Downtube shifters: Dura-Ace 7700, 7800, 7900?
I installed a set of new (NOS) Dura-Ace SL-7700 downtube shifters in early April, and they have been great so far after 2400 km.
Now, I'm thinking about upgrading all of the components on my 30-year-old Bianchi, from the original 105 to Dura-Ace 7700.
I would be making the upgrades piecemeal, as my budget allows and as I'm able to find NOS or used components in good condition.
So, that means I would have a mixture of 105 and Dura-Ace for a while, until I'm able to complete the entire set.
Would a Dura-Ace (10s) rear hub be compatible with my 105 (8s) rear derailluer?
I use downtube shifters set to friction mode, so I shouldn't have to worry about shifting inconsistencies other than adjusting the limit screws, correct?
Maybe I'll need a new chain?
Are there any other issues I should be aware of?
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 982 Times
Likes For georges1:
aka: Dr. Cannondale
Quoted: 2156 Post(s)
Liked 3,418 Times
I suggest caution with regard to Dura Ace 10 speed hubs. IIRC, 7800 hubs are limited to DA/Ultegra 10 speed cassettes due to the taller splines.
Quoted: 3530 Post(s)
Liked 2,940 Times
Steel is real
Quoted: 671 Post(s)
Liked 982 Times
Likes For georges1:
Likes For ramuji:
Dura Ace FH-7402 takes a special 8 speed cassette and requires a threaded outermost sprocket.
Other models of Dura Ace FH (7403, 7700, 7900) don't have the same cassette compatibility limitations but could present a problem if the freehub body needs to be replaced. The DA models use a different mount from most Shimano models and accepts only certain freehub bodies. Since these are usually quite old, parts availability is very scarce and expensive.
Likes For KCT1986:
Thanks to georges1 rccardr KCT1986 for info about Dura Ace 7700/7800. Obviously, there is a lot I don't know about these components, and the help/suggestions is a big help.
I'm not set on upgrading to Dura Ace, I just chose that because I recently installed the Dura Ace downtube shifters and really like them.
I'm looking at Ultegra now. I've spent the past few weeks trying to read as much online as I can find about Ultegra 6600 mainly, since I think I want a 10s cassette.
If I understand what I've read, the Ultegra FH-6600 is 8s 9s 10s compatible, correct?
I should probably also consider 105 5600. (My 1993 steel frame still has the original 105 1056SC groupset.) Are there any significant differences between Ultegra 6600 and 105 5600 other than weight?
Apologies for the vague questions. I'm still trying to suss out what I don't know that I don't know.
aka: Dr. Cannondale
Liked 3,418 Times
Everything you mention above is cross-compatible and works with 8-9-10 speed systems.
No real performance difference between 6600/6700 and 5600/5700, but if you are looking for bright and shiny there were polished versions in both of those series.
It is not unusual to find new or almost-new 5000 series RD's at really good prices.
Steel is real
Quoted: 671 Post(s)
Liked 982 Times
Likes For georges1:
Blamester
Yes, the FH-7800 uses a aluminum freehub body that had the taller splines to prevent the cassettes from damaging the body. This limits the compatibility, and will not allow the use of most common Shimano HG or HG compatible cassettes from other manufacturers. This limitation means that speed will be limited to 10 speed only.
And they are excellent.
Steel is real
Quoted: 671 Post(s)
Liked 982 Times
The FH-7850 was an interesting piece and somewhat limited, since it was quickly superseded by the FH-7900. It was very similar to the hub used in the WH-7850 wheelset.
As with most DA, it has a 'special' look. Replacement parts for the unique designs of the DA is now the challenge.
Steel is real
Quoted: 671 Post(s)
Liked 982 Times
aka: Dr. Cannondale
Liked 3,418 Times
All Shimano HG cassettes (except- possibly- 7800?) are cross-compatible with that freehub.
The less expensive 105 series cassettes are slightly heavier but work just as well and are much less expensive than Ultegra or DA.
Even the 7800 cassettes will fit on the FH-6600.
Correction, the 6600 cassette in most combos with a 11t or 12t smallest sprocket should work with FH-7800. Also the 5600 cassettes should work.
Last edited by KCT1986; 08-22-23 at 03:14 PM. Reason: correction for compatibility to FH-7800
