Busted Carbon
#51
I thought this only happened to Trek Madones...
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
#52
#53
CAADdict
Bikes: 2009 Cannondale CAAD9-?
Liked 5 Times
Galvanic corrosion. Basically, the interface between the carbon fiber (the actual fiber, not the bulk material) and bare aluminum becomes a little battery when you add a bit of electrolyte (water with dissolved salts of some sort or another) and eats away at the aluminum side. Here's an old thread on the subject.
That's definitely "must know" information.
#55
Bike ≠ Car ≠ Ped.
DannoXYZ, in post 7 in that thread, mentions the gel coat on carbon that should protect against carbon-Al galvanic corrosion. Hopefully it works that way in the real world, too.
#57
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1270 Post(s)
Liked 1,308 Times
OTOH, my carbon bike, which I've owned for over 4 years and have crashed twice, is still perfectly -- or at least acceptably -- intact.
#58
Quoted: 18883 Post(s)
Liked 10,646 Times
I crashed a year ago turning too sharply, and bent the rear triangle on an aluminum frame. I ride my carbon bike ... differently. It's not that I'm more conservative, but I try to take fewer risks on it. Any material can be destroyed if you abuse it right.
#59
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
Racing isn't any harder on a bike than non-racing.
#60
Old fart
Quoted: 3610 Post(s)
Liked 3,434 Times
Yes. When we designed the original Trek carbon fiber frame (the one that used round tubes bonded to aluminum lugs) we used a fiberglass sleeve between the carbon tube and aluminum lug to prevent electrolytic degradation of the joint.
#61
Old fart
Liked 3,434 Times
#66
Quoted: 4251 Post(s)
Liked 2,965 Times
you don't have to, but it seems to help.
#67
Bikes: 1991 Tomassini Prestige 1973 Raliegh Supercourse, 1975 Panasonic Sport Deluxe, 1983 Fuji S-12, 1975 Motobecane Mirage, 1983 Motobecane Super Mirage 1999 Trek 930 1989 Trek 930 ,
#70
Super Moderator
Liked 935 Times
btw, good luck with everything, umd
I've raced most categories, so I know what racing's like.
#71
Has coddling tendencies.
30,000 +miles on this full carbon fiber custom tandem bicycle . . . . . . including Easton c/f handlebars, front and rear; c/f cranks; c/f fork . . .
Have BROKEN 2 steel tandem frames and and one steel tandem fork . . .
So you still ride steel**********
Anything can wear or break eventually.
