Ever modified a crank to add a granny?
Bikes: my precious steel boys
Quoted: 438 Post(s)
Liked 603 Times
I'd rather like to try this because a 53/42 crank does not lend itself well to climbing for a relative out-of-shape guy who hasn't cycled in four years prior to the latest bike purchase.
Realistically I should probably get a different crank until I grow into the SR one. Out of curiosity, how much does the derailleur max capacity matter, is it only really an issue if you attempt to use the "bad" gears like granny/small cog?
Likes For degan:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
what's the bolt circle diameter on your crank? if you don't know, then what crankset do you have?
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For thook:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
I've seen an Avocet triple, which was a modified Ofmega.
VeloBase.com - Component: Avocet Touring Triple
Likes For JohnDThompson:
Yeah, I have a few of them myself, both the triple version and double version. The triple version is drilled for three different BCDs: 144mm for the outer two rings, and 102mm or 74mm for the inner ring. I haven't seen too many ring options for the 102mm BCD, but the 74mm BCD is widely available.
Old fart
Liked 3,401 Times
Quoted: 7351 Post(s)
Liked 2,478 Times
I saw one in a video somewhere. I think the guy is in Finland or Scandinavia.
Likes For noglider:
Quoted: 438 Post(s)
Liked 603 Times
right. small/small or big/big are the issues if you're exceeding the capacity. in either case, you could wreck and/or break parts. worst case...the world comes to end..if the gestapo doesn't admonish you into irrevocable shame first
The 53 ring is fun enough on tailwinds and downhill false flats that I'd like a triple over a compact if possible.
I'm also going to try to see if I can get a Suntour with a 28-cog to see if that can get me up short steep hills, but that's stretching the limit of the RD.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
It's the Campagnolo Strada Record crank with the flute arm. Velobase lists a BCD of 144mm, but I'd have to actually check myself on my frame.
i've got a 7spd suntour alpha 13-28 i've hemmed and hawed on using, but decided not to. the teeth and pawls are in excellent shape. it just has some surface rust on the cogs from being in my shed that could very well be cleaned. you can have it for shipping or maybe we can trade, if you want to do that. just calculate what the capacity would be and let me know
Likes For thook:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
so, i really started out wanting a simple way to do this and now i've got one thanks to all the input here. this idea will eliminate potential inaccuracies or mess ups going "freehand" on it. plus, i don't need to rig up any press fixtures
i'm going to make a template on my drill press using some high density polyethanol board i got for making strut spacers. trace out the chainring onto the board marking all points to be drilled, use a larger than 74mm hole saw on the press to make the template disc, drill the 5 bolts at a pilot hole size, drill the disc center to run a bolt through to clamp the disc to the inside of the crank, and then hand drill through 5 pilot holes of the disc and into the spider. this set up will act as a guide for my bit/s and tap. i just haven't decided what the final bolt size/pitch will be as i still have to decide on fasteners. if i can easily enough find some kind of applicable stud, that'll do the trick. otherwise i'll go with the hardware in the link depaso provided
image of the backside of my crankset stolen from the web. nice area for a granny, no?
Likes For thook:
Quoted: 438 Post(s)
Liked 603 Times
144 is likely accurate, then.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 438 Post(s)
Liked 603 Times
(the actual long-term project is to replace the old SR parts with a new silver Potenza 11 set but that's several hundred dollars down the line, haha)
Likes For sheddle:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 438 Post(s)
Liked 603 Times
It's more about getting a short-term solution to make it more suitable for steeps until I actually splurge on a new grouppo. Realistically a better solution would probably just be finding a suitable old triple at the co-op that can get put on the frame, but I do love the look of the fluted Strada.
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
Bob Freeman has a jig to do a Campy crankarm with great precision.
He has done many - prolly 100s
Finding the adapter hardware is up to you however.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Likes For mpetry912:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 76 Post(s)
Liked 76 Times
i didn't read through this thread with a fine tooth comb so someone may have mentioned this already, but if you're drilling on the same plane as the existing sprocket holes, just work out the difference between the stock bcd and the granny gear bcd and measure down that distance for your hole placement.
here's a high quality illustration to help show what i mean
if you do this for each hole, your granny gear should be centered with no wobble.
Likes For t_e_r_r_y:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i had thought of that. and, yes, that would enable centering the ring to the spindle. the other concern for me is getting the holes drilled straight so the hardware goes in/through straight so the bolt holes on the ring line up spot. so, i've decided to make this disc/template/guide thingy. otoh, could this be even more simple and easy? probably. hmmm...i think i'll review things once again. thanks!
Likes For thook:
Quoted: 76 Post(s)
Liked 76 Times
i missed out if you have a drill press or not. if so, you can mark the holes and then use some bolts/washers/spacers/whatever in the stock sprocket holes to work as stand-offs to rest the crank arm on the drill press table to keep it level/supported while you drill the holes.
here's another terrific illustration to show what i mean. this is the side view of the crank arm with some bolts n junk spacing it off the table to work as supports/keeping everything level
I think you should use this as an excuse to get an indexed rotary table. That way after you finish drilling your new granny gear holes very precisely, you can continue on with this productive hobby by drillium-izing all your chainrings...
