Road bike gearing?
#101
Quoted: 1530 Post(s)
Liked 724 Times
But bikes? Let's see... Cartridge bearings, creaky out of spec BBs, squeally dragging brakes, more chordal action in drivetrains, far less choice of ratios in spite of the growth in cog counts... But the rest is good. It's swings and roundabouts same as all the other tech.
Electronics are far more capable but you have to wait for the ridiculous complexity to boot up, etc...
#102
Quoted: 4527 Post(s)
Liked 5,031 Times
It's a physical limitation of the derailer drivetrain that any given jump in the number of teeth between cogs gets bigger as the cogs get smaller, and once you're down to one tooth jumps the gap gets bigger as you faster - which is the exact opposite of desirable, as evidenced by gaps that go 4,3,3,2,2,1,1,1,1,1 or whatever.
The only ways to mitigate this are either shorter chain pitch, bigger rings and cogs, and/or more chainrings. The 38/50/52 combo I identified makes such a nice ratio curve I guarantee it'll be a thing if civilisation persists long enough. It changes the line from an upwards curve once you hit the one tooth jumps to a straight line. And it could be retrofitted to existing cranks as a slightly offset small ring and a double big ring, which I suspect could be made to shift quite smoothly with modern tooth profiling techniques, with the shifting taken care of by electronic syncro.
#103
Liked 5,031 Times
Oh and your BS comment about nobody riding slower than 10 mph up hills.
#104
Liked 724 Times
Unless you think that one day all bikes will be e-bikes, this is the writing on the wall. The industry is taking ratios in the wrong direction for efficiency. Good front shifting became a thing, and I'm pretty sure slightly better front shifting can become a thing too. Electronic syncro makes managing the combos a non issue, so the only barrier is milking the 1x fad first.
#105
Liked 5,031 Times
Of course it'll happen. I've half a mind the industry's long range plan is to lead us down this blind 1x alley before ostensibly and belatedly waking up to the fact it results in a crap ratio spread. And given that so many tech developments are necessarily about realising efficiency gains, and that most improvements in efficiency have already happened, cogs smaller than 13t are waiting for the axe. Everybody with more than a passing interest has seen the graph.
IMHO front shifting - however smooth - is not a great solution with its step changes. For me the evolution to 1x drivetrains for mtb was a big step forward over previous triples and doubles. I can’t say I’ve ever wanted to go back on that. For road use it is more marginal, but I don’t like the idea of a triple there either.
I also don’t believe the “industry” really has any cynical long range plots. It’s just normal evolutionary engineering development and the bike industry is actually pretty conservative compared to many. It’s only in the last couple of decades things have really started to move and the resistance to change has been relatively high.
#106
Advocatus Diaboli
Quoted: 4760 Post(s)
Liked 1,542 Times
Some of the irony IMO that exists with where bike tech is heading, is the fact that things such as electronic shifting, disc brakes and tubeless, require a modicum of additional maintenance, knowledge, and mechanical ability. At the same time, we're seeing the small bike shop struggling to remain in existence because of the changing manufacturers' distribution preferences to larger but fewer retailers.
#107
Liked 5,031 Times
Likes For PeteHski:
#108
Quoted: 8366 Post(s)
Liked 9,217 Times
The range isn't a problem, for me at least. If I'm going fast on my mtb I'm usually coasting downhill. I never (rarely) spin out unless on the road.
On a road bike I see no advantage to a single ring. Shifting isn't a big deal, I don't mind it.
Likes For big john:
#109
Quoted: 741 Post(s)
Liked 412 Times
1x had a disastrous debut in the pro peloton. One team tried it and none since. when the Trek team went to SRAM, I remember reading that the company quietly designed a more standard crank for the team. As with tubeless, the industry is finding out that some things that work great for mountain biking may not be as effective on the road.
Likes For colnago62:
#110
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
Depends on your terrain and strength level. I live in Colorado- most of what we do is climb and descend bigger passes. I'm older now and I don't crank out big power. I'm not averaging 250 watts on a 3-4 hour ride with 3K-5K off climbing. Some do but I can't. So I run 50/34 and 11-28 + 11-32. I know a few guys here who run standard setup but they are almost always really strong ex-racers who push way more watts on average than I can. That type of gearing (54/30 with 11-25) keeps my HR too high and my cadence too low, and I am too old for that.
I like my 2x setup since I have to deal with altitude (6,000-12,500 ft...sometimes up to 14,000 ft elevation) and steep terrain that usually ranges from 6% - 15% and the climbs are 5-15 miles at a time. They feel relentless. If I lived on flat land or places with shorter punchy climbs, I'd prob run a standard 2x setup with 54/39 and 11-25.
I keep a 1x setup (32 and 11-46) on my mountain bike though I would prefer a 11-50 next time. The terrain is usually a bit steeper than road and I like to "rest" on some long climbs so I can enjoy the scenery, of which we have a lot.
#111
climber has-been
Quoted: 3535 Post(s)
Liked 3,686 Times
A single ring on a road bike is problematic. The speed range of a road bike is too wide.
The smallest single chainring that allows a reasonable cadence at speed is about 50t. And if you want the low climbing gears that are now popular, you'd need to pair it with a 50t rear cog.
So the rear cassette would need to be an 11-50. Thank you, I'll stay with my double chainring.
#112
Liked 5,031 Times
Likes For PeteHski:
#114
Liked 5,031 Times
A single front ring on a mountain bike solves issues regarding complex suspension design and short stays with 29" wheels. Also, front derailleurs suck in muddy conditions, a one by is much better in mud.
I'm open-minded to trying a 1x road setup and will certainly consider it on my next bike. But I'm pretty happy with compact doubles on the road too.
#115
Liked 9,217 Times
I'd be curious to try a one-by on the road, I just don't think I'd like to buy one yet. I've seen riders out in the mountains with high end bikes and single ring, but they were much younger and/or stronger than I am.
#117
Liked 724 Times
That's not my use case; my thing is I like to go fairly fast, but I'm lazy. Also, my terrain is flat, and most of my riding has been done in street clothes, so I'm not after a really wide range. Getting on top of a slightly higher gear is harder if you're not in lycra, so I'm pretty well attuned to noticing what's efficient. I've always been prepared to sacrifice one or two cogs on the either edge of the cassette that I would occasionally use if I had them, for cogs I'll use often.
I invite anyone who's both sceptical of the value of close ratios, and who has a power meter and/or heart rate monitor, to have a go at skipping a gear while they watch how hard they're working.
The thing is, we shouldn't have to choose between close or wide these days; we could have like 30 efficient ratios to choose from, although there'd be some minimum overlap dictated by maximum jump between rings. It could shift just like a normal triple but with syncro, and then if you wanted a half gear within the overlap zone you could double tap the shift button. Wide, and super close.
But nooo, front derailer bad (when they've never been better), triples extinct.
#118
Method to My Madness
Quoted: 2035 Post(s)
Liked 1,526 Times
#119
Liked 724 Times
Red is 39/53 for comparison, green is 38/50/52 shifted normally without half-stepping, blue is the half-step. X is gear number, Y is ratio.
#120
Quoted: 839 Post(s)
Liked 1,691 Times
I'd just run an 11-28 with a 50/34 compact crank. With a 28mm tire and a 100rpm cadence you'll riding less than 10mph in the lowest gear combo. You really going to go slower than that?
BTW standing out of the saddle to climb takes pressure off your knees. And you'll be going faster than sitting and spinning at 1000rpm in a super low gear.
#121
Quoted: 464 Post(s)
Liked 182 Times
I absolutely go under 10 MPH when the grade is 10% or over on extended climbs so my cadence is slow. My friend just did a 1X setup with a 50T. He can spin a lot faster than I can at those grades and it is much easier on his knees. I'll be interested to see how the 1x road gearing develops but I'm quite happy with my 2x, especially since I recently swapped the 11-28 for a 11/32. I have dropped a road chain twice so I sort of see the draw of the 1x and the simplicity but I'm going to be a slow adopter of this one (till I get a new bike, I suppose).
#122
Liked 5,031 Times
People climb a lot slower than they think!
#123
You need a less than 1:1 gear if you want to do anything resembling spinning on a 10% incline, - unless you can do monster watts. 3W/kg makes you go about 5.5mph. To go that "slow" at, say, 75RPM you need a 30t ring and a 34t cassette (!)
#124
Quoted: 464 Post(s)
Liked 182 Times
Yeah, for sure. I see people stopped or just hanging their heads grinding it out on those. I just don't bother trying to stand or my HR goes way up. I find it easier to sit and grind it out on those steeps. I go anywhere from 5-7 or I'll blow up. We always know when flatlanders show up since at 10,000 feet, a 10% climb can be a shock. I often stop and chat, just because I know first-hand how demoralizing that can be on a hot day. I have pulled a few up the pass after that. Company in suffering, is only panacea you need on those. People have done it to me when I first moved here.
#125
Liked 5,031 Times
Exactly. But as soon as you mention a 1:1 or even lower gear many people assume (incorrectly) they would be spinning out in such a "ridiculously" low gear. I'm doing a Sportive in a couple of weeks time in the Peak District. 3500 m of tough climbing, with some of the slopes north of 20%. I'll be grinding away in a 34/34 gear, while many will be rocking up with considerably bigger "man" gearing. There will be plenty of people walking and some seriously low cadence grinding! Ideally I would go even lower than 1:1, but it is what I have for now at least and I definitely won't be walking. However slow I ride I've never been overtaken by someone walking their bike up a hill.
