Post(s)
Liked 993 Times
I have begun hoarding…
Reviving this thread as a certain something happened in the interim from the last post in 2018.
7/8s cassettes (and 7s freewheels) have slowly been dropped from productions lines and the global parts shortage seems to have accelerated (or exacerbated) this trend. With manufacturers struggling to keep parts for current groups in stock, I don’t see them scrambling to replenish 7s and 8s stock. We did a search on QBP last week and got a lot of goose eggs in return.
So I, for one, am hitting the panic button and have begun hoarding my favorite combos. (That actually requires buying two cassettes and hybridizing them as I need to customize things to get what I want because I’m weird). However, I can’t find any example of a cassette that starts with a 13t sprocket.
Freewheels are even worse…
One might think they could order 9s or 10s cassettes and scavenge the sprockets, but a few things make that challenging or impossible:
So what are you doing as the end becomes nigh?
- Sprocket thickness is thinner and can affect indexing (not an issue with friction shifters).
- Overall width of the cassette is reduced so a spacer my be required to get the lock ring properly tight.
- Many modern sprockets come on spiders so they aren’t able to be pulled apart and used with old 6s/7s/8s spacers.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Quoted: 1163 Post(s)
Liked 442 Times
aka: Dr. Cannondale
Quoted: 2157 Post(s)
Liked 3,425 Times
- Sprocket thickness is thinner and can affect indexing (not an issue with friction shifters). Buy a selection of thin spacers; they come as thin as .5mm
- Overall width of the cassette is reduced so a spacer my be required to get the lock ring properly tight. Yes, this is often the case. Again, thin spacers do the trick
- Many modern sprockets come on spiders so they aren’t able to be pulled apart and used with old 6s/7s/8s spacers. Buy lower level cassettes. They are a little heavier and the coating/finish is different, but they shift just fine and may last longer.
Likes For rccardr:
tantum vehi
Liked 993 Times
All good suggestions, Doc. I have routinely bought Sunrace for the reasons you list. Microshift is similar. But even those companies start to use spiders in the 9s & 10s ranges so it can be hard/expensive to get large sprockets as singles.
I have thought about the custom spacer route, just haven’t pulled the trigger. However, I have a massive stash of spacers - they have slightly different dimensions as different manufacturers use slightly different thicknesses of sprockets, so I’m already forced to mix-and-match.
No wonder people like Grant Peterson revive ratchet shifted and spend time designing a rapid rise RD for possible reintroduction.
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Quoted: 1954 Post(s)
Liked 2,022 Times
I hope IRD continues to supply us but it doesn't look good right now.
https://www.interlocracing.com/shop/...earch=cassette
I have enjoyed a 5 speed from them and also a 10 speed cassette. My IRD cassette had no spider.
Quoted: 1088 Post(s)
Liked 1,206 Times
This prompted me to check Sunrace's website, and there is an interesting entry, a 7-speed 11-24 cassette that says it is compatible with 10-speed chains. Is this new, and is it fulfilling some specific demand? In any case, I kinda like the look of it.
https://www.sunrace.com/en/products/detail/csd10x-7ap
Edit: I guess I answered my own question by asking Google, "What is a downhill cassette?"
Likes For noobinsf:
Quoted: 978 Post(s)
Liked 1,642 Times
Yep... Read Um and weep. I have had to rebuild my 6 speed Freewheels from new 7 speed freewheels. Looks like the cassettes are going the same way. Oddly as I get older the older stuff gets harder to find. Ha... Oh well... As I have said many times, Its just an engineering problem...
As my parts bin gets smaller and smaller my trash bin gets more valuable...
Likes For zandoval:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 414 Post(s)
Liked 942 Times
Makes me feel better about my recent freewheel purchases - maybe I don't have too many after all!
Just went from a 14-28 six speed to a 14-24, because the 18 to 21 jump just felt too big. I like close ratios myself.
Quoted: 359 Post(s)
Liked 582 Times
7-sp cassettes
I have an NOS tight one, just pulled (with the 1056 group) from a ‘92 Schwinn.
My first metric, with 4500’ of climbing, was on a 12-21 7-speed, when I thought indexing was magic.
I couldn’t ride that now. I shudder at the thought.
Likes For bamboobike4:
Quoted: 754 Post(s)
Liked 737 Times
I think that there will always be a good supply of 7 and 8 speed cassettes. You be able to get any gearing you want as long as it's 11-28t. When the supply of 110 and 130 bcd chainrings dry's up, everyone better hope their happy with one size fits all gearing.
When I bought my new Giant Sedona in 2018 I was looking for a bike with a close ratio Cassette/Freewheel. I find it a bit strange that the 6 gears I use most are more closely spaced (14 - 24T) on their entry level comfort bike with the Shimano MegaRange freewheel, The same one used on many other entry level bikes from other manufactures, then most of their road bikes costing 10x as much with 10 and 11 speed cassettes vs 7 speeds.
A little research however shows some Shimano 12 - 28 10 speed cassettes with much better spacing readily available, which I'd have installed if I where looking for a road bike.
